Old 11-12-2012, 09:21 PM   #301
Rusbuilt
Rusbuilt's Avatar
Re: Project 78 High Sierra
Originally Posted by JRANGER View Post
Electrical went crazy and after pulling ever fuse i figured out that the hazards should not be used....It will make everything go wonky so the truck is back up and working again but i have no clue whats wrong with the hazard setup.....weird
On the bright side with the help of RUSBUILT i scored 2 amazingly solid fenders off a 1980 C20....Ill have to weld some screw holes used to hold the trim on and a couple small scratches and dings but they are awesome! No Rust at all!!!!
Also decided to go back to black gauges because it looks better but i painted the needles silver..On top of that a new cluster housing because the old one had one bad light connection plate that caused issue. So i painted the new housing white
Enjoyed helping out today Jeff!!! lol fenders on the bed my wife would die!! haha
Rusbuilt is offline   Reply With Quote
Old 11-12-2012, 09:24 PM   #302
JRANGER
JRANGER's Avatar
lol spare bed...and actually its just an air matress
JRANGER is offline   Reply With Quote
Old 11-12-2012, 09:25 PM   #303
JRANGER
JRANGER's Avatar
the results of the swap back to black gauges with silver needles
Old 11-13-2012, 02:10 AM   #304
1978chevybigten
1978chevybigten's Avatar
Nice man! And try replacing the blinker switch. That's why my light went all crazy.
1978 big ten 350/350:chevy
1978chevybigten is offline   Reply With Quote
Old 11-16-2012, 11:41 AM   #305
JRANGER
JRANGER's Avatar
Ordered some new battery terminals since I have been having some electrical problems...
Old 11-16-2012, 01:03 PM   #306
JRANGER
JRANGER's Avatar
Also just ordered a Vacuum/Fuel Test Gauge so I can try to get my carb tuned properly
Old 11-16-2012, 01:41 PM   #307
77ChevySharkBite
77ChevySharkBite's Avatar
Looks suuuuhweeet!!!! Must say its been a while since I checked out your build thread, it's coming along very very nice I must say, I've been trying to get my garage cleaned and get my monster put in there so I actually have level ground to work on.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 11-16-2012, 01:46 PM   #308
JRANGER
JRANGER's Avatar
I understand im still working on my workshop so not as much done as I would like...Need to workshop for the winter so i can do misc painting and etc
Old 11-16-2012, 01:49 PM   #309
77ChevySharkBite
you and me both, I'm trying to just get mine garaged so I can really start stripping mine down, part of a project nothing is finished overnight takes time and as well all know money. Your workshop looks awesome!!
Korwin
Old 11-16-2012, 01:52 PM   #310
JRANGER
JRANGER's Avatar
Thanks wish it was big enough to fit the truck in lol
Old 11-16-2012, 02:08 PM   #311
77ChevySharkBite
lol I bet, so you have it there so you can store parts and such, or whats the exact role of the workshop?\
Korwin
Old 11-16-2012, 02:29 PM   #312
JRANGER
JRANGER's Avatar
Storage for Parts, Tools, Painting, and a place to work on everything....Im putting in a Wood Burning stove and electrical
Old 11-16-2012, 02:31 PM   #313
77ChevySharkBite
Very very nice, I'm thinking about building a table of some sort to throw all my parts and other crap on
Korwin
Old 11-16-2012, 02:33 PM   #314
JRANGER
JRANGER's Avatar
Yeah ill be building some tables too!! lol
Hangers for painting etc
Old 11-16-2012, 02:41 PM   #315
77ChevySharkBite
Yep, just a matter of getting it done haha once I get the rest of the garage cleaned out and the truck in there thats when I'll decide on how big I want the table.
Korwin
Old 11-19-2012, 10:54 AM   #316
JRANGER
JRANGER's Avatar
I figure its about time to Re-Visit my to do list and update it...
1. Cut and Weld in new Cab Corners
2. Find another Driver side wheel well
3. Finish welding inner rockers and add a few patches
4. Replace CD Deck...Its Faceplate wiggles too much (Ordered)
5. Repair/weld Bed Wheel arches
6. Replace Rear wheel wells
7. Get new Rear Bumper
8. Replace More Bushings
9. Tune Holley Double Pumper Carb
10. Smooth out the suspension for better ride
11. Strip all paint
12. Primer & Paint Blitz Black
13. Black out grille
14. Paint Rally Wheels
15. Get new tires
16. Replace Transmission Tube (Siliconed in and not mounted to firewall)
17. Fix Oil Leaks
18. Replace Valve Cover Gasgets
19. Install AC Compressor and Lines
20. Get the E-Brake Working
21. Get better Acceleration.....Clueless on this...May be geared too low
22. Bleed and Flush Brakes
23. Fix Leaky Window or Cowl on drivers side...ERG!!!!
24. Replace Vent Window Seals
25. Replace my hack job replacement of regular window seals lol
26. Get longer RCA and clean all wiring up with ties
27. Replace Seat belts with Black ones
28. Replace Door Panels
29. Figure out Why Accessory Fuse is grounding out
30. Clean Engine bay
31. Replace hood hinges (Got a pair in workshop)
32... Line doors back up straight
32...More
Man my list got bigger and half the original stuff was done sheesh
Old 11-19-2012, 10:57 AM   #317
77ChevySharkBite
Hahaha its okay I don't want to really think about my list right now haha I'm sure it'll look just like that if not worse.
Korwin
Old 11-19-2012, 12:14 PM   #318
Rusbuilt
Rusbuilt's Avatar
Looks like a lot to do! I was hoping to see those fenders on by now!! lol
Old 11-19-2012, 12:37 PM   #319
JRANGER
JRANGER's Avatar
I welded the holes in them but I want to strip them down and put primer on them before I install them. Plus I will paint the insides too.....
Didn't have much time to work on it this weekend...FML.... Plus i didnt have you around with those handy Needle Nose Vice Grip pliers to get another bolt out LOL!!!!
Old 11-20-2012, 01:24 AM   #320
thelonerife
thelonerife's Avatar
I thought you said you needed fenders and saw these
http://clarksville.craigslist.org/pts/3405556322.html
thelonerife is offline   Reply With Quote
Old 11-20-2012, 01:28 AM   #321
JRANGER
JRANGER's Avatar
Well dang but I actually just got a solid pair from Pull a part...but thats a hell of a deal
Old 11-20-2012, 01:40 AM   #322
thelonerife
Oh ok. lmk if you want them and I'll pick them up for ya.
Old 11-20-2012, 01:43 AM   #323
JRANGER
JRANGER's Avatar
Appreciate it man! Im good though
Thanks!
Old 11-21-2012, 07:59 PM   #324
JRANGER
JRANGER's Avatar
So I have went through a bunch of extra clusters sitting around and I had an idea....Why do I have to have green blinkers?!!!!! So I had to change it, I went and took the extra "High Beam" Plastic and cut them into blinker plastics so now my blinkers are blue
Old 11-21-2012, 08:03 PM   #325
77ChevySharkBite
Nice!!! Looks clean man, I think I want some red ones!! I have to wait though I just bought my mufflers hopefully have an exhaust done this weekend
Korwin
