03-09-2016, 11:43 PM | #2901 |
Post Whore
Re: Restoring Rusty
more shots of the Vortec cylinder heads
03-09-2016, 11:45 PM | #2902 |
Post Whore
Re: Restoring Rusty
alright Greg, I think we get what cylinder heads look like, ha ha
03-09-2016, 11:46 PM | #2903 |
Post Whore
Re: Restoring Rusty
dude seriously? more pics of these stupid heads
I also took the Head Bolts since I did not know if they were going to be different kind then my old ones, I had to pay for these, they charged me $5.00 bucks total for all of them I realize you are supposed to use new head bolts as they supposedly stretch, but hey this is a budget build, and I aint made of money, so I hope to clean these up real good and use new goop of some kind on them Last edited by Gregski; 03-10-2016 at 12:14 AM. |
03-09-2016, 11:51 PM | #2904 |
Post Whore
Re: Restoring Rusty - Vortec Valve Covers
I also took the valve covers GM part number 12355350 off of the same vehicle since the Vortec heads use center bolt valve covers not the old style with bolts around the edges, and yes I also took the valve cover bolts, I showed them to the guy and he said I could just take em fer FREE (hey man, this stuff adds up real quick)
cost $21.00 other than the 5 foot filler neck on one of them I think they might could work out shoot, I think you saw these when I showed you the bath of parts, oh well Last edited by Gregski; 03-10-2016 at 12:01 AM. |
03-10-2016, 12:04 AM | #2905 |
Re: Restoring Rusty
if you unscrew the 5 foot filler the cap should screw right in to the cover
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
03-10-2016, 12:15 AM | #2906 |
Post Whore
Re: Restoring Rusty
03-10-2016, 12:28 AM | #2907 |
Re: Restoring Rusty
03-10-2016, 08:22 PM | #2908 |
Post Whore
Re: Restoring Rusty - New Water Pump
time to think outside the box
ah si, pompa de agua esta aqui strictly optional and won't count against our top end upgrade bottom line, but I must say I bought this $111.00 dollar GM part number 88894341 water pump for $44.99 on eBay with FREE shipping. It is a ZZ4 engine take off, and has never seen water, happy dayz |
03-10-2016, 08:26 PM | #2909 |
Post Whore
Re: Restoring Rusty
speaking of those Vortec cylinder heads, we subject them to the same precision leaky valve testing as the old ones, we do not discriminate people, I don't care what your chamber size or shape is - I'm looking at you Hemi
and I'm pleased to report these were air [ahem] gas tight |
03-10-2016, 08:30 PM | #2910 |
Post Whore
Re: Restoring Rusty
then it was time to show 'em some Wire Wheel Love - WWL
03-10-2016, 08:31 PM | #2911 |
Post Whore
Re: Restoring Rusty
one side done, on to the other side
I think it turned out great, check out the difference |
03-10-2016, 08:37 PM | #2912 |
Re: Restoring Rusty
Gregski, you have done well saving money by finding some truly great deals for your budget build but, I gotta ask, why did you pay so much for pushrods?
You could have saved over $100 for an example similar to this: http://www.summitracing.com/parts/hrs-95205/overview/ They are nice pieces for the money and plenty durable for your application. |
03-10-2016, 08:38 PM | #2913 |
Re: Restoring Rusty
I hope you plan to port match the heads and intake :P Go big or go home sir.
03-10-2016, 08:57 PM | #2914 | |
Moderator
Re: Restoring Rusty
If you re-use TTY bolts you'll end up with broken head bolts and/or leaking head gaskets just like the 1970's & 1980's Oldsmobile and VW Diesels. The damper is probably OK but if the ring looks cracked or pushed unevenly out of the slot you need to replace it. I replaced the dampers on my Diesels with Fluidampers but smallblocks dont beat the snot out of a damper like the 6.xL AMG engines.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-10-2016 at 09:03 PM. |
03-10-2016, 09:07 PM | #2915 | |
Post Whore
Re: Restoring Rusty
03-10-2016, 09:08 PM | #2916 |
Post Whore
Re: Restoring Rusty
03-10-2016, 09:44 PM | #2917 |
Re: Restoring Rusty
03-10-2016, 10:01 PM | #2918 |
Re: Restoring Rusty
Go Greg go!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-10-2016, 11:44 PM | #2919 |
Post Whore
Re: Restoring Rusty - Valve Spring Remover
for the life of me I don't remember what I did with my valve spring remover, I know I had one, so off to Harbor Freight we went, I don't know about your but I struggle with buying expensive single purpose tools, so $13 bucks plus the 20% off coupon you find in every car rag
so little about this tool, out of the box it sucks, it is very consistent in slipping off the springs in its current configuration, so step 1 is to modify it, you kneed to curl up or in the jaws that grab the spring, in my case I used a hammer to bend them in a little bit buttom pic is before modification, you can see the straight claws and how easily they would slip out |
03-10-2016, 11:50 PM | #2920 |
Post Whore
Re: Restoring Rusty
well it was raining out, poring actually so as much as I wanted to take the heads outside to play with them, I couldn't, but I had to do something, you know the feeling
so it was time to test drive that brand new shinny valve spring compressor remover thingie first I show you how bad it sucked no matter what I did in its virgin form |
03-10-2016, 11:52 PM | #2921 |
Post Whore
Re: Restoring Rusty
once I modified it so that it would actually not slip off the spring, I quickly learned that one must grab more than 3 coils of the spring cause that's not enuff to git the retainers out
03-10-2016, 11:54 PM | #2922 |
Post Whore
Re: Restoring Rusty
once we modified the tool, and reached out for more coils, well now we were cooking with propane
i used some needle nose pliers and a small flat screw driver to gently wiggle the retainers out |
03-10-2016, 11:57 PM | #2923 |
Post Whore
Re: Restoring Rusty
so lets seal the deal shall we, I am so glad I was talked into replacing the valve seals, I have never done that before, but let me tell you they were passed it
plus I had to use the vice grips to pull them off, and that pretty much sealed the deal that they aint going back on, all ovalized now and such so one big reason why I just had to take a peak at those seals is that the Engine Specs called for two separate part numbers for new valve seals 10212810 - Intake (Valve Stem Seal Type: Umbrella, Valve Stem Diameter 0.344 in., Valve Guide Diameter (in): 0.500 in.) 12564852 - Exhaust (Specs unknown) have any of you heard of this, can anyone comment please, to me they both look the same Last edited by Gregski; 03-11-2016 at 12:02 AM. |
03-11-2016, 12:04 AM | #2924 |
Post Whore
Re: Restoring Rusty
lets just take a quick look at the #8 Exhaust Valve itself
I see a wire wheel clean up in its future Beautiful Margin and a Face only a mother could love! The Russian Judge gives it a Score of: 2.8 Last edited by Gregski; 03-13-2016 at 01:53 AM. |
03-11-2016, 12:16 AM | #2925 |
Post Whore
Re: Restoring Rusty
and a quick looksie at his big brother the #8 Intake Valve
we shall clean him up too and see what lurkes beneath that black carbon cloak, what are you trying to hide Mr. Last edited by Gregski; 03-13-2016 at 01:53 AM. |
