Old 10-31-2014, 11:03 PM   #301
BigRed76
BigRed76's Avatar
Re: 67-72 Electric speedo
Has anyone found a paint that is the correct color for painting the new speedo numbers? I know ls1nova71 said he was just mixing paint to make the correct color, I'm just wondering if there's a premade color that will work...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 12-01-2014, 07:22 PM   #302
TBONE1964
Cluster King
TBONE1964's Avatar
I think Eric was using testers model paint. He used green and white and mixed them until he got the color right on the money which is the way I would do it.
If you want something in a spray can ready, I would go with a Jade Satin Krylon.
Hope this helps.
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 12-01-2014, 07:36 PM   #303
TBONE1964
Cluster King
TBONE1964's Avatar
Hi Eric,
I am finally building my first electronic speedometer conversion cluster for a customer and have some questions for you.
First off, I wanted to let you know that I have found a way that works well that eliminates the speedometer mounting plate. Of course it requires some fabrication to the stock tin but in the end it will be all one piece. Not to take away anything you have done, just trying a different method.
Also my customer did not want a trip so that made my work a bit easier.
Now for my questions. I bought a gauge cluster for a 1996 S-10 from ebay. The high MPH on it is 100 MPH. Is this OK with the 120 stencil you provide? Will the speedometer actually work and be accurate over 100 MPH?
My other question was regarding testing the speedometer without a VSS signal. I have heard if you put power and ground to it, it will move to zero regardless of where the needle is positioned. Is this true?
I am trying to make sure I get this cluster built so that it will work for my customer. I may be able to find someone with a later model vehicle with VSS to test it on but I cannot say for sure at this time.
I will try to post some photos of my work soon. I had a camera mishap and don't care for my phone camera.
Hope you are well,
Take care,
Tom
Old 12-02-2014, 12:21 AM   #304
BigRed76
BigRed76's Avatar
Hope this helps.
Tom
Thanks Tom, I was hoping to find something in a spray can, and just from pictures that jade satin looks real close.
My electric speedo cluster is still in the works but I went the route of modifying the tin to eliminate the plate like you mentioned you were doing for a customer.
Zach
Old 12-02-2014, 12:31 AM   #305
ls1nova71
ls1nova71's Avatar
I have never found anything that was an exact match, but then I'm picky, so I knew that mixing it would get the best results.
Hi Eric,
Interested in how you mounted it. My first one I didn't use the mounting plate, and got it to work, but making the mount seemed to be the better way. Post some pics when you get a chance.
The S10 speedos are all 100mph. The reason for making the 67-72 speedo 120mph is to get the sweep to match. It should be accurate above 100mph since the sweep of the needle is linear in relation to the face/numbers. I have never checked it above 100 to be honest though. I have checked it to about 90mhp or so and it's pretty accurate.
When you put power to the speedo, the needle will move to the 0mhp mark, you have to do this when putting the needle back on, or you may get the needle either too high or too low. Ideally, you want the needle to rest at 0mhp, with the needle just touching the little plastic stop.
The only way I know to test it is to hook it up to a vehicle and run it. I have a 2003 Pontiac Sunfire that I use to test mine. I just unhook the cruise control module and put the wires in to the connector for power, ground, and VSS, it works great since then I not only get to see it work, I can verify how accurate it is by comparing it to the speedo in the car. If you can find a later modle GM car with a cable drive cruise control, that would be the easiest way to make sure it is going to be right on the money.
Hope you are well,
Take care,
Tom
Hey Tom, I answered your questions in the bold text. If you need anymore help, don't hesitate to ask.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-03-2014, 12:48 PM   #306
TBONE1964
Cluster King
TBONE1964's Avatar
Hi Eric,
I appreciate the information. I will get some photos posted when I get time and the camera working. I am also working on making a wiring harness that I think will work nice.
I have limited time to work on this so my progress is slow.
Stay tuned...
Thanks again,
Tom
Old 01-06-2015, 11:07 AM   #307
tinsoldier
tinsoldier's Avatar
Is there anymore faceplate available? I am interested in purchasing one if possible.
tinsoldier is offline   Reply With Quote
Old 01-06-2015, 12:42 PM   #308
elimontfort
elimontfort's Avatar
Also interested in a faceplate.
elimontfort is offline   Reply With Quote
Old 01-06-2015, 04:46 PM   #309
ls1nova71
ls1nova71's Avatar
PMs sent
Old 01-22-2015, 12:06 AM   #310
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Eric, do you still have any of these? Debating this route on my dmax swap. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-22-2015, 12:35 AM   #311
ls1nova71
ls1nova71's Avatar
I will have some as soon as the printer gets the blade it takes to cut the number parts out of the stencil. I'm having a few more made up because I keep selling the ones I have stashed back for my own projects. I'm currently putting together 2 clusters so I won't have that problem anymore.
Old 02-08-2015, 08:48 PM   #312
Beaumont@
I may have missed after reading the threads but I am curious if this mod will work with a 4L80e with a standalone controller ie. TCI EZ-TCU and a gen 1 carbureted engine? If so I would be interested in one of your kits.
Beaumont@ is offline   Reply With Quote
Old 02-09-2015, 10:04 PM   #313
Beaumont@
Ah never mind I found out they have an output wire for the speedometer. I'm down for a set if they're available
Old 02-09-2015, 10:13 PM   #314
ls1nova71
ls1nova71's Avatar
At this time, I am not able to get the template for painting the numbers on the lens. I have been in contact with another member on here that thinks he may be able to do them. If it works out I should be able to get you a set, I will let you know if/when they are available again. Sorry for any inconvenience.
Old 02-10-2015, 03:36 PM   #315
Marty68
i may do this after i kill a couple other jobs.
Marty68 is offline   Reply With Quote
Old 02-12-2015, 08:01 PM   #316
eagleuh1
eagleuh1's Avatar
Anybody found a source for the light sockets other than junk yard? Only thing lacking on mine. Thanks. Jim
eagleuh1 is offline   Reply With Quote
Old 02-12-2015, 09:03 PM   #317
68c10airstream
68c10airstream's Avatar
Hi eagleuh1, look on ebay under the search "t10 194 heavy duty" They have them in 10 quantity. I haven't received mine yet but they are 2 wire twist lock sockets. Very cheap.
68c10airstream is offline   Reply With Quote
Old 02-28-2015, 12:48 AM   #318
68c10airstream
Got the 2 wire twist sockets in the other day. Close but no cigar, can't use them. Will try something else
Old 02-28-2015, 12:52 PM   #319
ls1nova71
ls1nova71's Avatar
PM sent
Old 02-28-2015, 12:55 PM   #320
elf w/capital T
The twist sockets everyone is using... i was told that some 88-98 sidemarker lights fit...??? Anyone confirm this?
elf w/capital T is offline   Reply With Quote
Old 03-30-2015, 11:22 PM   #321
68c10airstream
I found the parts tag for the 2 wire sockets i used for the cluster project. Made by STANDARD MOTOR PRODUCTS. HP 4060, the hp= handy pack. Application says AMC 70-88, GM 69-92, Ford 70-90. These sockets are about $4.00 each, 2 leads, firm rubber body with 4 latching lugs. Our 67-72 dash holes only have 2 notches for the lugs. I removed 2 lugs using my exacto knife. I chose these because i had green led's for dash lights that were made in the #194 bulb style. Each socket having 2 leads guaranteed good grounding for each led. I wasn't able to use the printed circuit anyway so i wired up everything individually. I needed at least one 2 lead socket for the cruise light i added in my cluster because the cruise box switches on a ground when it is engaged. (i removed the word "brake" lens and added the word "cruise" lens in it's place) The only issue with using the green led's are trying to dim them, it's all or nothing as they are not designed to be in a dimming application. I have eyes getting older and the additional brightness is nice.
Old 03-30-2015, 11:34 PM   #322
68c10airstream
Sorry i omitted in the above post is that the HP 4060 are a side marker replacement socket, that's why they are a 4 lug style.
Old 04-03-2015, 02:34 AM   #323
eagleuh1
eagleuh1's Avatar
Thanks 68 Airstream. Will be ordering these tommorrow. As a side. Does your 68 Airstream still sport the Armstrong AC it was born with? Just ordered a new fan motor for mine. It gave up the smoke while working nights, trying to sleep days near Baton Rouge La. Last week. Trying to keep it working still. Jim
Old 04-03-2015, 02:44 AM   #324
68c10airstream
This 1966 caravelle is without a/c but my prior 68 21' did have Armstrong a/c and the fan quit also. Sourced a replacement and it still has the original refrigerant charge and still gets cold. Love airstreams, nothing like them. My wife and I retire in 1 3/4 years, truck to finish, interior redo on the caravelle and then serious camping in the duo.
Old 04-03-2015, 06:00 PM   #325
eagleuh1
eagleuh1's Avatar
Sounds like a great plan. I've got to finish my truck as well, but have a few more years than you to retire. Good luck. Jim
