12-22-2013, 02:19 PM | #276 |
A day late and $1 short...
Re: Project: NO-LIFE,...
But would you trade it?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
12-22-2013, 02:28 PM | #277 |
67-72 parts collector,…
Ha.
No. I would like to have your white swb, in addition to this one,...
12-22-2013, 02:41 PM | #278 |
You and your "In addition to..."
12-24-2013, 12:55 PM | #279 | |
Page 2, Post 31 there is a picture of your lower control arm ground clearance with the 2.5" drop spindle and 3" drop spring, roughly how much ground clearance do you have with this setup at the lowest point of the control arm and lowest point of the front crossmember? Thank you in advance.
You remember when drinking too many beers was a bad idea? Me neither. |
12-24-2013, 01:06 PM | #280 | |
This is with a fairly short 215/70-15 front tire. This is the downfall of these trucks when you lower them. The crossmember hangs down too low. That's why the Porterbuilt Dropmembers have been so successful. Not only do they lay out,... but they increase ground clearance!
02-24-2015, 02:52 PM | #281 |
Did you put the super trac mount closest to the rear end saddle or the control arm. I'm doing the same thing and not sure if it should go on top of the lowering block or the bottom.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
02-24-2015, 03:04 PM | #282 |
You want the bar level to the ground @ ride height. Position the bracket which ever way gets it closest to being level (which is going to depend on the ride height of your truck).
02-24-2015, 03:14 PM | #283 |
Scoti is correct.
But I think I have my track bar under my lowering block on this truck. That's where ECE puts the bracket. On top of the trailing arm. On top of the block will make the track bar more horizontal with a 6" drop spring.
02-24-2015, 04:11 PM | #284 |
I have 6" drop and 1.5" block. I'll start with it on top of the block.
02-24-2015, 06:16 PM | #285 | |
Raise the bar until it's level & see where it's closest to. Install truck arm bracket accordingly.
02-24-2015, 08:41 PM | #286 |
Still love this truck
///Relaxed Atmosphere |
03-03-2015, 10:17 PM | #287 |
Are your front springs loose when you jack the front end of your truck up? With the drop I have 2" modular spindles and 3 inch springs I don't think the bump stop on the upper control arm will be tall enough to keep the spring tight. Thinking of making my own. Have you seen anyone do this Keith? Coming to Des Moines this year?
03-03-2015, 10:26 PM | #288 | |
I'm sure mine are loose in the pocket like all 3" drop springs. It's been a long time since I even looked at my truck. I would think you could make a set of energy suspension bumpstops work. Either cut down a tall set or make a spacer for a short bumpstop. Probably won't be at Des Moines this year.
05-14-2015, 02:54 AM | #289 |
Cool truck. Thanks for sharing.
05-20-2015, 02:11 PM | #290 |
Where did you get this tool?
05-20-2015, 02:54 PM | #291 |
Grainger & Fastenal both carry them. You can also use a piece of allthread, nuts, washers, & 2 wrenches.
05-20-2015, 02:57 PM | #292 |
So, just buy the nutserts or rivnuts from them and then use the hardware you suggested. Sounds reasonable.
05-20-2015, 03:51 PM | #293 |
I think I got mine from Fastenal,...
05-20-2015, 04:19 PM | #294 |
I've used the tools but when I went to buy my own found they were pricy for the top end models. IMO, the cheaper ones were cumbersome to operate after about the 3rd nut pressed into place. The allthread & hardware were much easier when installing in quantity.
05-22-2015, 08:43 AM | #295 |
Where are you installing nutserts?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-22-2015, 09:49 AM | #296 |
Same place he did, high hump.
12-07-2015, 02:48 PM | #297 |
Junior Member
I saw her on face book loaded up and headed to see n2billet along with the blazer?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
12-07-2015, 03:03 PM | #298 | |
n2billet owns my red '69 now. The blazer is still mine. I have too many projects and no desire to work on trucks. Life changes and you move on.
12-07-2015, 03:16 PM | #299 | |
Still Learning
I totally understand you not wanting to work on these old trucks. I know you will always be driving one of them though..... |
12-07-2015, 03:30 PM | #300 |
Junior Member
I figured the red one was paying for the other. I am sure the blazer will be awesome.
