12-18-2019, 06:17 PM | #276 |
Equal opportunity joke ofender
Re: My 1st 68 panel
A few more shots
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
12-18-2019, 06:21 PM | #277 |
Re: My 1st 68 panel
Also got the rest of the rusted/butchered inner cowl metal cut out
12-22-2019, 03:04 AM | #278 |
Re: My 1st 68 panel
Looking good sir!!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
12-28-2019, 02:03 PM | #279 |
Re: My 1st 68 panel
And this is why I can't get any work done. Things keep following me home. I really need to sell this trailer to limit my bring home capacity
12-28-2019, 02:09 PM | #280 |
Re: My 1st 68 panel
2 Short beds
Are these projects or parts trucks? Keep on Trucking .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
12-28-2019, 02:33 PM | #281 |
Re: My 1st 68 panel
Got enough projects I will begin going thru them for parts soon.
12-28-2019, 02:44 PM | #282 |
Re: My 1st 68 panel
Good to see you are feeling better.
12-28-2019, 06:51 PM | #283 |
Re: My 1st 68 panel
Thanks I did finally figure out that it was the vine that I cut on Monday that was poisonous. Not sure if it was ivy or oak but it was potent. Still swelled up some but it is going down. Gonna try to work on the panel some more over next couple of days
12-29-2019, 01:21 AM | #284 |
The Older Generation
Re: My 1st 68 panel
As my wife would say, " you're worse than a dog dragging s#!t home".... Good finds anyway. I am highly allergic to Ivy and Oak. If I don't get a shot in short order, I will end up in the hospital. LockDoc
12-29-2019, 03:47 PM | #285 |
Re: My 1st 68 panel
Looking good Richard. You are making some good progress!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
12-29-2019, 04:53 PM | #286 | |
Re: My 1st 68 panel
Thanks Paul not quite as far along as you though. I have been fighting this lower inner A pillar cover on the passenger side. It is not even close. The driver side one seems to be pretty spot on though. .
12-30-2019, 01:23 PM | #287 |
Re: My 1st 68 panel
Richard, your worse then a dog draggin sh!t home, gotta remember that one, as my son has too many trailers. He just brought home a trailer with a truck bed camper mounted on it, and a space on the back for his Jeep to haul that to the 4x4 campground
Anyway, subs looking good, can you pull back alittle on the pic of the side panel, hard for me to see the oreintation still have that heater box for you, I'll try to get some pics up, busy working on my truck
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-30-2019, 04:11 PM | #288 |
Re: My 1st 68 panel
Jim
It is the nature of the beast. Here are some pics of the drivers side. It lines up pretty good . This last pic I moved the lower inner forward flush with the firewall/floor pan joint and you can see better the gap or shortage of metal at the A pillar
12-31-2019, 10:43 AM | #289 |
Re: My 1st 68 panel
You may have to buy two of those pieces to splice it together, although I cant imagine why. I didnt have that problem on either side of the 'A' pillar DS or PS
12-31-2019, 10:49 AM | #290 |
Re: My 1st 68 panel
OK, I see what I did, I moved it down to get the lenght right, just remade the bottom and reflanged the seam where the weather strip go. I you need the flanging tool let me know and I will ship it out
I'd show yuo a pic but it is downright fugly
12-31-2019, 12:05 PM | #291 |
Re: My 1st 68 panel
Jim,
Since I have to replace them both all the way up under the dash, I bought these more for patterns anyway since I had nothing to go by. I am just going to split it apart to get the width right then transfer it to some 18 gauge sheet I have here and "hopefully" make a one pc panel for both sides. I am hoping to be able to use the bead roller I just got from Eastwood to do this since it came with tipping wheels. Since I am a beginner with it, I would imagine I will mess up quite a few pcs before I get it worked out. I spent all day yesterday replacing the water heater at the office. Things that should only take an hour or two seem to last me all day sometimes
01-02-2020, 10:00 AM | #292 |
Re: My 1st 68 panel
A whole lot of put it in...take it out ....put it back in.....take it out but finally got the DS inner area almost buttoned up. Still have to finish the very bottom pc inside but will wait on that until I get the rust converter put up in there. It is all fitted and ready to go. ALso got the DS lower A pillar replaced. All told I probably have put the new outer cowl on a couple dozen times while fitting the inner pcs on the driver side to make sure I kept my alignments correct.
01-02-2020, 10:04 AM | #293 |
Re: My 1st 68 panel
couple more pics. Hoping to have this whole area buttoned up by the end of the weekend but who knows
01-02-2020, 10:59 AM | #294 |
Proprietor of Dale's Corner
Re: My 1st 68 panel
Looks great!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-02-2020, 12:06 PM | #295 |
Re: My 1st 68 panel
Wow, that looks like a lot of work to me. I'm looking at a '72 Suburban a few miles from me but I will look it over extra good, if it is that bad I think I will pass on it. I know the Panels are harder to find than the Suburbans but I would have to give that a lot of thought. You are doing some Great work though. LockDoc
01-02-2020, 12:28 PM | #296 | |
Re: My 1st 68 panel
Thanks Dale
Today I am trying my luck remaking the passenger side inner foot pillar to the correct width. I also need to get my doors out of storage so I can make sure seams are lining up close enough to button up the floor. .
01-02-2020, 01:13 PM | #297 | |
Re: My 1st 68 panel
Woody |
01-02-2020, 06:54 PM | #298 | |
Re: My 1st 68 panel
Did not get one thing accomplished on it today. Ended up spending most of the day taking the boiler apart at the house and getting it cleaned up. Got a text this morning they woke up to black smoke starting to come in the house from furnace room. It was totally my fault. I did not clean the fire box chamber out before the season started and the fingers are so close the soot builds up bad enough over the course of a year or two that it will clog up and push smoke into the house. Luckily the shop is right next door to the house so I beat feet and got it all shut down and fanned out before it got in the house too bad. I have had several people out over the years trying to get it so that it burns cleaner but have been told this boiler is bad for it either way.Hope to get back on this tomorrow afternoon but have to go across state early in the morning to work on a sign. After that is done I am going to look at a 71 suburban parts truck that I was given a lead on. Thanks for following along
01-02-2020, 07:01 PM | #299 |
BlahBlahBlah
Re: My 1st 68 panel
Dang man, you are plugging right along. Looking great!
01-04-2020, 06:24 PM | #300 | |
Post Whore
Re: My 1st 68 panel
This thread is my first stop when I check back here. Between Richard and NZBurb's adventure thread these are exciting times here on the Burban Booard!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
