Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-29-2019, 08:46 AM   #3076
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
ahh DUNCAN YoYo been there done that wish I had saved one I too shall be a spring chicken August 17th turning 68 years young...Happy Birthday Jim
Jess
zicc1835 is offline   Reply With Quote
Old 07-01-2019, 07:22 AM   #3077
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Jess
Wow Jess, I am 2 days older than you, Happy Birthday to you as well
Us spring chickens have got to get together
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-04-2019, 06:43 AM   #3078
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
tank is mounted in truck, filler neck hose installed. What a pita putting tank up even with a trans jack
seems the repop manufactorer coundn't measure, as the mounting holes for the "U" bracket were off by a 1/4", didn't have a tool to do the job quickly so I just grabbed a rat tail file, and made a bunch of noise
Later will install rubber, between tank and straps.
also, received a filler neck clamp from Eric(1972 jimmy). Didn't even know they had a clamp
SAFETY FIRST
AS usual, off topic
Jim
Old 07-05-2019, 08:01 AM   #3079
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2gr67p1]20190704_123833
[url=https://flic.kr/p/2gr6dyW]20190704_123548
SAFETY FIRST
AS usual, off topic
Jim
Old 07-05-2019, 08:07 AM   #3080
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
finally was able to use my wobbler/center finder I bought several months ago
[url=https://flic.kr/p/2gpEbJe]20190702_135842
SAFETY FIRST
AS usual, off topic
Jim
Old 07-05-2019, 11:48 AM   #3081
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Poser
[url=https://flic.kr/p/2grJWWm]20190705_113337
SAFETY FIRST
AS usual, off topic
Jim
Old 07-06-2019, 10:52 AM   #3082
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
oil pan is up,but not without a struggle. My all thread didn't work as planned, the back corners hit the all thread, but the front was ok. I've bought 2 of these gaskets and neither on came with those 4 gizmos that help with installation
I have to open up the holes in the clamps for 1/4-20 studs. I have a press / punch with dies, want to see if it works on SS, I have to find the pliers that close these clamps
[url=https://flic.kr/p/2gspivY]20190706_101712
[url=https://flic.kr/p/2gsp2LF]20190706_101726
[url=https://flic.kr/p/2gsp48J]20190706_101800
SAFETY FIRST
AS usual, off topic
Jim
Old 07-06-2019, 11:38 AM   #3083
rsavage
rsavage's Avatar
Re: PO has me PO'd
I always glue the gaskets, even the one piece, to the pan with black RTV and let it sit for a few hours or overnight. I put the pan bolts down through the holes to keep them aligned, and also use some blue tape. Gasket stays on the pan whether it is upside down when installing on an engine stand or when putting it on the engine when it is in the truck.
It's looking good Jim.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 07-06-2019, 02:18 PM   #3084
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
The one piece gaskets don't need any glue or RTV. Just make sure the block and all mating surfaces are clean and bone dry.
Here's the Snap-ups you're talking about. Don't know how I put up a pan and gaskets before without them. Huge difference.
https://www.summitracing.com/parts/fel-es72863
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 07-06-2019, 07:00 PM   #3085
rsavage
rsavage's Avatar
Re: PO has me PO'd
Of course they don't. But gluing them to the pan with a very thin smooth layer of RTV works flawlessly and holds the gasket in place all over its perimeter. It will also stay with the pan if you have to remove it.
1961 C1 Corvette
2021 Durango RT 5.7
Old 07-06-2019, 08:28 PM   #3086
rsavage
rsavage's Avatar
Re: PO has me PO'd
By the way Jim, what is the capacity of that pan?
1961 C1 Corvette
2021 Durango RT 5.7
Old 07-07-2019, 07:42 AM   #3087
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
thanks for your ideas guys, but I sorta went with both, just RTV'D the 4 corners where it made a sharp bend. ran my primer device yesterday and no leaks so far. But, who knows what will happen when the engine gets up to temp. and full pressure.
the pan is a 8 quart, just a heads up, they didn't deburr inside where it was cut and welded so be careful when you wipe it down
[url=https://flic.kr/p/2grFkpA]20190705_095016
thanks for the link on the parts AJ. I just may buy them and keep in tool box
SAFETY FIRST
AS usual, off topic
Jim
Old 07-08-2019, 10:34 PM   #3088
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
we shall ...I may have more time on my hands soon ....and take a ride when it works for us ....share a birthday cheer...
Old 07-11-2019, 08:13 AM   #3089
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well, since you're my little brother, i'll take you out for dinner, Mexican or ?
SAFETY FIRST
AS usual, off topic
Jim
Old 08-29-2019, 01:45 PM   #3090
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
my shop is empty, moved over to injection connection, sure feels like a load has been lifted from my shoulders. I'll let Dale handle my problems for now....
first problem he saw was the sealing of the pump to tank, he offered suggestions. I'll post up when I get more info.
Yes, that is one of the shelving units loaded with Jimmy parts, I'll sell them off as I don't use them
[url=https://flic.kr/p/2gEFFfj]20190722_194138[
one eye instead of four
[url=https://flic.kr/p/2h7pLiM]20190829_100502
[url=https://flic.kr/p/2h7pLo6]20190829_100619[
SAFETY FIRST
AS usual, off topic
Jim
Old 08-29-2019, 01:52 PM   #3091
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: PO has me PO'd
Glad to see you making some progress on this Jim. Looks real nice out in the open shop like that.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 08-29-2019, 02:06 PM   #3092
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Richard, I am breathing a sigh of relief, like the world is lifted. Thank goodness I saved some cash after I paid off the camaro and bought a boat. DON'T tell the wifey, I don't think she ever reads this site
Computers are installed using my mount, wiring is installed at main harness and working on fuel tank seal
Dale is a wiz at this early TPI set up, He was just out at the salt flats tuning cars
SAFETY FIRST
AS usual, off topic
Jim
Old 08-29-2019, 06:03 PM   #3093
1rippen6
Re: PO has me PO'd
I see a grand national in your picture, does he work on them also?
1rippen6 is offline   Reply With Quote
Old 08-29-2019, 08:26 PM   #3094
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
Hopefully it is a quick turn around.
litebulblsc is offline   Reply With Quote
Old 08-29-2019, 10:39 PM   #3095
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
great news moving the project along Jim, shop looks lonely ...
Old 08-30-2019, 06:46 AM   #3096
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
actually, I think I saw 2-3, this guy works on anything, and does outstanding work
4-8 weeks is what he quoted me, but at this time it doesn't matter as she is getting worked on. Thanks for following
Thanks Jesse, just bought an old boston whaler, so I have another project waiting to go in the shop, wish I had a bigger shop
sweet '55 you have been working on, glad the gas tank swap went well
SAFETY FIRST
AS usual, off topic
Jim
Old 08-30-2019, 09:20 AM   #3097
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: PO has me PO'd
Great progress Jim - ready to drive before the snow flies maybe?
Old 09-01-2019, 08:48 AM   #3098
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Pete, yeah, maybe, but I wouldn't mind driving in a lot of snow. our car washes down here have a product called salt x, and undercarriage wash.
Your trucks look fantastic, glad they made the move well, hope you enjoy the cold and snowy cold north
SAFETY FIRST
AS usual, off topic
Jim
Old 09-01-2019, 10:41 AM   #3099
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: PO has me PO'd
When I lived in MT I’d drive my k20 in salt free snow and had a good time. Too much salt here to consider it. I’m told that some car washes here recycle the undercarriage wash and it can be like brine - I’ve identified a car wash that doesn’t recycle water.
Thanks for the good words. Having a great time here!
Old 09-01-2019, 05:59 PM   #3100
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
didn't know that about recycled water, but I'm sure if I get the truck done I won't care what the weather is, 20 years is along time to wait, and I'm super excited to drive this thing....
Thanks for entertaining me with you're great builds and info. of said builds. I always key into a thread when i see you post up
SAFETY FIRST
AS usual, off topic
Jim
