09-01-2019, 07:44 PM | #276 |
Re: Dumptruck Dolly
09-02-2019, 11:26 AM | #277 |
Roadtrip!
Re: Dumptruck Dolly
It hooks under the edge of the arm and then you just work the arm up and it pops off. Should be able to find one at napa or similar.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-02-2019, 02:19 PM | #278 |
Re: Dumptruck Dolly
Thanks Too Much Stuff...I’ll have to look into it.
09-02-2019, 03:51 PM | #279 |
Re: Dumptruck Dolly
I have to say that I’m impressed the original flooring has held so well in its previous farm life.
09-02-2019, 04:02 PM | #280 |
Re: Dumptruck Dolly
In my previous post (find the double burger) I mentioned removing the roll pin on top for the 4 speed shifter...DON’T DO IT!!!...
Here’s the right way... 1. I had to use a little lubricant to get the top to depress down against spring pressure...you may not have to. Note the opening where shifter goes in, is positioned straight ahead. 2. Get over the top of the silver ring and press down hard! 3. When you get it pressed down, turn an 1/8th turn counter-clockwise. See red arrow. Again, normally the opening you see is positioned straight ahead. 4. Remove shifter 5. Plug up the hole on top the trans to keep debris from getting in. |
09-02-2019, 07:01 PM | #281 |
Re: Dumptruck Dolly
Bottom half is ready, I think...speedo cable, u bolts, trans mount bolts, motor mount bolts. Hopefully, tomorrow afternoon allows me to yank it out.
09-03-2019, 10:09 PM | #282 |
Re: Dumptruck Dolly
That was a workout...thanks to my son and my brother, I was able to get the 292 and the trans out as one unit. Doing this while keeping the riveted transmission crossmember in was accomplished by disconnecting the rag joint, unbolting the front cab mounts, and simultaneously jacking up the front of the cab just a few inches. (I had enough slack in the brake lines) After that, it was just a wrestling match the rest of the way. I’ll clean up the tools tomorrow...but for now, I’m calling it a night.
09-03-2019, 10:42 PM | #283 |
Re: Dumptruck Dolly
Wow.
Great progress. I like your shop and your strategy of the project. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
09-04-2019, 12:09 AM | #284 | |
Re: Dumptruck Dolly
...regarding the project, I’m trying take a little section at a time, and enjoy the success of the moment. Thanks 👍 |
09-15-2019, 07:08 PM | #285 |
Re: Dumptruck Dolly
I siphoned the brake reservoir in preparation to disconnect the brake lines. I didn’t want brake fluid all over the place.
09-15-2019, 07:26 PM | #286 |
Re: Dumptruck Dolly
I marked the engine mounts... I don’t want to guess what they are on the “next” project.
09-15-2019, 07:40 PM | #287 |
Re: Dumptruck Dolly
Another milestone...
09-15-2019, 07:51 PM | #288 |
Re: Dumptruck Dolly
Some scraping, some grinding, and liberally spraying brake cleaner to clean and dry the metal, I sprayed my favorite rubberized sealer on the frame...now I am pumped up...after the frame dries, I think I’ll clean up the firewall.
09-15-2019, 08:08 PM | #289 |
Proprietor of Dale's Corner
Re: Dumptruck Dolly
Looks good, progress is always good....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-15-2019, 08:17 PM | #290 |
Re: Dumptruck Dolly
09-15-2019, 09:41 PM | #291 |
Re: Dumptruck Dolly
Thats one of the nicest dump trucks in this era that I've had the pleasure of seeing!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 09-15-2019 at 09:47 PM. |
09-15-2019, 09:55 PM | #292 | |
Re: Dumptruck Dolly
I do have some ideas on where I want to take this truck regarding looks, etc...but I have to remind myself about the initial goal of “keeping it in a functional mode”, and not tear this down so far that it’s not useable for long periods of time... Stay tuned |
09-16-2019, 11:24 PM | #293 |
Re: Dumptruck Dolly
Looking good!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
09-17-2019, 12:36 AM | #294 |
Re: Dumptruck Dolly
09-20-2019, 09:17 PM | #295 |
Re: Dumptruck Dolly
Maybe a minor detail, but I’m documenting the original scribed numbers from the assembly line.
09-20-2019, 09:41 PM | #296 |
Re: Dumptruck Dolly
Using aluminum foil again, I prepped the firewall for paint. Prior, I used a wire brush on a drill to scuff up the paint. I used rubberized sealer below the cab seam and used black hammered paint for the rest. I find that this hammered finish covers a multitude of blemishes and is a great finish when you’re going to change colors later on. I’ll use this on the inner fenders and fender wells.
09-20-2019, 09:49 PM | #297 |
Re: Dumptruck Dolly
My son came into the garage last night and cleaned up the trans and transfer case. After masking today, he sprayed multiple thin coats of Chevy Orange. I like it!
09-21-2019, 08:24 AM | #298 |
Re: Dumptruck Dolly
I like the Hammer finish paint.
I have used it before but not on trucks and cars Looks great. Your moving right along. .
09-23-2019, 12:22 AM | #299 | |
Re: Dumptruck Dolly
Looking at your profile, I see you had a 1963 Impala in high school. I bought one as a sophomore and spent the next three summers working on it. My first day on the road with it was October 2, 1984...I was a freshman in college. Here’s a pic of my SS. |
09-23-2019, 07:24 AM | #300 |
Re: Dumptruck Dolly
I still got it. Bought it when I was 15.
That will be my next (make over) project. Mine is a 2 door hardtop Impala. I also like the Orange on the trans and transfer. What transfer case is that? .
