Old 12-10-2017, 09:43 AM   #301
buffydores
buffydores's Avatar
Re: 1978 Russet Metallic 4x4
The rebuilt TH350 was leaking from the shift shaft output seal. You can just see a little dab of red there.
And here is the 20 dollar tool and seal to fix it. The tool works for tons of GM transmissions.
It is so much fun learning to wrench on these things. There's so much joy doing it yourself, saving some time/money and knowing it's done right.
Old 12-11-2017, 12:56 PM   #302
phillipm
Thanks for the update!
Old 12-18-2017, 05:18 PM   #303
buffydores
buffydores's Avatar
The rubber transmission cooler lines looked a bit rough and leaky.
That's better. Finally found a use for those 3/8" FI hose clamps.
Old 12-19-2017, 04:16 PM   #304
phillipm
Man someone went gorilla on those old hose clamps!! That hose is cut bad!
Old 12-19-2017, 05:46 PM   #305
buffydores
buffydores's Avatar
"If it's leaking just tighten more" has its limits.
Old 01-03-2018, 06:13 PM   #306
Zook75
Zook75's Avatar
Nice thread. I had a black 79 back in the mid 80 that I raced and wrenched on all them myself. Good times for sure.
I just picked up a 91 Jimmy that will be my daily driver, can't wait to get it.
Zook75 is offline   Reply With Quote
Old 01-03-2018, 07:23 PM   #307
buffydores
buffydores's Avatar
Thanks Zook. It's a never-ending project of fun.
Old 02-17-2018, 12:57 PM   #308
buffydores
buffydores's Avatar
I installed a vintage Rancho Front Axle Truss I purchased from Jeff. Used some POR15 to give it a decent finish. The second picture shows how the attachment works. I upsized the u-bolt a tad for some more strength. With the truss installed, you can still remove the diff cover and pull axles. There's no scenario I can see that would require removal. There's a lot of tension in this thing.
Old 02-18-2018, 09:17 PM   #309
buffydores
buffydores's Avatar
I've been fixing little leaks as I find them. One curious leak that I've noticed on these old axles is gear oil leaks at the plug welds on the pumpkin. I've found three separate leaks this way. Weird.
Old 02-19-2018, 10:47 AM   #310
mickeykreg
mickeykreg's Avatar
X2, very annoying. I decided next time I take it apart that problem is getting welded shut...at least I hope it's that easy.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 03-21-2018, 01:49 PM   #311
denslow
Wow truck looks incredible. I have the exact same plaid on the seats on my 78 jimmy but the driver seat needs to be re upholstered. I saw you said they were new 40 yr old seats. Did you order the cloth somewhere and take them in? Want to get mine repaired too. Any info on how to go about that would be much appreciated.
Great job love to see these trucks look original.
denslow is offline   Reply With Quote
Old 03-21-2018, 03:49 PM   #312
buffydores
buffydores's Avatar
Hi Denslo: Thanks for the compliments. The company is called SMS. They're out of Oregon I believe. Expensive stuff, but original and awesome.
Old 03-25-2018, 09:36 AM   #313
buffydores
buffydores's Avatar
The original (I think) blower motor started to make an awful squeal on start-up, so I hunted down a NOS blower motor and installed. Problem solved.
Old 05-02-2018, 06:58 PM   #314
buffydores
buffydores's Avatar
I was at the Buffalo Wild Wings the other night and the Blazer refused to start. Usually starts as easy as pie. Wires are fresh, good grounds, just starter turning and no spark. Came back the next morning and after a few tries, started up fine. No problems since.........I don't trust the coil. Out you go.
Doesn't look bad:
These are getting harder to find:
Old 05-03-2018, 03:12 PM   #315
phillipm
Oh how do I hate intermittent problems! Hopefully all is well now.
Old 05-03-2018, 06:29 PM   #316
buffydores
buffydores's Avatar
I ruled out everything I could think of. I don't think the computer would be dying on a cold engine. I expect to see problems for computers when they're hot. Let me know if you have any ideas. Me and Brian have our first vintage 4x4 event at the end of May.
Old 05-05-2018, 12:20 PM   #317
buffydores
buffydores's Avatar
Replaced the leaking steering stabilizer. The bolt connected to the tie rod was the most stubborn thing in the world. Finally succeeded with heat, PB Blaster, ball joint kit, and a BF hammer.
Old 07-26-2018, 01:28 PM   #318
buffydores
buffydores's Avatar
I've found a good shop here in Longview that can be as OCD as I desire. They installed the ORD frame repair kit, went through the front axle and are currently replacing the birdnest of 40 years of accessory wires into something not embarrassing. I was starting to have an issue with my wife observing a unreasonable time investment in non-family related items like the Blazer. Sometimes its best to let someone else do the work.
Old 09-29-2018, 12:03 PM   #319
buffydores
buffydores's Avatar
Well, about two months ago, I went out to start the Blazer and nothing. Starter turned, just no spark. Towed it in to my mechanic friends. They found that the ECM was tied into the interior fuse panel with a bunch of random things. The auxiliary cruise control lever was shorting on the steering column and knocking out the ECM. Powerfully stupid. I asked them to strip all the 40 years of random wiring out and do it like a smart person. They did a great job. But here's something funny. While working the RamJet harness, they found a plug not going anywhere. After a little research, they realized that the original installer just failed to plumb in the IAT sensor. The ECM, without the sensor, reads -40F for intake temperature. So.....I was running a tad rich. Here is the solution:
Old 09-29-2018, 12:28 PM   #320
schpeen
schpeen's Avatar
Excellent! so how does it feel now?
1991 K5 Blazer 4x4 "9 ball"
2019 Chevy Silverado Trail Boss 4x4
2018 Chevy Colorado 2 door ZR2 4x4
1988 23' Mako Marine
2005 Harley Davidson Road King
schpeen is offline   Reply With Quote
Old 09-29-2018, 12:47 PM   #321
buffydores
buffydores's Avatar
Faster. More responsive. Quieter.
Old 09-29-2018, 12:49 PM   #322
schpeen
schpeen's Avatar
faster. More responsive. Quieter.
yahtzee!!!
Old 09-29-2018, 07:31 PM   #323
buffydores
buffydores's Avatar
Any input on a 700r4/4l60e setup swap?
Old 10-01-2018, 08:33 AM   #324
aggie91
I'm just glad to be here!
aggie91's Avatar
Go with a 4L80. To many issues with a 4l60/700r4.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-01-2018, 10:17 AM   #325
buffydores
buffydores's Avatar
Hate the first gear on the 4l80
