Old 12-05-2014, 10:44 AM   #276
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
Pic #1 In this shot is how we normally do our steering column mounts...simply use exhaust tubing just big enough to fit over the column. Then using a large washer open the hole (if needed) so the shaft fits through with plenty of room to move. weld the washer to the bottom of tubing and metal finish..then the entire unit is ready for mounting in firewall. so after you drill your hole for the tubing you can slide it through the hole and get your depth set and mark it on the outside. at this point you can remove the excess (inside the vehicle leave 2-3") and then using flange nut close to the end of tube inside vehicle drill a hole and weld in place for securing the column.
Pic #2 all welded in...
reaper71 is offline   Reply With Quote
Old 12-05-2014, 10:50 AM   #277
reaper71
reaper71's Avatar
As I stated before this is what your tube will look like inside....The bolt you see is the way you secure the column,this is where the flange nut is used...So when it's all said and done you have a very solid mount for the column (at the bottom) so now when you need to remove it loosen the bolt and slide the column out of tube..
onto the upper mount..
Old 12-05-2014, 10:57 AM   #278
reaper71
reaper71's Avatar
In these two pics is the upper mount I'm making it is heavy wall tubing I had laying around and was the right I.D. I needed to fit the column. I cut them in half so there is a way of "clamping" them together.
The plate will then be welded to the upper (stock mount under dash)
Old 12-05-2014, 11:08 AM   #279
reaper71
reaper71's Avatar
Here is the final mount.. IT has been welded to the upper stock mount coming off the firewall and is super solid. So now when your putting this together, slide the column through the hole in the upper mount and into the lower tube and secure it. One thing I do not have a shot of is in the upper cover for the top mount I put a cap screw in it facing down. The reason for this is so you drill a hole the same size in the column and now the cap screw drops in the hole and locks it all together preventing the column from rotating.
Mark...
Old 12-05-2014, 05:41 PM   #280
RockinKees
RockinKees's Avatar
That looks nice and easy, Mark.
What are you using for brake pedal assembly?
I want to make my own assembly but have to sort it out yet...
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-05-2014, 05:57 PM   #281
rusty76
rusty76's Avatar
Great work Mark. I really dig the mounting system.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-08-2014, 10:27 AM   #282
reaper71
reaper71's Avatar
Thank's Kees....The brake pedal ass. is a Speedway unit it is a 6:1 ratio for the pedal swing I think they are around $90.00 range.
Old 12-08-2014, 10:28 AM   #283
reaper71
reaper71's Avatar
Thanks Rusty76!!
wanted it nice and simple to frills...
Old 12-08-2014, 10:33 AM   #284
reaper71
reaper71's Avatar
Onto the the next Item...My mount cover...
Here is a shot of the upper mount cover(this is not a structural item) This is simply used as a cover to fill in the gap between the dash and column...
1st I made a template and rolled it to the shape I wanted and then using round bar to finish off the edges.
Old 12-08-2014, 10:40 AM   #285
reaper71
reaper71's Avatar
In this Pic it is showing the entire cover made
(sorry did not have any pics during the making of lower cover) The lower cover was made from 1 piece and just rolled into shape and is held in place using industrial velcro
Old 12-08-2014, 10:43 AM   #286
reaper71
reaper71's Avatar
Covers all done....A few shots from diff. angles.
Till next time...
Mark...
Old 12-08-2014, 06:14 PM   #287
rusty76
rusty76's Avatar
Nice.
My build thread
Crossmembers CC
Old 12-08-2014, 07:13 PM   #288
RockinKees
RockinKees's Avatar
Looks great, Mark!
You've got a great eye for detail!
And thnx for the info about the pedal assembly!
Cheers!! Kees.
Kool Guyz CC
Old 12-09-2014, 10:43 AM   #289
reaper71
reaper71's Avatar
Thank's Kees! The part # Is 91631991 they also offer a dual for clutch and brake FYI...
Looks great, Mark!
Old 12-09-2014, 10:50 AM   #290
reaper71
reaper71's Avatar
Ok guy's this is my next big project!!!
I really wanted a cockpit feel to the interior. I also love the Impala gauge housing's, the problem is they are pot metal (aka cast) and if you try and weld to them they will blow apart.....My solution ....Make my own!!
Old 12-09-2014, 10:58 AM   #291
reaper71
reaper71's Avatar
First I started with exhaust tubing that fits around the gauge bezel (gauge sits inside tubing) and I cut the tube @ 30 degree angle.. Then using the piece that was cut off it is then tacked and trimmed to replicate the Impala design..(black line is cut off point)
The reason I cut @ 30 degrees and weld it back on, is it was alot easier than trying to get the angle cut with a flat all at one time
Old 12-09-2014, 11:00 AM   #292
reaper71
reaper71's Avatar
This is what you have after you cut the short section off....time for welding and metal finish..
Old 12-09-2014, 11:02 AM   #293
reaper71
reaper71's Avatar
Welding and metal finish all done!!
Old 12-09-2014, 11:07 AM   #294
reaper71
reaper71's Avatar
So...After several hrs cutting,welding and metal finish they look like this.
You may notice the seam on the inside...Yes I weld them and metal finish them as well...
At this point all the small ones are finished, now onto the Large!!
Till next time..
Mark...
Old 12-09-2014, 02:08 PM   #295
RockinKees
RockinKees's Avatar
Cheers!! Kees.
Kool Guyz CC
Old 12-09-2014, 05:11 PM   #296
Advanced Design
Advanced Design's Avatar
Mark - Really great ideas you are sharing! Love every one of them and really appreciate your design eye and talent. Thank you for continuing to share and look forward to the next updates.
PS - When do you sleep?
Advanced Design is offline   Reply With Quote
Old 12-09-2014, 05:52 PM   #297
rusty76
rusty76's Avatar
I've wondered the same thing^^^^^ When do you sleep? Zzzzzzz
My build thread
Crossmembers CC
Old 12-10-2014, 10:53 AM   #298
reaper71
reaper71's Avatar
HaHaHa!!!! you guys are funny!!
Alot of the progress I'm sharing was already completed at a earlier date so this is old stuff....
Old 12-10-2014, 11:00 AM   #299
reaper71
reaper71's Avatar
OK boy's....these are the large bezel's.
again starting with exhaust tubing. (went to a diesel shop for the tubing)
These are still not large enough to fit over the large gauges (3 3/8) so they will need to be cut and opened up about an inch..
this pic shows same steps as the small ones, cut,weld,grind etc.
Old 12-10-2014, 11:07 AM   #300
reaper71
reaper71's Avatar
In this pic. it is showing the amount it has been opened.
So after I spent the time doing my metal finish on the tube I then cut it open and lightly pull it apart so it will fit around the gauge bezel....Then using a leftover piece of tube I cut my piece to be installed..
