Old 04-21-2013, 12:16 PM   #301
oilyrag80
oilyrag80's Avatar
Re: Brave or crazy? crewcab build
Originally Posted by jbclassix View Post
Do you have your hinges attached in that picture?
No they are not door is just sitting there, its just held in by the latch.
It was getting late and I just had to check it out before I was done for the day.
The door fits in the hole but is nowhere near lining up, still have a little trimming
to do and alot of adjusting.
oilyrag80 is offline   Reply With Quote
Old 04-22-2013, 09:36 PM   #302
oilyrag80
oilyrag80's Avatar
Ok, I could not wait until the weekend I had to know if this was going to work.
I got home from work drilled a few holes, now I have a swinging 4th door.
Still needs alot of work and adjustment but it works and fits pretty good as well.
Old 04-22-2013, 09:38 PM   #303
oilyrag80
oilyrag80's Avatar
few more
Old 04-22-2013, 09:39 PM   #304
Rusbuilt
Rusbuilt's Avatar
Wow bro! Looks great!
Rusbuilt is offline   Reply With Quote
Old 04-22-2013, 09:51 PM   #305
jbclassix
Junk Yartist
jbclassix's Avatar
Did you move the hinges closer together like on the 3rd door?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-22-2013, 09:58 PM   #306
lolife99
67-72 parts collector,…
lolife99's Avatar
Amazing work!
Keith
Convert to disc brakes.
Old 04-22-2013, 10:11 PM   #307
oilyrag80
oilyrag80's Avatar
No I did not see any reason too, the hinge sits flush on b pillar and it clears the inner latch. I thought I'd give it a shot, seems to work ok.
Old 04-22-2013, 10:44 PM   #308
bodydropped68
bodydropped68's Avatar
Looking awesome !!!!!!!!!!!!!!!
bodydropped68 is offline   Reply With Quote
Old 04-22-2013, 11:03 PM   #309
oilyrag80
oilyrag80's Avatar
Here is a pic of upper hinge before I drilled holes
Old 04-22-2013, 11:07 PM   #310
Xeen
Xeen's Avatar
Impressive work man.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 04-23-2013, 07:21 AM   #311
ThreeQtr
I think it's time for a video, doors open, doors shut (think of this as being said from that guy on 'Karate Kid', the original one "Wipe wax on ,wipe off." )
Just kiddin, sorta, looks fantastic ! Bravo.
ThreeQtr is offline   Reply With Quote
Old 04-23-2013, 10:43 AM   #312
jbclassix
Junk Yartist
jbclassix's Avatar
That is pretty awesome that it worked that way!
I like the way you did your door better than the way I did mine and my brothers. On both of them I used the rear of a right door and then chopped the front of a left door for the hinge section. I thought there was a reason why I moved the hinges closer on my Burb to match the 3rd door, but i guess it was moot. I may just copy you for the hinges on my brothers door, and save me some welding.
After I bought my brake, I started to think that it would have been easier to use Suburban stuff and just flip it. But we had a real hard time finding one that we could get parts from. Donor parts are definitely the way to go.
-Jeremy
Rebuilding an NP205
Old 04-23-2013, 09:30 PM   #313
oilyrag80
oilyrag80's Avatar
Yea the door was eaiser then I thought it would be I am still going to use part of a passenger door as part of the finishing details. I was planning on moving the upper hinge down but when I mocked it up it looked like it would work so I gave it a shot. I used as much off the doner sub as I could I was just lucky my buddy had one i could cut up. The weather is about to get ugly around here I just hope I can keep up the pace.
Old 04-24-2013, 11:53 AM   #314
MattSt
MattSt's Avatar
Originally Posted by oilyrag80 View Post
Havent got that far yet its just tacked together and sitting there.
I think Im just going to double layer it and weld down the seam to look factoryish
at least thats the plan.
This is the way I have always done it: http://67-72chevytrucks.com/vboard/s...d.php?t=497761
It's the fastest method with the best looking results IMO. Build is looking better every day! I wish I was brave/crazy enough to do one.
1970 GMC Custom Camper 396, A/C, Tach
1978 Chevy 1 ton 350, NV4500, D60/14 bolt (drivetrain donor for the GMC)
MattSt is offline   Reply With Quote
Old 04-24-2013, 01:03 PM   #315
Low Elco
Lookin' great!
Low Elco is offline   Reply With Quote
Old 04-24-2013, 01:25 PM   #316
67cheby
67cheby
67cheby's Avatar
you are making this look easy man, nice work !
67cheby is offline   Reply With Quote
Old 04-24-2013, 09:26 PM   #317
oilyrag80
oilyrag80's Avatar
Amazing work!
Originally Posted by Low Elco View Post
Lookin' great!
Thanks! Its good to know you guys are following along.
Old 05-07-2013, 05:04 PM   #318
frostbyte
Junior Member
your door is turning out awesome. ...keep going man
frostbyte is offline   Reply With Quote
Old 05-07-2013, 05:30 PM   #319
vegadesign
vegadesign's Avatar
subscribed! badass build i lolove the craftsman ship of these crewcab builds
keep up the good work i cant wait to see more
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 05-07-2013, 06:15 PM   #320
rambler
MOVE OVER
rambler's Avatar
just saw this,awesome work !
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 05-09-2013, 09:27 PM   #321
oilyrag80
oilyrag80's Avatar
Thanks guys, havent had much time the last few weekends I had to work on my
dad's f**d powerstroke but I hope to start back on it tomorrow.
Old 05-11-2013, 11:54 AM   #322
jbclassix
Junk Yartist
jbclassix's Avatar
Hey man. You mind posting a picture of the header area above your 3rd (right rear) door where the cabs are welded together? On mine I ended up cutting all the way to the B-pillar and adding that section from another pick-up. I checked on my suburban compared to my brothers cab and they both are different than above the front doors.
This is proving to be a pain to get lined up just right, by the way.
-Jeremy
Rebuilding an NP205
Old 05-11-2013, 12:26 PM   #323
68GMCburban
68GMCburban's Avatar
Awesome work! I'm ready to see how this turns out.
-Holden
1983 & 1972 Chevy Longbeds
(16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc)
1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806
(6) 60-66s (shortstep, rollback, two-ton, longbeds)
(3) 47-59s half tons
+ MANY more and always looking for more
68GMCburban is offline   Reply With Quote
Old 05-11-2013, 04:34 PM   #324
oilyrag80
oilyrag80's Avatar
Yea I can Ill try and do it later today
Old 05-11-2013, 04:59 PM   #325
VA72C10
VA72C10
VA72C10's Avatar
Great work so far! Just found this build and follow along!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
