Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 07-26-2013, 07:38 PM   #301
mmiddle
mmiddle's Avatar
Re: Post your best budget mods! ($50 or less)
This is a great thread!
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline
Old 07-26-2013, 08:01 PM   #302
Mister-B
You can refresh your parking brake knob by painting it black, then rubbing the recessed letters with a white crayon, then shoot the whole thing with a coat of clear
Mister-B is offline
Old 07-26-2013, 08:03 PM   #303
Mister-B
Replace your cracked and worn washer hoses with some new ones from Oreillys. They are only like $5 a package, and requires 2
Mister-B is offline
Old 07-26-2013, 08:06 PM   #304
Mister-B
Redo your leaking and cracked drip rail with this cool stuff. It's a two part epoxy in one bottle that works in a regular caulk gun
Mister-B is offline
Old 07-26-2013, 08:08 PM   #305
Mister-B
Paint your black emblem areas and switch plate with small brushes and model paint
Mister-B is offline
Old 07-26-2013, 08:10 PM   #306
Mister-B
Buy an original jack from the yard. Paint it, and get a replacement sticker
Mister-B is offline
Old 07-26-2013, 08:14 PM   #307
Mister-B
Replace your old, non matching, split ring spare tire with a modern matching steelie from the junk yard and a good used tire the same size as your other four tires
Mister-B is offline
Old 07-26-2013, 08:16 PM   #308
Mister-B
Paint your pedal arms, and buy new rubber pedal covers and gas pedal
Mister-B is offline
Old 07-26-2013, 08:18 PM   #309
Mister-B
Get new steelies from the yard. Wire cup them and paint them yourself.
Mister-B is offline
Old 07-26-2013, 08:19 PM   #310
Mister-B
Paint your dash.
Go from this
To this ( ignore the new pad)
Mister-B is offline
Old 08-14-2013, 08:22 AM   #311
Low Elco
This a great thread!
Low Elco is offline
Old 08-14-2013, 03:12 PM   #312
twisty
twisty's Avatar
Originally Posted by 70BLAZERX2 View Post
Get a HEI distributor advance curve kit...change it to the lightest springs in the kit and get a 1977 corvette vacuum advance unit.
These 2 will cost about $35 and will gain use about 15 horsepower out of your smallblock with about 30 minutes to put them in...and you will feel the difference it will make..Under $50
Originally Posted by oldblue1968chevy View Post
Whats so much more special about the corvette vac can? jw not trying to be smart...
It had a totally different power curve in it..for the vette camshaft.
It dont hurt to ask..
It will wake up even a 86 stock 305 in a 4x4...make it pull like a 350...Yes it does work..and its cheap.
is there a diagram for the vacuum line set up for the 250 i6 motor? mine is all disconnected, id like to replace all the lines and stuff, may as well get the better can and stuff while im doing that.
twisty is offline
Old 08-14-2013, 09:43 PM   #313
bobbydigital
bobbydigital's Avatar
subscribing to keep up with this one
bobbydigital is offline
Old 08-14-2013, 10:31 PM   #314
slow-1
slow-1's Avatar
$15 seat from CL...used scrap metal to adapt brackets, spent $3 on long enough bolts....rides like a Cadillac!
http://67-72chevytrucks.com/vboard/s...d.php?t=590535
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline
Old 08-14-2013, 10:32 PM   #315
BrianG
BrianG's Avatar
[QUOTE=Mister-B;6191600]Redo your leaking and cracked drip rail with this cool stuff. It's a two part epoxy in one bottle that works in a regular caulk gun
Posted via Mobile Device[/QUOTE
Hey, I'd like to hear more about the drip rail redo process. How did you go about removing the old, what were the tricks to putting the stuff on, etc. does it run on the vertical parts, etc. etc... great tip, and would love to love to learn more. - oh, also, what exactly is it
Thanks!!!
BrianG is offline
Old 08-15-2013, 02:16 AM   #316
Mister-B
[quote=BrianG;6221704]
Thanks!!!
No problem. I did a whole write up how to with pictures, explanations, and tips. If you search my old posts for "drip rail caulk", you'll see it. Take a look at that, and if you still need help, let me know
Mister-B is offline
Old 08-15-2013, 09:06 AM   #317
slow-1
slow-1's Avatar
Link to Mr. B's repair thread...look near the end for his actual repair.
http://67-72chevytrucks.com/vboard/s...rip+rail+caulk
Link to another thread with some more info.
http://67-72chevytrucks.com/vboard/s...d.php?t=592096
slow-1 is offline
Old 08-16-2013, 01:06 AM   #318
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I may have posted about this before. But for less than fifty bucks, this is the best cosmetic mod I think I've ever done...
Well, the wood bed that I put in cost less than that, but I had the wood. No fair.
I stumbled on this on my own. But I think other Members (Maybe Mr. B...and others) have written about it.
I just washed the spray on bedliner...which was very, very "blotchy" (sorry, no "before" pics), masked up,
and sprayed the stuff in. I'm going to keep it as the finished surface on the inside of the bed.
I think it took three cans, tailgate and all.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 08-16-2013, 08:49 AM   #319
BrianG
BrianG's Avatar
- Thanks again, I was about to do it soon with a single part tube of body sealer that I bought from NAPA. I now think I'll pick some of that two part self leveling stuff up and save the other for different parts of the truck.
Another quick question though... well, maybe two. first, are there any concerns about sag on the vertical edges by the door. Seems that being self leveling, it would tend to sag. Second, is there a good way to make sure that the chrome drip rail trim will still fit. I was thinking about taking a grinder to one of those yellow Bondo applicator throw away things that you can get. Grinding it down so that I could run it along the drip rail and then it would 'scrape' away any wet filler that is going to be an issue for the trim. In a sense, shaping a special template. Does that make any sense.
Just wondered your thoughts on these two things. Thanks again!
BrianG is offline
Old 08-31-2013, 08:37 PM   #320
FLDBRED
Love this Thread, thought I'd bring it back up!
FLDBRED is offline
Old 08-31-2013, 09:18 PM   #321
67chevemall
67chevemall's Avatar
My interior was a great deal.
Seats were $10 for bolts and gas
The wood cluster was $5 rosewood stock.
7 gauges were elbow grease(except the tach but that came DOA sucks)
The head smash pad was $10
Door panels and head visors were free.
And my Defrost to floor switch was pure inovation.
$20 in shrahdar valves saved me a $1000 in gear.
Tremclad and spool of mig wire.
$50 interior
happy happy happy
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline
Old 08-31-2013, 09:21 PM   #322
67chevemall
Couple more. Beer is good and this helps save $ from the $tripper joint.
From this thread alone : I am
getting the plastic clips for my wipers so I can finally clean the windows on the I 90
Get the 5 LED 94bulb replacments. that is just awsome to see the gauges
Head light relays is a now must. And probabaly rewire the truck now too while at the wire store.
Cheers to a great site.
