12-10-2022, 12:42 AM | #2976 |
Re: Post Your Craigslist Finds Part 2
12-10-2022, 12:43 AM | #2977 |
This is a 2nd owner truck, Never wrecked. I have owned it for over 30years. This is a one of a kind Monster. It has a Merlin IV Chevy 572 CI Race motor Balanced and Blue printed with a Dyno sheet measuring 748HP with a 4 barrel carburator, More like 850HP with the Pro Flo 4 intake on it. Comes with a hand held computer controller so you can set all the parameters of the intake. Lot of torque, From White Racing Motors in Tennessee. exact number is on the sheet. It is Fuel Injected with a massive Edelbrock Pro Flo 4 Intake on it with a 4 1/2" diameter intake. It has a Yukon Posi traction rear end, 17" billet polished Aluminum wheels with bead locks and Mickey Thompson Baja Tires on it and they were machined to take the original chevy hub caps, cool. It has front disc brakes. The wheels are rated for over 100ph. It has a balanced 4" Aluminum drive line. The transmission is a 4L80E with a shift kit and computer. It has a DANA 60 rear end. It has a Fuel Pump speed controller for keeping the fuel constant in hot weather. It has Evans antifreeze coolant in the motor for heat control. The C20 has the passenger side tool box with a rust free door and it locks. It has a white camper shell. I installed heavier front springs for the added weight and to keep it level. It has 4WD clearance under the truck. The truck looks totally stock.
I have all brand new top of the line choice Oak for the bed and the chrome runners and all the hardware to install. I have a complete package of insulation foam for inside the doors and floor. Brand new carpeting and new blue and black Houndstooth seat upholstery for the bench seat. I installed a extra rear gas tank that is 24gal along with the front tank which is 24 too I believe. I can send pics to serious buyers. I will post pics later. Think FARM TRUCK check out YouTube. do NOT contact me with unsolicited services or offers https://fortcollins.craigslist.org/cto/7564945783.html |
12-10-2022, 12:45 AM | #2978 |
Clear Colorado title
350 ci sbc, Runs well, quiet top end and bottom end. Edelbrock Street Master low profile single plane intake manifold Edelbrock 1405 600cfm manual choke carburetor Hei distributer Long tube headers, true dual exhaust, glass pack style mufflers Power brakes, power steering SM 465 four speed NP205 two speed transfer case Dana 44 front axle (open) with lock out hubs and disk brakes Gm 12 bolt rear axle (open) with drum brakes 4 inch suspension lift kit 15 x 10 inch steel wheels 33 12.50 15 tires (date code 2008) Custom front and rear bumpers, and tubing grill built in our shop, all bolt on parts. Good battery (2018) Starts, runs, drives, and stops. What i would call a great turn key "project" Has a solid diamond plate steel bed floor Doors bottoms are in good shape (picts) 205 and 465 checked and topped off with gear oil. Fresh engine oil and filter 10/40 Carb has been cleaned and a new kit installed Fuel tank inspected while installing the new sending unit, looks like new inside. This is a solid truck, has a GMC tailgate and possible stepside bed on it Discloser: has damage to drivers side rocker panel and common cab corner rust. (picts). Will include patch panels for the cab corners and rocker panel with sale of truck (picts). https://westslope.craigslist.org/cto/7564000424.html |
12-10-2022, 12:46 AM | #2979 |
12-10-2022, 12:47 AM | #2980 |
https://denver.craigslist.org/cto/7559679361.html - 350 4BBL/ T350 - Rebuilt?
- A/C Cab - Tilt tach - Power steering - Power brakes - New rear fenders - $700 each - New black bench seat - New wood floor - Rear gas tank - New 31 10:50's on 15x8 Chevy Rally's - Needs RH Rocker and paint - Runs and drives great - Mechanically well sorted - Needs lots of misc follow up after paint Call for details - If you have been seriously looking for a short box - You will see that this one is approx 75% done Only interested int trading for 67 - 72 Half ton 4x4 Long Box |
12-10-2022, 12:48 AM | #2981 |
12-10-2022, 12:50 AM | #2982 |
12-10-2022, 12:52 AM | #2983 |
12-10-2022, 12:53 AM | #2984 |
1971 Chevy C10 PU completely restored it has a 383 stroker professionally built automatic transmission rebuilt I am the second owner I have all the records and receipts for the truck brand new Michelin tires just to many things to list call or text for more information $21,000. OBO NO TRADES!!! https://moseslake.craigslist.org/cto/7566534527.html
12-10-2022, 11:01 AM | #2985 |
this .......... great trucks Wikid
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
12-12-2022, 09:49 PM | #2986 |
12-12-2022, 09:51 PM | #2987 |
12-12-2022, 09:51 PM | #2988 |
12-12-2022, 09:54 PM | #2989 |
1970 Chevy k20 has a 350 with a 4 speed. Has a Dana 60 front axle with new seals and axle shaft u joints. New tie rod and ends and new steering stabilizer. Has a new brake booster/master cylinder/ proportional valve set up for the disc front and drum rear. Front brakes lines have been re-done so it has a line to each front wheel. Comes with the factory drum drum proportioning valve and drum brake front Dana 44. Has a brand new heater fan. New aluminum radiator. Bluetooth radio that fits into factory uncut dash. Have lots of parts that can go with it. Includes 2.5” front lift springs that’s are brand new. It has rust in the usual places for these trucks. Some has been temporarily patched. Has dents and dings it’s not perfect. Truck runs and drives great just have moved on to a new project.
Call or text with any questions I am sure I am forgetting something. $9500 obo https://portland.craigslist.org/mlt/cto/7567347574.html |
12-12-2022, 09:55 PM | #2990 |
12-12-2022, 09:59 PM | #2991 |
12-12-2022, 10:03 PM | #2992 |
12-12-2022, 10:05 PM | #2993 |
12-12-2022, 10:06 PM | #2994 |
12-12-2022, 10:11 PM | #2995 |
12-12-2022, 10:16 PM | #2996 |
12-12-2022, 10:25 PM | #2997 |
12-12-2022, 10:29 PM | #2998 |
12-12-2022, 10:30 PM | #2999 |
1972 CHEVROLET REAL CHEYENNE C/10 SHORRT BED
CLICK OR COPY AND PASTE LINK TO WATCH WALK AROUND VIDEO --- > https://youtu.be/kzxezam_Zck THIS C10 IS A REAL HEAD TURNER . ZERO ISSUES AND TURN KEY . FLY IN AND DRIVE ANYWHERE WITH NO WORRYS .. ZERO LEAKS AND ZERO RUST! PAINT IS DAMN NEAR FLAWLESS AND HAS ZERO ROCK CHIPS AS YOU CAN SEE IN VIDEO. SHE IS A BLUE WITH PEARL PPG PAINT , NO ORANGE PEEL AND SMOOTH TO THE TOUCH … HAS THE ORIGINAL DRIVE TRAIN WHICH HAS BEEN COMPLETELY REDONE TOP TO BOTTOM . 350 MOTOR 350 TRANSMISSION NEW HOLLEY CARBURATOR NEW EVERYTHING COLD AC AND HEAT NEW LOCKING BED COVER NEW RIMS AND TIRES SPRAY IN BEDLINER NEW INTERIOR NON SMOKER NEW GLASS AND GASKETS ALL THE WAY AROUND NEW LEVELING KIT ALL GUAGES WORK AS THEY SHOULD ALL LIGHTS WORK HORN AND BLINKERS WORK NEW BATTERY TRANS COOLER 12 BOLT REAREND TRUCK IS FROM CALIFORNIA AND LIVES IN TEXAS NOW CLEAR CLEAN TITLE IN HAND ! I BUY AND SELL HOT RODS AND HAVE BEEN DOING SO FOR 20 YEARS WITH 100% RATINGS ANYWHERE IM FOUND FOR A REASON. I WORK FROM HOME IN HOUSTON TEXAS AND PROMISE YOU THE BEST EXPERIENCE TO DATE! I WILL ENTERTAIN EVEN TRADES OR TRADE AND CASH FOR OTHER HOT RODS . MUST BE NICE AND NEED NOTHING ….LOOKING FOR 1956 FORD F100 , 1961 IMPALA BUBBLE TOP , 1970 – 1973 CAMARO , 1966 1967 NOVA OR ? PURCHASE COMES WITH FREE SHIPPING TO YOUR DOOR IN THE U.S. $46,500 C E L L ( 8 3 2 ) 6 0 6 - 0 0 0 1 do NOT contact me with unsolicited services or offers post id: 7567511588 posted: about 8 hours ago https://houston.craigslist.org/cto/7567511588.html |
12-12-2022, 10:31 PM | #3000 |
