#2801 | |
Senior Enthusiast
Re: What did you do to your truck today?
Having driven it mostly in crappy weather, I have been somewhat impressed with the containment of water spray in the rain. Retaining the entire inner fender above the tire, the engine and firewall haven't gotten any dirtier than they did before the side panels were eliminated. |
#2802 |
![]() Join Date: Dec 2010
Finally got the frame to the coater, put in xmbr, will hang everything else this week
#2803 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
got the windows in at long last on the street truck....
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
#2804 |
Just got back from portland swap meet the other day....with a load of parts for the pro street truck...getting closer now
#2805 |
![]() Join Date: Jan 2011
Holy Sheep dip!!! That's a full load of parts!!!
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
#2806 |
Those of us with out talent have to buy that many parts to keep things rolling.......lol...Well there is almost 3 trucks in all those boxes.
#2807 |
Lovin' that two tone paint split at the upper body line.
![]() Last edited by lakeroadster; 04-06-2011 at 07:30 PM. |
#2808 |
bought new battery
took off fuse block drew diagram off fuse block cut wires from back of fuse block found tons of bad/wires that arent being used cut some wires now i need to make new ones and remember how to put it all back together. |
#2809 |
Hey thanks on the paint split......That little gold stripe that runs between the blue and white worked out awsome..There were a few challenges with splitting it there like the door jambs for example. But once we figured out that the jambs had to be done the same way right throught , it turned out really well. Thanks again
#2810 |
![]() Join Date: Oct 2010
Dang whtnxt, what a truck full of parts!
Other truck looking great!!!! Like the color combo towersddg9-- You can tell that is going to be one sweet truck ![]()
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
#2811 |
Hey guy's thanks for all the compliments....
#2812 |
Well my cousin came over today so I had a helper. We pulled the bed, hood, front clip, doors, gas tank, and all of the wairing and dash stuff.
I pulled the master cylinder and heater core assembly. Last edited by AdvantageR1; 04-06-2011 at 11:37 PM. |
#2813 |
replaced cracked windshield and new rubber, new ****ty glove box, new rally rims with
new meat bfg t/a 245/60 15 front and 275/60/15 rear oh and took the dog for a ride and of course he farted. |
#2814 |
#2815 |
dont get to work on mine for a little while as im stuck on flood duty up here in morehead mn for the national guard
#2816 |
Dropped the truck at the muffler shop.$200 duals with turbos.Can not wait to hear it tomorrow!
65 c-10 swb,bbw,step,402/t350,sold!! 1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold Bought the wife a 84 gmc short step |
#2817 |
Broke a fitting in the intake.
#2818 |
Realizing the hardest part of getting the truck done is getting all parts in at the same time...
#2819 |
Took the day off to paint the frame while the cab is off at the body shop getting some metal implants.
I'm a little embarrassed showing this picture after seeing the gloriousness of towersgg's newly coated frame. ![]() |
#2820 |
Got a speed sensor for the truck, just waiting on the braided wire loom to get here and then the wire harness and gauges are getting installed
![]() Last edited by 1966JSM; 04-08-2011 at 11:47 PM. |
#2821 |
UCA63
Stripped out a '63 930 cab (C-30) that someone in the past had tried to move with slings through just the cab(doors open) (yes,the whole truck,duallies and all)........you guessed it ....it buckled.
too bad too 65000 miles on it. Note worthy parts: Recently recovered seat bottom Replaced and near new fuel tank Brand new looking sending unit All rubber parts in mint condition(less door seals) Deluxe heater Uncut dash center I thought I did pretty well for a freeby T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) Last edited by 63sbssbbw; 04-09-2011 at 07:38 AM. |
#2822 |
Put in gearbox, used CPP kit, overall not bad, I did'nt like the lower forward bolt set up
#2823 |
completed 4bolt roller from 98 suburban, eagle crank kit, comp cam, air gap intake, can't wait to fire it up
#2824 |
![]() Join Date: Nov 2007
Got my A/C running today!! Just in time for hot weather. 40 degrees at the center vent, fan on high.
This a Vintageair GEN IV magnum in my 65 LS2. Custom setup using OE low mount compressor. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
#2825 |
Today I swapped manifolds on the 67 and got it running, Then I cleaned out the interior of the 60 and got the clutch and brakes pumped back up then I got it running( been sitting since September of 2010. I then went for a cruise around town and then ran out of gas.
![]() I forgot how much I love driving my old trucks. Theres just somthing about that Old truck smell, gear noise and clicking lifters that gives me a warm fuzzy feeling and puts a huge smile on my face. ![]()
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
