Old 07-04-2015, 06:19 PM   #301
ZouchaR
Re: My 63 Project
Door thresholds in.
What is the best way to secure the door rubber trim in?? Glue?? Double sided tape???
ZouchaR is offline   Reply With Quote
Old 07-04-2015, 06:20 PM   #302
ZouchaR
Re: My 63 Project
Little bit o bling!!!
Old 07-14-2015, 09:40 PM   #303
ZouchaR
Re: My 63 Project
Custom drive shaft made and installed.
Old 07-14-2015, 09:42 PM   #304
ZouchaR
Re: My 63 Project
Originally Posted by ZouchaR View Post
Now the bottom side, stock has more clearance for the driveline. About 2 inches.
So, I pulled the entire crossmember, first to pull out that angle iron that the PO welded in. And since I now have it out, I can bolt it back in, upside down if you will. This will give me more driveline clearance on the top side of the crossmember. And since I have dropped the rear end four inches, it should be better for driveline clearance. Make sense?? If it doesn't work out, I can flip it back over without much work.
So now that the drive shaft is installed, I think the decision to roll the cross member over makes even more sense.
Old 07-14-2015, 09:51 PM   #305
ZouchaR
Re: My 63 Project
E-Stopp installed. I tested it and it works very nice!!!
Old 07-19-2015, 02:32 PM   #306
ZouchaR
Re: My 63 Project
And here is the E-Stopp in Action.... Once it applies the parking brake, you can not move the truck!!!
https://www.youtube.com/watch?v=BoOGGFS51gA
Old 07-23-2015, 12:43 PM   #307
ZouchaR
Re: My 63 Project
Nothing new in this picture, I just liked the look with the light inside. Thought it was cool.
Old 07-23-2015, 09:47 PM   #308
ZouchaR
Re: My 63 Project
Windshield installed.
Old 07-23-2015, 09:49 PM   #309
ZouchaR
Re: My 63 Project
Back window.... Not so much so.
The gasket is too big for this original back window. So my glass guy is going to cut me a new, just a bit smaller, back window.
Old 08-24-2015, 11:08 AM   #310
ZouchaR
Re: My 63 Project
Got some pictures of the shroud.
Old 09-03-2015, 12:38 AM   #311
ZouchaR
Re: My 63 Project
Today is the day!!! We cranked the motor without gas to make sure we had oil pressure and to make sure the motor would turn over. Added some gas. And here is the results. This is the video of the very first attempt to start this motor.
Old 09-03-2015, 01:27 AM   #312
ZouchaR
Re: My 63 Project
Ok.. so let's try again to upload the first start video....
https://www.youtube.com/watch?v=V9oDF6myngE
Old 09-04-2015, 09:10 PM   #313
ZouchaR
Re: My 63 Project
I decided that the carb needed a rebuild since the motor would not rev quickly. And since this carb had been sitting for like the past five years or so. Here is my first go at a carb rebuild.
Old 09-04-2015, 09:12 PM   #314
ZouchaR
Re: My 63 Project
And the after. She fired right back. And idled down nicely. Have to some more tuning but she runs a ton better. And now the motor will rev!!
Old 09-05-2015, 01:33 AM   #315
whitels1
whitels1's Avatar
Re: My 63 Project
Bad ass build so far, nice attention to detail!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 09-08-2015, 02:10 PM   #316
62jimmy
Re: My 63 Project
Great Build! Just read the whole thing! How much clearance do you have on the bottom side of the driveshaft with the flipped crossmember?
62jimmy is offline   Reply With Quote
Old 09-08-2015, 02:23 PM   #317
ZouchaR
Re: My 63 Project
That was a dang good question. And I didn't know. So I went out and took a picture.
Looks to be about an inch and a half.
Old 09-08-2015, 11:37 PM   #318
62jimmy
Re: My 63 Project
Cool, thanks for the picture, I am planning a 4" drop on my truck, I think I will try this trick!
Old 09-08-2015, 11:54 PM   #319
ZouchaR
Re: My 63 Project
I did four inches as well. But you will need a longer transmission than stock or the driveline will be too long. Mine was 72".
Old 09-10-2015, 01:21 AM   #320
ZouchaR
Re: My 63 Project
So we got ambitious today and pulled her out for a run up and down the street....
https://www.youtube.com/watch?v=FA4O...ature=youtu.be
Old 10-19-2015, 10:49 AM   #321
ZouchaR
Re: My 63 Project
That edlebrock had some issues with jetting and such. And it really wasn't the right carb for this motor.
So.... Holley (quick fuel) 780 CFM!!!!
Old 10-19-2015, 10:51 AM   #322
ZouchaR
Re: My 63 Project
Let her spend a couple of nights outside.
Old 10-20-2015, 09:36 PM   #323
ZouchaR
Re: My 63 Project
Got the bed sides back on her. The drivers side isn't bad. The passenger side is probably beyond repair.
Old 09-30-2016, 01:08 AM   #324
ZouchaR
Re: My 63 Project
So I took her out for her first car show this weekend... The Las Vegas Super Run.... We had a good time and LOTS of people stopping by to ask questions...
Old 09-30-2016, 01:10 AM   #325
ZouchaR
Re: My 63 Project
Along with my good friend Tony who brought out his original 65 Mustang that he purchased new for $3400 in 1965.
