Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-07-2019, 10:59 AM   #3026
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2dvSYJG]20190206_112501
It's in , very easy to match up studs with feet
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-08-2019, 06:51 PM   #3027
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I decided to carry my stud idea a little further, I screwed up one of the studs by not using the correct tool, thinking a torx would work, but not
[url=https://flic.kr/p/SvzmoJ]20190208_104157
SAFETY FIRST
AS usual, off topic
Jim
Old 02-08-2019, 06:53 PM   #3028
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/QTmxvc]20190208_104116
SAFETY FIRST
AS usual, off topic
Jim
Old 02-08-2019, 07:00 PM   #3029
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
decided to wax the brackets, I like the look of semi rust, but wanted to protect them some what
whiskey :30
[url=https://flic.kr/p/2dxZH5j]20190208_175454
all phillips heads replaced with square drive, hated that little burr you get with phillips head, even with a new screw driver and correct head
[url=https://flic.kr/p/243wRYF]20190208_181529
SAFETY FIRST
AS usual, off topic
Jim
Old 02-10-2019, 08:03 PM   #3030
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
decided to take it a step further, tracks haven't been lubed since who knows when....
and dum dum never
[url=https://flic.kr/p/2456Pbp]20190210_094203
[url=https://flic.kr/p/SxtVD1]20190210_102035[
don't know what WTR stands for , but I grabbed it when I had first honors, to go thru my brother in laws garage. He worked for boeing-vertol right after his service in the Marine Corps
SAFETY FIRST
AS usual, off topic
Jim
Old 02-14-2019, 11:28 AM   #3031
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
working on adapter for trans. temp. sender
[url=https://flic.kr/p/2eEPShf]20190214_091934
[url=https://flic.kr/p/2dDy51J]20190214_101741
easy peezy
[url=https://flic.kr/p/2eKpbKX]20190214_083014[/url
SAFETY FIRST
AS usual, off topic
Jim
Old 02-14-2019, 11:33 AM   #3032
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2dDyCcN]20190214_103128
SAFETY FIRST
AS usual, off topic
Jim
Old 02-15-2019, 06:11 AM   #3033
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
What did you dum dum on the tracks?
litebulblsc is online now   Reply With Quote
Old 02-15-2019, 10:21 AM   #3034
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
underneath the mounting brackets, where it mounts to the floor, it squeezed out, About a 1/4" roll all the way around, plus the bolt hole
[url=https://flic.kr/p/SyAQQ3]20190211_102814
SAFETY FIRST
AS usual, off topic
Jim
Old 02-16-2019, 11:05 AM   #3035
litebulblsc
Re: PO has me PO'd
Oh, okay. That makes sense
Old 02-17-2019, 12:01 PM   #3036
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
a little trouble with the back bracket for the Lokar shifter. Have to buy a 5/8" spacer and a 3/8"-16 X 3" bolt
[url=https://flic.kr/p/2eNdRw8]20190217_104456
SAFETY FIRST
AS usual, off topic
Jim
Old 02-27-2019, 11:36 AM   #3037
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
finished up rear trans mount, ordered 3" bolts had to cut down to 2 1/4"
[url=https://flic.kr/p/2dKgeGA]20190220_121315
working on shift lever, changing 1/4" hole to 5/16" for studded rod end
SAFETY FIRST
AS usual, off topic
Jim
Old 02-27-2019, 06:08 PM   #3038
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Threaded 5/16" rod and studded rod end came today, working on shifter linkage
[url=https://flic.kr/p/2dRNtzC]20190227_170045
also picked up my Nic cop brake tubing from NAPA 5/16"
SAFETY FIRST
AS usual, off topic
Jim
Old 02-28-2019, 12:44 PM   #3039
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
finished mod to 5/16" studded rod ends for Lokar shifter
[url=https://flic.kr/p/2eYnmwX]20190228_113604
now onto vacuum line for trans
SAFETY FIRST
AS usual, off topic
Jim
Old 02-28-2019, 08:30 PM   #3040
rsavage
rsavage's Avatar
Re: PO has me PO'd
Looking good Jim. Stud idea on seat mounting is great. Makes installing carpeting a lot easier if you are going that route.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-28-2019, 08:42 PM   #3041
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thank you, but no, carpet only hold moisture and sand, perfect combination for rusting out my floor boards again. I'm thinking garden hose after a trip to the beach
Your truck is looking great, my shop is 14 by 18 but it is heated, so I can spend my time in a t shirt
My son offered to help finish my truck in april march, so it will be headed your way
SAFETY FIRST
AS usual, off topic
Jim
Old 03-18-2019, 09:10 AM   #3042
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2fdRkx2]20190317_085148
[url=https://flic.kr/p/24BjTQn]20190317_085228
SAFETY FIRST
AS usual, off topic
Jim
Old 03-18-2019, 09:48 AM   #3043
litebulblsc
Re: PO has me PO'd
When are you going to get around to getting that guage off the min reading?
Old 03-18-2019, 07:41 PM   #3044
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Ya made me chuckle, looking at end of summer, when all those wires terminate at a senser or something
SAFETY FIRST
AS usual, off topic
Jim
Old 05-12-2019, 09:18 AM   #3045
litebulblsc
Re: PO has me PO'd
I find it hard to believe you haven't made any new progress. What's up?
Old 05-18-2019, 07:22 AM   #3046
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
sorry for not updating, but just enjoying life. this is my off season, where I catch up on my other projects. Did get to drive the shifter cart for a while, it's a blast.
doing alot of road trips, just got back from Sturbridge flea market, lots of cool stuff up there, picked up some automobilea.
SAFETY FIRST
AS usual, off topic
Jim
Old 05-19-2019, 09:37 PM   #3047
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
That's not a good excuse Jim. Those of us without skills need our regular dose of progress.
J/K. Enjoy your off season.
low'n slow is offline   Reply With Quote
Old 05-21-2019, 06:57 PM   #3048
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
alright,alright! I got you're drift, no more crickets. Here are some updates, quadrajet and dual point dizzy going back in, TPI and computers going on the shelf. Pics to follow
SAFETY FIRST
AS usual, off topic
Jim
Old 05-21-2019, 08:01 PM   #3049
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2eA8b8z]20190521_17311
[url=https://flic.kr/p/2eA81a8]20190521_172515
[url=https://flic.kr/p/2fZ5k5t]20190521_172611
SAFETY FIRST
AS usual, off topic
Jim
Old 05-21-2019, 10:02 PM   #3050
low'n slow
low'n slow's Avatar
Re: PO has me PO'd
That looks nasty.
