#276 |
Re: 72 2wd Blazer: Project "Break Me"
#277 |
Good build. Are the rear bags supposed to be helpers, or will you run those and triangulated four link? If you do the four link, consider slam RE8's. They run about $70 per bag, have 8.5" bellows, only require 120psi to be fully extended, and are a whole lot smoother ride.
#278 | |
#279 | |
Kevin LFD Inc. |
#280 | |
![]() Join Date: Apr 2004
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#281 | |
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
#282 |
![]() Join Date: Aug 2005
Making over 400hp is getting played too...
#283 |
#284 |
I like it don't get me wrong but I like it better on another persons ride. I want to be low and that is where I am at so why bother?
#285 |
#286 |
I think the same way. I drive it/keep it low all the time & don't care for the 'frame on the ground' @ the fairgrounds trend. But (another one of those).... air sure is nice when it comes to changing tires or getting a jack underneath the vehicle.
#287 |
A guy with a truck
...and coilovers are a whole ****-ton cheaper than Shockwaves...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#288 |
#289 |
So, to piss all you floks off that think I should have bougt a truck here it is with 1.5" out of the front and 1" out of the back
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by jkade; 10-26-2008 at 06:22 PM. |
#290 |
A guy with a truck
Looks just right to me
#291 |
#292 |
I also got me a front tire for mock up on the 18x10's which is a 255/40/18. That tire is 10.2" wide and has worlds of clearence.
#293 |
That's all that matters then. I think it looks cool, too. I probably won't do it to my Blazer since I want to keep the back seat, but then again, I tend to change my mind a lot.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#294 |
#295 |
looks good.
#296 |
![]() Join Date: Apr 2005
Neat concept, excellent execution,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#297 |
PITbut
#298 |
Looks fantastic! Allot of people are not going to know just what all was done to that "truck" and that will be the fun part.
Couple of questions for you. 1) by laying back the windshield, squeezing the A pillars in and not widening the top do you think you will have a problem getting glass to fit in their right? What are you plans for going about this? 2) It looks like you had to cut the B pillar area to align with the door and the squeezed A pillars so do you now need to change out the window tracks so they are also in line? I am probably thinking way to much into this but I can't help my self. You got me thinking ![]() Kevin LFD Inc. |
#299 | |
Nice placement of the front tire centerline by the way. Kevin LFD Inc. |
#300 |
PITbut
