12-15-2016, 04:29 PM | #301 |
Re: Plus Five
I'll post more of the radio install after I get the dash speaker and
sub. I installed the fuel filler and tank emissions lines. Charcoal canister and vents all hooked up.
53 Chevy Pickup |
12-15-2016, 04:32 PM | #302 |
Re: Plus Five
and the filler...
53 Chevy Pickup |
12-15-2016, 04:39 PM | #303 |
Re: Plus Five
I also temporarily installed the park brake and center console
frame. The handle is from a 350Z, and the bell-crank and assembly I made from scratch. It drops thru the floor and will have a grommet to seal it up. It will be covered later.
53 Chevy Pickup |
12-15-2016, 04:43 PM | #304 |
Re: Plus Five
the rest of the linkage,
53 Chevy Pickup |
12-17-2016, 09:26 AM | #305 |
Re: Plus Five
Nice update!
I have to make a parkbrake myself, you have set me in the right direction, Thanks!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-17-2016, 03:53 PM | #306 | |
Re: Plus Five
those kind of parts are fun to make.
53 Chevy Pickup |
12-17-2016, 04:01 PM | #307 |
Re: Plus Five
I got the speaker for the dash yesterday.
today was drizzly and cold so I spent a few hours in the shop. I made a bracket for the speaker, and mounted it temporarily. It will be covered with black speaker cloth. I also made a thru the firewall fitting for the windshield washer line. I'll make a reservoir for the fluid later, and mount it in the engine compartment.
53 Chevy Pickup |
01-02-2017, 05:22 PM | #308 |
Re: Plus Five
New Years update,
I don't have any pictures, but made some real progress. I painted the emissions lines and put new emissions/fuel hose on the lines and new stainless hose clamps so that is all complete. I also completed several wiring harness tasks. I completed the Radio,A/C, cigarette lighter,motorized cowl vent,wipers,headlights,turn signals, horn, third brake light,backup lights,sport mode, overdrive lockout button, LED dimmer, high/low beam dimmer, ignition switch, interior dome/courtesy lights,front hood tilt, power seats,park brake light, cooling fans, engine harness, check engine light, etc. In fact, I think everything is wired up except the two round gauges. I'll make a separate harness for those two. I installed the fuses and so far everything works! I even bumped the starter a few times....
53 Chevy Pickup |
01-02-2017, 05:46 PM | #309 |
Post Whore
Re: Plus Five
Sounds like your getting close..
01-02-2017, 06:10 PM | #310 |
Re: Plus Five
This will be epic
01-02-2017, 10:03 PM | #311 |
Re: Plus Five
Just read through your whole thread and I'm blown away by your fab skills and attention to detail. Funny how all those systems that you didn't have a "comfort level" with seemed to get finished up like you had been doing it for years. Looking forward to seeing you finish her up.
01-03-2017, 06:03 AM | #312 | |
Re: Plus Five
I am hoping it won't be an epic fail! I have plans to have friends stand by with fire extinguishers for the First start up. Wiring has me a little nervous. Hoping for start in February
53 Chevy Pickup |
01-11-2017, 07:47 PM | #313 |
Re: Plus Five
Ok,
I'm on the road again tonight, and have a question about my transmission control. I have the Connect and cruise supermatic transmission controller and the harness included a wire labeled "brake light". The instructions read as follows; 2.2.9 Brake light wire Although not necessary,the wire labeled "brake light" should be run to a factory brake pedal switch (NC) so the TCC will unlock When you apply the brakes. The switch I have has six terminals, some NC and some NO. Is the tranny looking for a 12 volt + positive or is it looking for a ground to be supplied to this wire? Thanks
53 Chevy Pickup |
01-11-2017, 08:15 PM | #314 |
Re: Plus Five
I'm going with 12 volts + on mine, I didnt think anything different. Generally 12 in and 12 out.
My thought just looking for you stepping on brake
1950 3100 5 window |
01-11-2017, 08:46 PM | #315 | |
Re: Plus Five
Just to be clear, cause I know nothing about this, the 12v + that feeds into the brake switch to power the brake lights is normally open isn't it? I think it is Orange wire in my AAutowire harness. I pick up the out put side of that switch.... The tranny would not see a 12v positive till you step on the brakes, and this 12v + is sent to the brakes lights AND now also the tranny TCC?
53 Chevy Pickup |
01-11-2017, 09:04 PM | #316 |
Re: Plus Five
Yes normally open switch, would be 12+ in and 12+out to brake lights, and Trans control module.
I havent driven yet either. I figured if they wanted a normally closed switch they would say that. in instructions.
01-11-2017, 09:29 PM | #317 | |
Re: Plus Five
part in parenthesis about (NC), so I'm still confused. For all of the other functions they tell you what the wire is "looking" for, like the O/drive or shift modes needed a ground signal for example. Any transmission guys out there?
53 Chevy Pickup |
01-11-2017, 10:15 PM | #318 |
Post Whore
Re: Plus Five
THE transmission man around here on this site is clinebarger..contact him
01-11-2017, 10:29 PM | #319 |
Re: Plus Five
If I have given you wrong info. Sorry. I will also have to change my wiring.
01-12-2017, 12:32 AM | #320 |
Re: Plus Five
Rock Auto is having a big sale, do you have one of these for your TCC and brake light
I just bought one from AZ and I think it was 15.00 STANDARD MOTOR PRODUCTS SLS89 Info Brake Light Switch w/CRUISE CONTROL Choose: ^ Ships from same location as parts in cart $1.64 Part In Cart
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-12-2017, 05:46 AM | #321 | |
Re: Plus Five
I just looked at it, and I have something similar that has two more terminals, but works the same.
53 Chevy Pickup |
01-12-2017, 05:50 AM | #322 | |
Re: Plus Five
You may be right, I just don't know from my instructions. I'll try to get info from Pace performance, or clinebarger. I'll keep you posted.
53 Chevy Pickup |
01-12-2017, 08:52 AM | #323 |
Re: Plus Five
Brake light ON
TCC off cruise off
01-12-2017, 12:02 PM | #324 |
Re: Plus Five
Thanks,
I have terminals available to use for this correctly.
53 Chevy Pickup |
01-14-2017, 05:08 PM | #325 |
Re: Plus Five
installed the gauges and speaker,
53 Chevy Pickup |
