Old 08-12-2009, 11:41 PM   #276
shrunken66stroker
shrunken66stroker's Avatar
Re: Shrunken66Stroker's build thread.
Originally Posted by BIGMAC68 View Post
This part has been recently re-designed to match the original bracket.
Good to know. You can see in the picture from the circular marks that the bolt head overhung the edge of the mount. The first time I saw that I knew something wasn't right.I bought mine and had them sitting around for a few months. I'm sure they'll work fine. The tailgate will be closed 99% of the time anyways so who give a $hit really, right.
shrunken66stroker is offline   Reply With Quote
Old 08-13-2009, 06:46 PM   #277
protrash64
Resistance is Futile
protrash64's Avatar
My bed is 1/2 '62 and 1/2 '66......the earlier hardware was bolted and later it was spot welded. My theory is cost reduction during the production run. Other differences include a lot of metal that was eliminated as time passed.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-19-2009, 11:38 AM   #278
61TWUK
61TWUK's Avatar
any update on this build? I love your truck...
61TWUK is offline   Reply With Quote
Old 08-19-2009, 12:12 PM   #279
daverod
SSN 706
daverod's Avatar
He's busy cutting his truck up.
daverod is offline   Reply With Quote
Old 08-20-2009, 12:01 AM   #280
shrunken66stroker
Thanks dude. Between the two kids under 3 and work, I've been really busy. I also have a 61 MGA that I'm restoring for someone and that's eating up my garage time from the truck. I have been doing a few things though. I took the front end off, fit the new hydraulic clutch master, brake booster master and filled some holes on the firewall. I got a gas tank from a guy who said it's a blazer tank of an unknown year. Maybe someone who reads this can identify it but I don't think it's going between the back cross members without some heavy modification. He said he thought it was from an 80 or 81 blazer. The thing is gigantic, it's like 26x26. I'll have to hack seven inches out of it to get it to fit up in there. The price was right, so I thought I'd give it a shot.
Next I think I'm going to raise my bed floor up a few inches. With the air out of the shocks the differential pushes up on the bottom of the floor and bows the wood. I don't have the money to buy a wood kit so I'm stalled out on that for now. After the bed floor is done I'll blow it apart and paint the frame. I'll prime the whole thing while it's apart and then put it back together. I'm thinking of driving it in primer for a while to make sure there aren't any more modifications that I want to do before paint. It's nice sometimes to slow down and just look at it to make sure everything is like you like it before moving forward.
Old 08-20-2009, 12:04 AM   #281
Joemomma1
Joemomma1's Avatar
Thats a blazer tank. What type of steelies are those?
Joemomma1 is offline   Reply With Quote
Old 08-20-2009, 12:28 AM   #282
shrunken66stroker
I thought so but is there a thread somewhere that you know of that deals with the modifications to jam it up in the frame rails that are 19" wide?
The rims aren't steelies. They're 17" cragar 397s.
Old 08-20-2009, 12:31 AM   #283
Frizzle Fry
Frizzle Fry's Avatar
This might help.
Frizzle Fry is offline   Reply With Quote
Old 08-20-2009, 12:33 AM   #284
SCOTI
SCOTI's Avatar
Check out Rokcrln's threads. He did a late-model blazer tank install on his LowBuk build IIRC.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-20-2009, 12:39 AM   #285
Joemomma1
Joemomma1's Avatar
Well, I am putting the same tank in my 66 swb truck. You need to remove the last crossmember in order to make it fit. I am not happy w/ the idea of less support back there so Im going to weld a piece of steel right behind the tank going to both frame rails. Cragar 397s huh? Love em. Might have to invest in those. 17s look perfect, get those 20s outta here!
Old 08-20-2009, 12:46 AM   #286
shrunken66stroker
Wow, I have to take out the last cross member? I didn't know that. I thought I only had to take out the little one that's 18" from the end. Like you I'll have to weld or bolt in some kind of support. Make sure you post it when you do it so I can get a good look at it. I'll do the same if I get around to it.
Check back on page 8. There's a pic of my truck aired out. I think the proportions are nice with 17's.
Old 08-20-2009, 12:50 AM   #287
shrunken66stroker
Originally Posted by Frizzle Fry View Post
Thanks Frizzle. I've seen that before, I think. I guess I just never realized I have to take out the furthest rear cross member. I'll make it work. Where's a good place to get replacement sending unit? How many gallons is it?
Old 08-20-2009, 12:58 AM   #288
Joemomma1
Joemomma1's Avatar
Im still sorta working it out, what type of straps and how low. I also didnt want to have to remove the bed in order to remove the tank. I spot welded some nuts on the inside of the rails. You will not be able to get you hands in there once its installed. I can now just remove the bolts and drop it. I will post up some pics. Your also gonna have to notch one of the cross supports on your bed as well, how much depends on how low you hang it.
Old 08-20-2009, 01:08 AM   #289
shrunken66stroker
Im still sorta working it out, what type of straps and how low. I also didnt want to have to remove the bed in order to remove the tank. I spot welded some nuts on the inside of the rails. You will not be able to get you hands in there once its installed. I can now just remove the screws and drop it. I will post up some pics. Your also gonna have to notch one of the cross supports on your bed as well, how much depends on how low you hang it.
I'm raising my bed floor up a few inches and I want that SOB tucked up tight. I'm also having the roll pan/rear bumper debate with myself at the moment. I have a roll pan already that's been sitting in my garage for about 8 months. I still can't decide if I'm going to use it but if I do, I want the gas tank to tuck up behind it completely. I need to get straps to hold it up too. Any suggestions?
Old 08-20-2009, 01:09 AM   #290
Joemomma1
Joemomma1's Avatar
Thats where it stands now. I ran across some diamond plate straps and put those on. Im not sure I want to use aluminum instead of harder steel. The skid plate is a whole differnent animal I have yet to confront.
Old 08-20-2009, 01:14 AM   #291
Joemomma1
Joemomma1's Avatar
I put the bed on to see where I needed to cut. THAT BABY HANGS LOW! I think the bumper will cover majority of it but Im sure some if it will be seen. You can also run it in between the rails instead of below like I did to push it higher.
Old 08-20-2009, 01:18 AM   #292
Joemomma1
Joemomma1's Avatar
Thats the only pic I have right now, I will post up more tomorrow. Side and ground clearance.
Old 08-20-2009, 07:53 AM   #293
daverod
SSN 706
daverod's Avatar
The first tank I tried looked like the one you have. It's to big on the top half. They make another one thats smaller on top it's about 1" wider so you have to trim thing alittle but height wise it fits a lot better. The one I used came from a 80's van.Your right you won't use that roll pan you can just send it to me I can use it on my 64 it has a big old farmers bumper on it.
Old 08-20-2009, 07:55 AM   #294
daverod
SSN 706
daverod's Avatar
I see you still have your drip edge. Thats good.
Old 08-20-2009, 10:51 AM   #295
shrunken66stroker
The roll pan will go on at some point but I don't want it to be completely smooth back there so I'll probably leave the seams....maybe. I'm not committal on the drip rail. I'm with you, I'll wait to see how the rail on Dennis' truck comes out first.b The tank will end up working after I raise my bed floor a few inches.
Old 08-20-2009, 10:55 AM   #296
Dinos63
chevy only
Dinos63's Avatar
DUUDE THATS ALOT OF BARE METAL
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-20-2009, 11:53 AM   #297
shrunken66stroker
It makes me a little nervous. It will all be primer soon... hopefully soon.
Old 08-20-2009, 12:30 PM   #298
Frizzle Fry
IIRC They are 21 Gal. I was going for low buck on that one and didn't want to spend $100 on a new Blazer sending-unit (4x what I paid for the tank). So I welded in the flange from the truck tank and bent the truck sending-unit float arm and pickup to work in the Blazer tank. Worked great!
Old 08-20-2009, 02:52 PM   #299
Strodder
Daring to be Different
Strodder's Avatar
Yeah, but living in Vegas it can sit for a while without rusting. Like here. Just don't was it. Oh I forgot it's against the law to wash your car in Vegas. Unless you do it with a pressure washer.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-20-2009, 11:34 PM   #300
shrunken66stroker
Still makes me a little nervous. I have just a few more things to do before painting the frame and priming the whole truck. I see the light at the end of the bare metal tunnel.
1966, bagged, disc, long to short, stroker
