Old 09-26-2019, 12:01 PM   #276
lower50's
lower50's's Avatar
Re: Project Screamer - '72 GMC K2500 + DD 4-53T
Very nice and clean. Did you paint it all together or apart?
Ps: I think your fan belt is a bit loose.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-26-2019, 04:40 PM   #277
burnitg
A mix, i removed the water pump, oil cooler, oil pan, rocker cover, turbo and exhaust manifold. The remainder, I painted together. I had the exhaust manifold and turbine housing ceramic coated.
I left the belt loose because I can’t set the vertical height of the fan until I have the engine in the truck and the fan shroud installed.
burnitg is offline   Reply With Quote
Old 10-19-2019, 03:12 PM   #278
burnitg
Painted!
The old Jimmy is painted. I drove down to Denver yesterday and picked him up.
Name:  On the trailer headed home.jpg
The paint job is GORGEOUS! I don't think he looked this good when new.
Name:  Painted tailgate.jpg
I had the bottom of the cab coated with Lizard Skin to help mitigate the noise from the engine and transmission. I used Lizard Skin on the bottom of my UNIMOG cab. It made a big difference.
Name:  Cab Lizard Skin.jpg
He's going to sit on the trailer for a while. I'm still working on the chassis and drive train.
Old 10-19-2019, 04:27 PM   #279
kipps
Any chance you're going to make a custom SPID sticker for the truck? Make up your own RPO codes for the detroit and other custom bits? It'd be interesting to see GM truck aficionados try to make sense of that one!
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-20-2019, 01:53 PM   #280
burnitg
I have considered making my own SPID sticker. I have the correct option code for the 4-53T from the 1979 C-70 that I pulled it from. I’ll have to create my own code for the Fuller transmission since it wasn’t offered. I won’t do anything until the truck is back on the road.
Old 10-20-2019, 06:27 PM   #281
regan wilson
regan wilson's Avatar
Man that looks awesome Burn. I can't wait to see it together.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 10-30-2019, 01:45 AM   #282
Average Joe
Average Joe's Avatar
That would be very cool!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 11-03-2019, 08:29 PM   #283
burnitg
The engine has landed!
I finished the brake and fuel tubing and dropped the engine into position in the chassis.
Name:  4-53T in the chassis.jpg
It sure looks good.
Old 11-04-2019, 07:32 AM   #284
regan wilson
Yes it sure does.
Old 03-13-2020, 09:24 AM   #285
regan wilson
Any updates?
Old 04-23-2020, 11:43 PM   #286
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Man the body looks beautiful!!! When you get to the spid, member chipflyer makes them and he will custom make you one as well. The engine and chassis look sweet too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-04-2020, 05:50 PM   #287
lower50's
lower50's's Avatar
Updates? Hope things are good.
1951 MG TD
Old 02-23-2021, 05:17 PM   #288
kipps
Any updates? I've been pretty excited about this build, and want to see it continue.
