01-29-2013, 12:55 AM | #301 | |
The 60-66 GMC/Pontiac guy....
Re: How about some pics of Static dropped 60-66
http://67-72chevytrucks.com/vboard/member.php?u=30278 Since your frame is a leaf, don't get talked into notching it... that will really weaken the leaf frame... You can get her pretty low without doing a C-notch.
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
01-29-2013, 03:30 AM | #302 |
cb... I hear you and speaking as an old-f@rt, dad, and Grandad, they are all that really matters, but in the balance of things you will get there and these shouldn't be hard or expensive to fab even if nobody is making them.
Tube diameter, saddle width, and so on... could be cut out on the cheap and the results would be dramatic. I'm also a fan of CaptFab's stuff. keep us posted and hug the family. rg Last edited by robber grin; 01-29-2013 at 03:30 AM. Reason: gramar |
01-30-2013, 11:56 AM | #303 |
Beautiful truck!! I have a 63 LB and am looking to buy a 4/6 drop and disc brake conversion from Early Classic as well. I was wondering how you liked your kit for them and how the install went? Thanks for any info.
01-31-2013, 11:38 PM | #304 |
02-04-2013, 09:33 AM | #305 | |
http://www.performanceonline.com/che...springs-parts/ They have mono leaf springs and drop shakles for your leaf truck. Hope it helps
02-04-2013, 11:38 AM | #306 |
Sunday I got the front drop done - it's on the ground finally and it's SOOO nice to have a rolling truck again.
62 C10 - 2 1/2" Bell drop spindles and 3" drop coils on a 78 burb clip. Steering section is next - Then front sway bar. rg |
02-07-2013, 02:51 AM | #307 |
This was my 65 shortbed. Built it in 1994/95. Sold it in 97.
350/350 combo 74 control arms with 5 lug disc 72 rear 12 bolt with drums 2.5" Western Chassis spindles with 3" Eibach coils front 5" Eibach coils with 2' blocks in rear Doetch Tech shocks all 4 corners 1 ton swaybar 15x7 and 15x10 Welds with 235/60 and 275/60 BFGs Lip stick red with 93 Silverado bench seat gray Best handling truck Ive ever owned. Sorry for poor quality pic... |
02-09-2013, 03:09 PM | #308 |
My 62.... I wished I would have just bagged it.... This mild static drop wasn't sufficient..
My 63.... paid the price for my previous wishes. |
02-11-2013, 10:27 AM | #309 | |
Posted via Mobile Device |
02-11-2013, 10:28 AM | #310 |
Like*
02-12-2013, 05:08 PM | #311 | |
02-12-2013, 07:34 PM | #312 |
Thanks! Here is an updated pic.
02-23-2013, 09:37 PM | #313 |
My daily, plan on going 1 in lower all around.-Jimmy-
NOMADSC.C. |
02-24-2013, 12:15 PM | #314 |
Nice!
02-24-2013, 03:29 PM | #315 |
Hi
I have a 1965 C20. I want to lower it ,but am still a novice at this type of stuff. I want to lower it about 4 inches front and back,and want to know can this be done just by changes coils?How will it affect handling?and stance?Please help!!Thanks |
02-24-2013, 03:55 PM | #316 | |
P.S. When you have questions, you will get plently of help and different kinds of advice, but you should post your question in the right place. This is a "picture thread" so some may get a little cranky to see questions, and requests for advice here. Welcome to the forum, feel free to PM me if you like, I would be happy to help you learn your way around here.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
02-25-2013, 12:19 AM | #317 |
66 C-10 Small Rake will be going to wider rear and narrower front wheels and tires. A mild Pro Street look.
02-25-2013, 09:29 AM | #318 |
Nice truck! No clutter, just black, and chrome, I like it!
02-26-2013, 03:19 AM | #319 |
here is my turd lowered 5 in the back and 4 in the front with springs
02-26-2013, 07:23 AM | #320 | |
Current project (My Maria) 62 Chevrolet LWB stepside 235 inline 6 cylinder http://67-72chevytrucks.com/vboard/s...d.php?t=569873 Dano |
02-26-2013, 07:40 AM | #321 |
lugnutking.com or you can get them on ebay, you have to widen the center hole on your wheels to get them to slip through and fit over the wheel hubs..
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
03-03-2013, 05:49 PM | #322 |
66 C20 Longbed Stepside
2" CPP springs in the front 2" blocks in the back before and after... |
03-04-2013, 01:24 AM | #323 |
63 all components from CPP.
2.5 drop spindle with 1" drop coil 4" drop coils out back 18" x 8" Gragars SS 245/45/60 front and rear Could have went wider rim and tire on rear but looks good. Rear adjustable trac bar Front and rear sway bar. Lowering shocks all four coners Rear shock relocation kit for lowered suspension Posted via Mobile Device Posted via Mobile Device
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 Last edited by Trsmotrhed; 03-04-2013 at 01:31 AM. Reason: added more to description |
03-04-2013, 01:42 AM | #324 | |
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
03-04-2013, 01:03 PM | #325 |
Is that 5.5 inches in the front or 2.5 in the front and 3 in the rear? If it is 5.5 in the front that is really low have fun with speed bumps.
