Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-31-2015, 01:54 AM   #301
70gmc longbed
70 gmc longbed weighs 4300 with me in it
357 aluminum heads
1.9 60ft
8.7 1/8th
80mph
70gmc longbed is offline   Reply With Quote
Old 09-21-2015, 02:33 PM   #302
turbotruck
Re: post latest 1/4 and 1/8 mile times and 60ft.
1968 c10
turbo 355 sbc
borg warner s475 turbo
th350 trans
4130 lbs 3.73 rear gears
ptc 3500 stall
1.5 60 foot
6.46 @110 in the 1/8th
10.09 @131 mph in the 1/4
stock trailing arm suspension, with drop coils, front and rear sway bars added
15 year old napa shocks.
turbotruck is offline   Reply With Quote
Old 09-21-2015, 09:37 PM   #303
Heavymetl
5.3
10psi
4L80E
02-04 LS6 cam
3.25 gears Moser 9"
4100lbs
Now that Drag Week is over, time to turn up the boost and improve those times a little. Hoping for 10's at some point soon. I love this turbo stuff, drive like stock and scream on the skinny pedal.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 05-05-2016, 12:29 AM   #304
69GMC910
MOTORHEAD!
69GMC910's Avatar
Had my 82 out at the track on opening night at Castrol Raceway in Edmonton, Alberta on April 29th. Ran a new best! The DA was 2780' and I ran a 11.61 @ 116.10.
Heading back on May 20th to try to better my time.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 05-09-2016, 06:53 PM   #305
69GMC910
MOTORHEAD!
69GMC910's Avatar
This one was an 11.62 run.
https://youtu.be/EFr-XXjOWMU
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 05-23-2016, 01:03 PM   #306
turbotruck
Originally Posted by turbotruck View Post
1968 c10
turbo 355 sbc
th350 trans
ptc 3500 stall
1.5 60 foot
not my best pass, but slowly getting there.
new shocks helped with launches. need to turn up the boost at launch to get the 60' back to what it used to be
Old 07-27-2016, 12:30 PM   #307
lower50's
lower50's's Avatar
'52 GMC P/u
7.3L idi n/a diesel
custom intercooled turbo
4 sp auto
dually dana 70
locker
3:54 gears
First time drag racing for me and the truck
low boost 8psi
slipping trans
60ft 2.33
1/8 11.12 @ 60.23
1/4 17.64 @ 75
Slow but lots of room for improvement
A ton of fun
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-08-2016, 10:05 PM   #308
Da_pLaNt
78 SWB fleetside, Eagle 383, RHS Proaction 200 heads, th350, 9" w spool and 4.88 gears, caltracs CE 3 ways in front.
Best time to date:
1.628 60'
7.478@90.57
11.885@109.53
Da_pLaNt is offline   Reply With Quote
Old 01-10-2017, 03:22 PM   #309
19671972C10
15.32@86 with 2.4 60'
19671972C10 is offline   Reply With Quote
Old 03-16-2017, 11:02 PM   #310
edhtrd71
Finally took my 71 swb. My first time going down the drag strip was lots of fun but the reaction time and 60 ft times show I'm a rookie. Truck has a stock ls1/4l60e with stock converter and 3.73s.
60' 2.104
1/8 8.68
1/4 13.57
Mph 99.37
edhtrd71 is offline   Reply With Quote
Old 04-03-2017, 03:32 PM   #311
RatPwrd72
RatPwrd72's Avatar
I took the '72 out for it's first passes with the 496 I built 2 years ago. Truck pulls great but needs a converter swap, it's way too tight. I also took it across the scales and it weighed 4480 lbs with me in it.
1.78 60'
7.80 1/8th
12.15 1/4 @ 109 mph.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 04-15-2017, 12:15 AM   #312
djracer
djracer's Avatar
1.78 60'
7.80 1/8th
ADD SOME NITROUS IT WILL Loosen that Ole converter up!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-07-2017, 10:04 PM   #313
pacman1967
pacman1967's Avatar
1st time having the truck at the track, it weights 4000lbs with me it it. A little 357sbc with a 142 supercharger.
Best 60ft 1.923
Best 1/8 8.176 @ 86.06
Best 1/4 12.789 @ 105.61
Marcus
1985 swb C10 Supercharged357/TH400
1972 lwb C20, Grandpa Al's Truck
pacman1967 is offline   Reply With Quote
Old 08-15-2017, 12:04 AM   #314
lower50's
lower50's's Avatar
60' 2.168
1/8 et 10.601
1/8 mph 63.17
1/4 et 16.801
1/4 mph 78.01
Dropped .7 et and gained 3 mph from last year
1951 MG TD
Old 10-08-2017, 11:33 PM   #315
409malibu
just started building my 86 chevy sb. have been racing a 65 elcamino for a couple years now.
.040 sb 400
comp 660 solid roller
callies crank
6 in rods
mahle forged flat tops
brodix cnc track1 heads
brodix hv1000 intake
1050 dominator on 110
9 inch spool with 488's
29.5 9 inch mickey slick
built 350 turbo manual valve body 5500 convertor
car was going 10.20 but didn't handle very good
gonna transfer this set up into my truck over this winter on caltracs
409malibu is offline   Reply With Quote
Old 10-11-2017, 07:58 AM   #316
lower50's
lower50's's Avatar
.040 sb 400
callies crank
6 in rods
That should be fun.
1951 MG TD
Old 12-14-2017, 07:34 PM   #317
turbotruck
went efi last winter. 2nd pass on efi, 15lbs of boost. did a little wheelie and ran a 6.43 @109 in the 1/8th. 1.4 60'
Old 12-30-2017, 01:46 AM   #318
hkrob
1974 C-10 Long Bed , Dual Tanks , Trailer Hitch ect.
350ci Edelbrock RPM Heads, Comp XR270, Edelbrock Air Gap, Edelbrock 600cfm.
Th350 2400 Stall
4.10 posi
MT ET Street SS 275/60/15
1/8 mi
ET 9.06
78 Mph
60’ 2.13
Was having carb issues had to baby it off the line. Should be in the high 8’s once i get my carb working right.
74 C-10 Long Bed 350ci/th350 4.10 posi
hkrob is offline   Reply With Quote
Old 01-14-2018, 01:31 PM   #319
nebdrummer
nebdrummer's Avatar
1.41 60ft
6.19@110 1/8th
9.87@140 1/4
760whp, 315 drag radial, 16lbs of boost. shooting for an 8 second this year!
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 01-15-2018, 09:53 PM   #320
lower50's
lower50's's Avatar
MMM boost
1951 MG TD
Old 06-27-2018, 11:26 AM   #321
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
60'...1.382
1/8...6.526
MPH..102.52
1/4...10.44
MPH...122.8
only 3rd time out with new engine. Truck needs some more suspension work.
launching on T-brake @ 3500 rpm tires @ 12psi
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 06-27-2018, 01:38 PM   #322
Super73
Super73's Avatar
Originally Posted by 68 C-10 KID View Post
60'...1.382
1/8...6.526
MPH..102.52
1/4...10.44
MPH...122.8
Looking good!!
Remind me, you have a TH400?
What tire gear?
Whats the verter flash too?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-27-2018, 04:31 PM   #323
68 C-10 KID
Mean Green
TH400
5500 flash on the verter
tire 29.5 11.5w
4:56
I still have the 1'' drop springs in the front from many years back.
I'm going to install Santhuff front springs before I go out again.
I still have the Moroso front springs I got from you many years ago on the shelf
AKA MEAN GREEN.
Old 12-04-2018, 10:29 PM   #324
Thamilktruck
Thamilktruck's Avatar
Dan Madewell
12/4/18
60' 1.56
1/8 ET 7.56
1/8 MPH 90
Year 1986
3860lbs
327 cubes
th350
coan 4500
150 shot
4:11
28x10.5
I drive it to highschool!
3860 lbs
327 sbc
Street Driven!
Tha Milk Truck
Thamilktruck is offline   Reply With Quote
Old 01-08-2019, 10:01 PM   #325
BadX
1.31 60
119.8
1/8 mile
3826 with driver
https://www.facebook.com/meancitycyc...267440/?type=3
BadX is offline   Reply With Quote
