Old 03-05-2014, 11:47 PM   #276
skymangs
skymangs's Avatar
Re: 49 ls1
I also filled the firewall hole I cut out to mock up the column. And did some rust repair to the drivers side A pillar. Next on the list is repairing that dvr side cab corner, welding in the dash, and building some bracketry for that Fulton visor.
skymangs is offline   Reply With Quote
Old 03-06-2014, 12:11 AM   #277
oldman3
oldman3's Avatar
Re: 49 ls1
Chris, bracket looks good. Never seen a door pillar rust in those areas, but there's a lot I haven't seen...Jim
oldman3 is offline   Reply With Quote
Old 03-06-2014, 02:46 AM   #278
99 to Life
99 to Life's Avatar
Re: 49 ls1
cool cool, yeah I went with the newport from classic parts USA made one for like 200 I think, little steep but I didn't wanna dicker with anymore and that was the last main thing my truck needed when I finished it. I am however gonna maybe try some of the way less expensive motors you see out there, just fab up a bracket and see if I don't destroy something. $200 just to have a 2 speed wiper is a bit steep, but I wanted to support something usa made, the china one is 160. Looking good.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 03-06-2014, 06:34 PM   #279
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks guys, This truck had a hole cut in the center of the roof, right above the windshield (I assume for an antenna). I'm sure that it allowed water and debris to run down the channels and settle on top of the upper door hinge. I found a lot of debris behind the metal when I cut out the rust.
Bear Claw latches and plates got here today, unfortunately I was sent a set of "small" latches instead of the large ones I ordered. Got it fixed, but I have to wait for the correct ones to get here.
Old 03-06-2014, 07:13 PM   #280
skymangs
skymangs's Avatar
Re: 49 ls1
New T-Shirts are in! If anyone would like one, please PM me.
Old 03-12-2014, 10:42 PM   #281
skymangs
skymangs's Avatar
Re: 49 ls1
Got some work done on the dash tonight. Got the new Pro-Line vents and AC control panel from Vintage installed.
Old 03-12-2014, 10:45 PM   #282
skymangs
skymangs's Avatar
Re: 49 ls1
I had to get a little creative with the AC controls. I wound up cutting out the ashtray support, and building some framing behind it. I think it turned out kind of nice though.
Old 03-12-2014, 10:48 PM   #283
skymangs
skymangs's Avatar
Re: 49 ls1
I also welded in the delete panel on the other side of the radio, and slapped a little bit of dyna-hair over it. Next I have bear claw latches and one more cab corner to install.
Old 03-12-2014, 11:15 PM   #284
oldman3
oldman3's Avatar
Re: 49 ls1
Looking good Chris...Jim
Old 03-13-2014, 11:08 AM   #285
99 to Life
99 to Life's Avatar
Re: 49 ls1
looks cool, nice and subtle.
Old 03-13-2014, 10:23 PM   #286
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks guys. I want it not to look too custom, just at second glance. That is the idea anyway.
Old 03-17-2014, 08:25 PM   #287
skymangs
skymangs's Avatar
Re: 49 ls1
Got some work done on the 49 today (waiting on parts for a customer car). Dashboard is all welded in.
Old 03-17-2014, 08:40 PM   #288
skymangs
skymangs's Avatar
Re: 49 ls1
I also installed my new large bear claw latches, and worked on door gaps. Got them fitting pretty good, need some tweaking on the forward edges still.
Old 03-17-2014, 08:54 PM   #289
skymangs
skymangs's Avatar
Re: 49 ls1
More pics.
Old 03-17-2014, 09:56 PM   #290
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 49 ls1
Great work fixing those gaps. That looks like a crazy amount of work.
--Josh
Old 03-17-2014, 10:10 PM   #291
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks Josh. Those damned doors never fit right. Always finding the happy medium, then fixing the frame to match.
Old 03-17-2014, 11:25 PM   #292
oldman3
oldman3's Avatar
Re: 49 ls1
Taking shape Chris, nice job...Jim
Old 03-18-2014, 09:20 AM   #293
48ChevBagged
48ChevBagged's Avatar
Re: 49 ls1
Looking good sarge. Great job on the doors.
48ChevBagged is offline   Reply With Quote
Old 03-19-2014, 10:42 PM   #294
skymangs
skymangs's Avatar
Re: 49 ls1
thanks 48Chev, and Jim
Here's some pics of the dash with some accessories mocked up. Starting to take shape!
Old 03-20-2014, 11:13 PM   #295
skymangs
skymangs's Avatar
Re: 49 ls1
Finally got that drivers side corner in today. Did a bunch of door gap fitting, and some smoothing on the back wall of the cab.
Old 03-20-2014, 11:18 PM   #296
oldman3
oldman3's Avatar
Re: 49 ls1
Chris, looking good...Jim
Old 03-20-2014, 11:31 PM   #297
skymangs
skymangs's Avatar
Re: 49 ls1
I don't know why my replacement cab corners never fit the damned door frame. The gap always gets too wide at the bottom. Wound up slicing it, and adding a slim wedge of 18ga. to get the door gap correct on the bottom.
Old 03-20-2014, 11:58 PM   #298
oldman3
oldman3's Avatar
Re: 49 ls1
Just seems that's the way with replacement panels, one was OK on drivers side, but pass side was crazy off...Jim
Old 03-21-2014, 07:37 AM   #299
skymangs
skymangs's Avatar
Re: 49 ls1
Thanks Jim. Yeah it's kinda hit-n-miss with the replacement panels. My passenger side lower cowl fit great, but the drivers was all out of whack.
Old 03-21-2014, 07:57 AM   #300
STOCKISH
STOCKISH's Avatar
Re: 49 ls1
Great job on the rust repair. Looking killer, love what you did with the dash too.
--Josh
