Old 05-12-2013, 11:41 AM   #301
likaroc13
Rollin' Old Skool
Re: Show us you're seats
Originally Posted by Raceaprilia View Post
Seat is done. Blue vinyl with light grey cloth and some white inserts. Inspired by original custom seat out of 63.
looks nice!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-21-2014, 09:09 AM   #302
murphy98
murphy98's Avatar
My '62 with original seat & upholstery, just re-died the original turquoise colour to the moss green to match my interior cab colour. Black section of seat was just refreshed with black vinyl die. I did add a 1" high density foam pad between the seat springs and original foam to firm the seat up. Quite comfortable now, added 3 point seat belts as well.
murphy98 is offline   Reply With Quote
Old 01-21-2014, 01:05 PM   #303
61K10
61K10's Avatar
Murphy what's on the floor under the seat? some kind of rubber diamond plate looking stuff?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-21-2014, 01:50 PM   #304
murphy98
murphy98's Avatar
Yep! I'm a bit of a diamond plate nut! Love the look of it, since I was not too crazy about how the rubber floor mat just ends at the front edge of the seat I decided to get some rubber diamond plate mat & molded it to the contour of the floor under the seat. Worked out quite well, the sill plates also help keep it in place. I used the same stuff on the kick panel areas too. I also used similar stuff to line the inside of the bed, and used 1/8" steel diamond plate to skin over the old bed sides which had become quite distorted over the years. It also ties in well with the wrap around rear diamond plate bumper.
Old 01-21-2014, 03:20 PM   #305
NEWFISHER
NEWFISHER's Avatar
Here's the seat that was in the truck ( for sale in the classifieds ) and the 99 Silverado contoured bench seat with a "fitted" blanket. I drove it for a few weeks to make sure I liked the fit on a long trip and gave me time to order all of the material and the seat heaters. I also chopped down the frame to lower it in the cab for a better position and installed a couple large pockets in the rear panel including a shotgun sleeve.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 01-21-2014, 04:10 PM   #306
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
You really wanna see my seat.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-21-2014, 05:12 PM   #307
NEWFISHER
NEWFISHER's Avatar
At least the you keep the towel clean
GOD BLESS AMERICA!
Old 01-21-2014, 09:12 PM   #308
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
That picture was taken in the winter of last year....and the towel WAS clean then....I just cleaned it last Sunday!!!! HAHAHAHAHAHAHAH!!!!!!!!!
Old 01-21-2014, 10:37 PM   #309
slepysal
slepysal's Avatar
Here is what I have in mine. They are out of a Land Rover. A craigs list deal !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-22-2014, 02:07 PM   #310
earl84
Nice seats Newfisher, digging the shotgun sleeve. Anything difficult about putting in the seat heaters?
slepysal, those look VERY comfortable.
earl84 is offline   Reply With Quote
Old 01-22-2014, 02:31 PM   #311
NEWFISHER
NEWFISHER's Avatar
Most kits come with a metal tape that you hold the grid pads down to the seat foam with. I just glued them to the bare foam with contact cement so they wouldn't move around when the cover went on. The grid harnesses poke out the back and are virtually plug-and-play when you run a power wire to them. Once the seat was bolted down, I spent 2 hrs running a sub-panel off the fuse panel and wiring the heaters, installing the switches etc. I have since spent many hours with a warm back
GOD BLESS AMERICA!
Old 01-22-2014, 03:46 PM   #312
ljackson
ljackson's Avatar
I've been looking at seat heaters. Which brand and supplier do you choose?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 01-22-2014, 03:50 PM   #313
NEWFISHER
NEWFISHER's Avatar
I had been using Doorman kits, but wanted to try the guys on Ebay that are selling them around $55 shipped. It's the same as the Doorman kit for 3x them money. I would do the Ebay kits again.
GOD BLESS AMERICA!
Old 01-22-2014, 03:58 PM   #314
earl84
That's good info, Newfisher, thanks. Nothing like nice heated seats in the morning. Aaaaah.
Old 01-22-2014, 04:02 PM   #315
NEWFISHER
NEWFISHER's Avatar
Morning, noon, evening, etc. I haven't shut them off since installed!
GOD BLESS AMERICA!
Old 01-22-2014, 04:20 PM   #316
slepysal
slepysal's Avatar
[QUOTE= slepysal, those look VERY comfortable.[/QUOTE]
Thanks they are real comfortable. On any trip over 20 miles my butt would go numb with the old stock bench. I picked these up for $50.00, I had to drill 2 new holes and massage the mounting base a bit. The seatbelts are surplus Hummer units .
Old 01-22-2014, 06:26 PM   #317
ljackson
ljackson's Avatar
Thanks, I saw those and wondered if were any good. I'll order some.
Old 01-23-2014, 06:06 AM   #318
lostsheep
From an upholsterers experience and observation, one thing I can give ya'll a tip about.
The highest wear spot on most seats is the driver's side, outside bottom edge. Where the facing of the seat bottom and the seat side panel comes together.This is the place that the seat of your jeans/chinos/sweats/OP swim trunks or whatever you got rubs across when you enter and exit the cab. Hence, if there is welting (the cool looking rolled bead) around the seat facing and side panels, this is where it tends to come apart. The welting provides a lip to catch on any clothing and eventually the stitch that binds the seam together lets go.
More functional, and just as nice looking is a french seam. This seam is where the two pieces are seamed together, then the seam allowance inside is separated and a strip of material is stitched in, with a double needle. This means there is actually three lines of stiches holding the seam together. From the top side (the side you see). You see the seam, and a line of stitches on either side of it. It's a nice, classy and tough seam.
Next is a 'top-stitch'. Similar to a frenchy, but no backing cloth, and only one visible stitch. Typically the seam allowance on the back side is folded to one side (depending on which way you want the face to lie) and stitched through the three layers of fabric. Again, this is a good, tough seam, and more common than a frenchy.
Welting looks very nice, but there is only a single line of stitches holding the layers together. The top, two plys of welt covering and the side panel. Add with the drag of countless back pockets pulling on it, and you can see why they fail more. So, for a daily driver, the top-stitched or french seam for the seat bottom half is better. For a show type or occasional driver, a welted seam works and look trick, but won't last as long.
lostsheep is offline   Reply With Quote
Old 01-23-2014, 06:10 AM   #319
lostsheep
The black line around the seats here are an example of a welted seam. Eventually, with high use, that bottom will wear out at the welting. In the first pic you can see the breakdown of the edge from entering and exiting the vehicle. That top panel will go first. An upholsterer can replace just that panel. Just be sure to catch it before the foam gets tore up too bad. They charge more to repair the foam.
Nice seats, though!
Old 01-23-2014, 06:22 AM   #320
lostsheep
This seat bottom is french seamed. One problem with a frenchy is that it can be difficult to prevent a 'puckered' look, especially on the curves or angles. Usually you can leave a tag of the backing strip out at the end of the work, and pull it tight and hog ring it in place to alleviate the wrinkles. There's a few other tricks to help this as well.
Nice seat. I prefer the benches. I like having the girl sit next to me, not 3 feet away.
Old 01-23-2014, 08:02 PM   #321
slepysal
slepysal's Avatar
After 25 years of maraige I prefer the space. And for the 50.00 I paid well wort it
Old 01-24-2014, 12:44 AM   #322
lostsheep
Yup. $50 is a steal for those!
They look comfy, but watch sliding your gluts across that trouble spot.
Old 02-01-2014, 01:27 AM   #323
junk4cash
junk4cash's Avatar
Just picked my seat up today from the upholstery shop. Went with gold metal flake and white piping. Had them do my visors too. Matches my gold metal flake vintage wheel.
junk4cash is offline   Reply With Quote
Old 02-01-2014, 01:27 PM   #324
likaroc13
Rollin' Old Skool
Looks nice! Make sure to post up some more pics once installed.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 02-01-2014, 09:48 PM   #325
Jeff La
The cow hide seats I love, I may have to steal that one.
Jeff La is offline   Reply With Quote
