Old 12-09-2012, 11:20 PM   #276
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project "Just an Old Truck"
Thanks brother, I appreciate the good words! Now about that parachute...
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-09-2012, 11:25 PM   #277
Rusbuilt
Rusbuilt's Avatar
Haha! It could be all yours... If I really had it!
Rusbuilt is offline   Reply With Quote
Old 12-10-2012, 01:05 AM   #278
gringoloco
A guy with a truck
gringoloco's Avatar
Can't remember; did you do the trailing arm flip on this one? That will help correct pinion angle, too. Wheels are gonna look good!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-10-2012, 10:42 AM   #279
shawno72
C/10 junkie
shawno72's Avatar
I think your truck is gonna look great with those wheels!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-10-2012, 11:05 AM   #280
Portmod7
Portmod7's Avatar
That is why you are a guru!
In all seriousness, I appreciate your willingness to offer assistance and answer questions all the research you do. Rob (Hart_Rod) and I were talking last night about the quality of board members and the importance of guys like you, Scoti, STP67-72, hot trux, N2Trux, n2billet, havinsomefun, 67cheby, portmod7, and grigoloco (to name a few that have helped me) maintaining its integrity. I hope I can repay the deeds to those, like you, who pay it forward.
On another note, I graduated High School across the river from St. Louis and will be up that way next August, if it's not too far maybe we can meet up and do a little bench racing.
Daaaang, I made the list! Not sure I deserve that, but thank you!
I agree 100%. This board is full of great people who are very helpful. If I need to know something, 99% of the time I can search this site and find it. If it's not there, you can ask a question and usually have it answered the same day. Pretty cool little online community that's been established here. Not to mention some of the very high profile trucks that have their builds posted here. Pretty cool.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 12-10-2012, 12:01 PM   #281
67cheby
67cheby
67cheby's Avatar
very nice work on the trans crossmember
67cheby is offline   Reply With Quote
Old 12-10-2012, 12:31 PM   #282
C10_ustacould
When I started the tail shaft was 5° down and the pinion was 0° (neutral), and the output shaft and the pinion gear were the same height from the ground. Right now I will have to estimate how much raising the tail shaft corrected the downward angle at the tail shaft, but lets say it is now 3° down. Having moved the tailshaft up 1" the output shaft should be 1" above the pinion gear, which opens the possibility of increasing the pinion angle (up). I have a choice here, I can install the 3.5° shims I borrowed from Hart_Rod or flip the trailing arm brackets. The shims are the easiest, and could provide a good test but depending on how many degrees it changes the pinion angle, moving the trailing arm bracket might be the better permanent fix. Does anyone know how many degrees the pinion angle changes by flipping the brackets? The other possible advantage to moving the brackets might help with is centering the wheel in the wheel well. So, I am going to try the shims next and then the flip if the shim help eliminate vibration. I will try and get numbers at each step so that we will know how the flip affects the pinion angle.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-10-2012, 12:38 PM   #283
C10_ustacould
There are many more, I just didn't have time to name everyone. Many times it's not answering a question directly, it's having taken the time to document projects throughly or creating a new way to fix or modify something. And sometimes it's just a "hey bro your truck is looking good!" that keeps people motivated. Good bunch of folks started this forum and guide it each day, we noobs must conduct ourselves in ways that perpetuate this helpful culture! I really enjoy my truck, and I enjoy the time I spend here on the board almost as much!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-10-2012, 04:02 PM   #284
72BlckButy
Tot Roddin'
72BlckButy's Avatar
And I'm just 20-25 from his 90.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-10-2012, 10:19 PM   #285
C10_ustacould
Wheels got here today! But the rears don't fit... wrong backspace. Seems like the website that says they make a 5" bs is wrong so I was sent 5.5"bs. I am working with the guys at Old School Wheel on a fix. The fix (spacers) will be temporary until I build the longer rear end I have. Crappy pics in the garage...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-10-2012, 10:28 PM   #286
lolife99
67-72 parts collector,…
lolife99's Avatar
Wheels look good.
Sorry about Coys shipping out the wrong BS.
Keith
Convert to disc brakes.
Old 12-10-2012, 10:29 PM   #287
Rusbuilt
Rusbuilt's Avatar
Yessss!!!!!! So nice!
Old 12-10-2012, 10:32 PM   #288
Portmod7
Portmod7's Avatar
That's a bummer about the rears, but it still looks awesome!
Got any info on plugging the tank filler hole in the cab? That's on my to-do list...
Old 12-10-2012, 10:34 PM   #289
Justin36
Justin36's Avatar
Looks great! So you are driving out to St.Louis?
Justin
Justin36 is offline   Reply With Quote
Old 12-10-2012, 10:46 PM   #290
sourkraut
sourkraut's Avatar
Ran thru your build might have missed it but whose fuel tank did you use? considering moving mine under the bed too.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 12-10-2012, 10:50 PM   #291
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Love it!
-Nate
Old 12-10-2012, 11:10 PM   #292
C10_ustacould
Wheels look good.
I appreciate your restraint as I know you have more to say...
Thanks!
Thanks, Hope to next summer...
I used a Boyd Welding tank, good product and very nice people.
Originally Posted by 72BlckButy View Post
Love it!
Thanks, I wasn't sure how I'd like them but I knew I wanted to do something different. And, besides the fact that they don't fit, I love them too!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-10-2012, 11:35 PM   #293
Justin36
Justin36's Avatar
Can't wait to see it backed out in the open!
Justin
Old 12-11-2012, 12:14 AM   #294
Bennett68C10
Bennett68C10's Avatar
Wheels look great on your truck, sorry to hear about the bs mistake. Can't say I'm shocked, they did the same thing to me and told me to run a spacer if it bothered me. Eventhough their customer service sucks they do have some very nice wheels as seen on your truck.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-11-2012, 01:05 AM   #295
C10_ustacould
As soon as the tires aren't pinned against the bed sides!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-12-2012, 12:06 AM   #296
C10_ustacould
With the help of some spacers I borrowed from Hart_Rod I was able to get the wheels off of the bed sides. I don't want to run spacers permanently, and I really like these wheels so I am going to start collecting parts to rebuild the 70-72 rear end I have sitting in the corner. The one thing that swapping the rear end won't fix is the placement of the wheel in the wheel well. Since I lowered it the rear wheels are too far back in the opening. Does anyone know if flipping the trailing arm brackets will correct this? Please let me know if you have any info on this. Measurement pics I took...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-12-2012, 12:44 AM   #297
C10_ustacould
Pics... Gonna have to do something about the drums and the exhaust, whew that is UGLY!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-12-2012, 07:56 AM   #298
shawno72
C/10 junkie
shawno72's Avatar
Wheels look great. Big wheels = big view
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-12-2012, 08:31 AM   #299
lolife99
lolife99's Avatar
I wonder if you could run a Porterbuilt tubular trailing arm crossmember,... and position it 1" forward?
How much do you think it is off?
hot trux has a set of 1.5" lowering blocks on his truck,... and that kinda helps kick the rearend forward.
Keith
Old 12-12-2012, 09:12 AM   #300
jmedero
jmedero's Avatar
Shhh... Be quiet.. Do you hear that? What's that sound behind you?
Oh it's the sound of a snow ball effect starting to roll. Lol. Rear disc, new exhaust lay out, just a little bit lower.... Next thing you know
Lol
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
