08-06-2022, 07:00 AM | #301 |
Re: 53 3100 - complete rebuild and upgrade . . . .
Slowly but surely moving along . . . . . Lots of life keeping me distracted the last little while, but the firewall and tunnel are almost done. More later -
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 |
08-08-2022, 08:13 AM | #302 | |
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
08-08-2022, 07:22 PM | #303 |
Much appreciated! That makes 2 of us at least LOL. Here's a little progress. Tinkering with the fire wall and trans tunnel; goal is for the trans tunnel to be removable from inside the cab. Yes, it's heavy (11ga?) but I'd guess it only adds maybe 25-30 lbs total.
More later- thanks for looking - Dan
08-08-2022, 08:48 PM | #304 |
Mine's removable from the inside of the cab to get to the back of the engine and the transmission. It is two pieces.
Here's what it looks like from the engine side of the firewall |
08-09-2022, 04:47 AM | #305 |
Very clean. Looks great!👍
Dan
08-09-2022, 11:14 PM | #306 |
beautiful fab as usual!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-14-2022, 09:25 AM | #307 |
Thanks for the input! Still moving along. No where near done yet, still just mocking up, but you get the idea.
More later - thanks for looking - Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . . My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean. https://www.67-72chevytrucks.com/vbo...d.php?t=791886 My 65 Ford project . . https://www.67-72chevytrucks.com/vbo...d.php?t=792428 Last edited by big_dan; 08-15-2022 at 05:03 AM. |
08-20-2022, 07:30 AM | #308 |
Again, miles to go but a little more progress.
Dan
08-22-2022, 10:53 AM | #309 |
it's amazing how low that motor is, that tunnel is coming out money too.
08-22-2022, 10:58 AM | #310 |
Looking very good Dan...
Marc
08-28-2022, 07:03 PM | #311 |
Thanks, fellas. Just trying to keep moving forward.
On that note, a little progress. Finished "step1" of the firewall. All tacked together, so back on the chassis to lay out pedals. There's plenty of room behind the driver's side head to "adjust" for the go-pedal, but that's later. Since I'm chucking the high rise bench for lower bucket seats, I picked up a set of reproduction Chevelle? pedals from Speedway. With the hydraulic clutch, pedal ratio and master cylinder position are critical, so I spent a little time making a bench mockup to get everything right the first time (and saving having to lay under the dash). Thanks for looking - More later- Dan
08-29-2022, 11:39 AM | #312 |
aw come on, the educated gamble to weld in the mount without trial makes for some great anxiety!
08-29-2022, 06:43 PM | #313 |
Pedal set up looks good.
08-31-2022, 04:54 AM | #314 |
Thanks all. Believe me - trying to measure and get pedal locations and ratios correct laying under a dash is some kind of aggravating! I'll cheat on this one 😆
Dan
08-31-2022, 08:18 AM | #315 |
it's not cheating if there aren't any rules
and thank the god's of speed for no rules ... or my build would have gotten me tar-n-feathered a long time ago! |
08-31-2022, 11:10 PM | #316 |
wii you get a full stroke of the master cyl and clutch? looks close to the firewall and floor. maybe just the pic angle?
09-01-2022, 07:12 PM | #317 | |
Dan
09-02-2022, 11:52 AM | #318 |
have you mocked up a go pedal yet? looks kinda tight for space, maybe just the angle of the pic?
09-02-2022, 01:06 PM | #319 | |
Dan
09-11-2022, 03:52 PM | #320 |
A little more of an update.
Since I decided to use replacement pedals (shorter) I had to move the brake booster a bit. After getting all the geometry right I had to decide how to "move" a hole, so I decided to chop it out and make a replacement. Added a few button heads around the plate to make it interesting? and tacked it in (it'll all be welded up once the fab is complete). Gun- drilled the pivot pin (5/8) and tapped for grease fittings, added bushings, etc. Pedals are nice and smooth with no play side to side. Yes, I'll have to clearance the inner fender a fuzz, but minimal. Mocked it all back up and now to notch for the go- pedal next. More later - Dan
09-18-2022, 03:48 PM | #321 |
A little more progress. Once the clutch and brake pedals were sorted I moved to the gas pedal. Using a simple spoon style. Because of the tunnel/ firewall, I expected to have to recess a bit for the gas pedal. Got that done and tacked, still with plenty of clearance, and pulled the cab to get it all welded up.
About a month of welding to go - Thanks for looking - Dan
03-06-2023, 07:51 PM | #322 |
Time for a little update - life sure does get busy!
Finished the gas pedal cutout on the firewall and welded everything up. Routed all the brake lines (3/16 steel, AN3 fittings). Trimmed the fender wells for clearance, and checked alignment of the rear end, and picked up my gas tank. All in all, steady progress the last few months. Goal is to be finished with the chassis soon and then start wrapping everything else up. More later - thanks for looking - Dan
03-06-2023, 10:21 PM | #323 |
wow, I LOVE your shop and tooling as seen in the background. i am jealous.
you also have a great skill level as show in the tremendous fab work you have done. awesome. Im like your attention to detail, keep posting, it'so great, |
03-07-2023, 11:45 AM | #324 |
Glad to see you still plugging away Dan. ANY progress is good progress.
Marc
03-07-2023, 12:02 PM | #325 |
Really nice work!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
