09-10-2009, 07:52 AM | #276 |
Re: Intro from an old Assembly Plant guy
Ok - so here's the point where you find out they are not "exactly" the same....apparently the transfer case shift lever is "coarse" thread and the transmission shift lever is "fine" thread Nothing that a couple minutes with a 7/16 fine thread tap couldn't fix:
And here we are, back in business: Total time investment: about 15 minutes; dollar investment of about $3.00 (for shipping). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-19-2018 at 10:53 AM. |
09-10-2009, 07:59 AM | #277 |
I guess that's not entirely true: I noticed the engine seemed to run "too cool", that is, the needle on the temp gage wouldn't come up to the first mark. Probably running about 140 degrees, and I was concerned that wasn't warm enough to burn all the condensate out of the motor oil plus - with winter coming - I'm going to want some heat in the cab!
So I did replace the thermostat with a new 180 deg stat; that seemed to help, as the needle is now coming up to the first mark on the gage. I'm wondering if that earlier stat (marked as a 180) had some problems. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-10-2009 at 08:00 AM. |
09-10-2009, 08:02 AM | #278 |
Great intro/thread. Rep point given!
09-10-2009, 12:02 PM | #279 | |
My Truck's not leaking its marking its territory! |
09-10-2009, 12:04 PM | #280 | |
Thanks; I hadn't heard that. I will check it out (...although I have some degree of confidence it may have been the thermostat since changing it seems to have made a difference). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-12-2009, 08:37 AM | #281 |
As I recall from HS physics, as an electrical component rises in temp, its' electrical resistance increases.
09-12-2009, 09:41 AM | #282 | |
a positive temperature coefficient is as you described, temperature rises=resistance rises (examples include: incandescent bulbs and motor windings) a negative temperature coefficient is just the opposite, temperature rises=resistance falls (examples include: thermistors and semi-conductors) I am not sure if the temperature coefficient of a sending unit is positive or negative though....
CHEVY ONLY Last edited by joe231; 09-12-2009 at 09:43 AM. |
09-14-2009, 07:12 AM | #283 |
9/12 & 9/13 2009 Edition:
1) Finished the door opening on the driver's side (paint, added the new weatherstrip and door sill plate) 2) Painted the pickup box (it's about 98% done; pics to come later) 3) Started on the inside of the doors:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-19-2018 at 10:54 AM. |
09-14-2009, 08:36 AM | #284 |
great southern land
lookin good
rod 86 chevy c10 silverado |
09-14-2009, 05:17 PM | #285 |
Keith:
Where did you pickup the vinyl floor covering? I've always liked it better than carpeting...as long as there was a good thick mat installed beneath. |
09-15-2009, 11:58 AM | #286 | |
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) Captkaos Customs 73-87chevytrucks.com It's a good, thick vinyl and comes with the "shoddy" insulation that goes underneath.
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-15-2009 at 11:59 AM. |
09-15-2009, 12:01 PM | #287 |
These are the inserts that go in the door trim panels. This is the same technique I used for the dash panel insert, discussed previously:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-19-2018 at 10:55 AM. |
09-15-2009, 12:02 PM | #288 |
Some people have a "green thumb"; I have a "gray" thumb!
(lol)
09-15-2009, 12:29 PM | #289 |
ive been known to have one of those myself!
looks great keith! almost done!! what will be next after the doors??
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
09-15-2009, 02:18 PM | #290 | |
(lol) Then I'll just drive it!! K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-15-2009 at 02:23 PM. |
09-15-2009, 02:33 PM | #291 |
You think you'll be done.
Looks good man, and you will have time to enjoy it before winter comes. |
09-15-2009, 03:42 PM | #292 |
No, no - I have to be done. I've got other stuff I'm supposed to be working on!
Seriously, I had one project one time that was actually DONE. I redid a Farmall tractor and once it was refurbished I never had to work on it again. It was a very cool feeling (...very different from having a race car. Race cars are never done...):
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-19-2018 at 10:56 AM. |
09-15-2009, 04:00 PM | #293 |
Project Optimus Prime
I have a 84" C-10 swb that was built in flint!!!! man ur story is soooo cool!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
84 SWB work in progress 89 burb 1500 (parts pig) LOL 08 ford focus (I know, I know) Wifes car "I said it b4 and i'll say it agian wiring is my worst enemy":devil: |
09-15-2009, 04:19 PM | #294 |
That's a cool tractor. Do you still have it? If so that would be a sweet photo with your swb pulling your tractor.
09-16-2009, 07:48 AM | #295 | ||
I said "...you'll have to be more specific about which 'broken tractor' you are talking about!"
09-16-2009, 08:39 AM | #296 |
09-16-2009, 12:28 PM | #297 |
Its blue i would post pics but i dont know how 2 resize that pics 2 post them?????????
09-16-2009, 12:51 PM | #298 | |
I guess I need to go back and find the previously discussed, discussion
CHEVY ONLY |
09-16-2009, 02:19 PM | #299 | |
I was teasin'....we built about three and a half million trucks during the 7 years that I was there. It's unlikely I would remember it (unless it was one that got dropped, or smashed or something...)
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-16-2009 at 02:21 PM. |
09-16-2009, 02:24 PM | #300 | |
