02-06-2012, 10:17 PM | #301 |
Re: No Limit's "K-10"
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
02-07-2012, 12:04 AM | #302 |
Those wheels are just awesome
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627 Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
02-07-2012, 12:19 AM | #303 |
WOW, those look great.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-07-2012, 11:59 AM | #304 |
I'm just glad to be here!
Those wheel are the bomb. Is the center coated gray? Can't wait for more updates and to see this one complete in person.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-07-2012, 12:37 PM | #305 |
Thanks for all the positive feedback. This is my first ever attemp at making wheels. There is a lot to learn, but it was kinda fun. when the centers were finished (machined), we took then to a blaster and had then go hot & heavy on them to soften the edges, then they were powder coated grey with a semi-flat clear. I wanted brushed hops, but was over ruled. I like 'em. "Loco-Motive"'s.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
02-07-2012, 10:12 PM | #306 |
Rob, how wide are you running in the front?
02-08-2012, 12:46 PM | #307 |
Definately 18x12 with a 335 out back. Trying for that up front too, or 18x11, with a 315. Fender clearance is an issue.
02-08-2012, 04:17 PM | #308 |
OK, so this is how we fixed the wheel/tire clearance issues. The new openings are 2 1/2" higher and appx 1 1/2" wider. We tried to make 'em look stock-ish, and blend them into the stock body lines. If there were Can-Am trucks in 1972, this is what they would have looked like.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! Last edited by robnolimit; 02-08-2012 at 04:42 PM. |
02-08-2012, 04:38 PM | #309 |
02-08-2012, 04:41 PM | #310 |
67cheby
well now that 18x11 should fit !!
02-08-2012, 05:16 PM | #311 |
Still plays with trucks
Very nice. The flare blends well into the stock body lines.
Are you going to do something similar out back so it matches?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-08-2012, 07:38 PM | #312 |
the flare looks clean.did you use the stock openings and added a strip?
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
02-08-2012, 08:42 PM | #313 |
Grill
02-08-2012, 08:44 PM | #314 |
Update
02-08-2012, 09:22 PM | #315 |
I wish, we built them from scratch, it took about 6 hrs each. And yes, I will have to do the back to match.
02-08-2012, 09:33 PM | #316 |
6>8 Plugless........
Rob, that looks great! Those wheels are killer! I'm assuming you're going to be cutting holes in the grill fillers you installed?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-08-2012, 09:59 PM | #317 |
......baddest k10 ever!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-08-2012, 10:42 PM | #318 |
Junk Yartist
there is that piece on the roof again! Ever gonna clue us into what it's for? can you explain the grille a little bit also?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
02-08-2012, 10:44 PM | #319 |
Excellent craftsmanship! Looking forward to following this
02-08-2012, 10:48 PM | #320 |
GEARHEAD
That grill looks heavy. Those little holes behind the headlights won't lighten that front end much. I'd use it to make a mold to form one of carbon fiber. I'm only half joking. I've been reading up and watching videos on carbon fiber parts forming. It's not that hard once you have collected the proper materials. That methad could be used to form the fender flares also, or whole fenders, whatever. Light weight and easy to repair.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
02-08-2012, 10:51 PM | #321 |
WOW JUST WOW!! how in hell have i been missing this build i need to start hanging out here on the 67-72 area i went through the whole build bro and i got to tell you. you got some mad skills there i dig all the work you done to this k10 great job so far and keep the updates coming im staying tuned for this one......
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... |
02-08-2012, 11:54 PM | #322 |
Bad a$$!!!
02-09-2012, 12:22 AM | #323 | |
i think that's gonna look sweeeet with those rim's and the flare's they just seem to suit each other for some reason |
02-09-2012, 09:45 AM | #324 |
Ya know, with as many holes that your drilling in that thing, maybe paint it yellow or yellow-orange and call it Swiss Cheese!
Remember the Cheese Whiz '55 back in the 80's? Truck is looking awesome! - Can't wait to see it runnin!
Dave aka "Wild" Current truck "Ida Mae" 71 K5 Blazer Former Trucks "Loretta" 71 Longbed (AZ) "Tanya" 69 Stepside (AZ) "Ferdinand" 71 Longhorn (SD) "Patches" 67 Panel (IA/ KY) "Rosita" 68 C30 (KY) Instagram @Wildforwheels @k5_klub @c10university Profile pic provided by Jeff Sundance |
02-09-2012, 05:29 PM | #325 |
lets see, no more holes in the grill. Two for brake ducts and one for air cleaner inlet. We are well over the 250 hr mark, and closing in on the 500. I'd like carbon fiber, but know nothing about it. It would be cool to have it all steel, but I know it's heavier. The mistery panl is still in play, You'll see it installed soon.
