Closed Thread
Old 06-20-2011, 10:14 PM   #3251
markeb01
Senior Enthusiast
markeb01's Avatar
Re: What did you do to your truck today?
Originally Posted by Rich 5150 69 View Post
Hey Mark that was the same time I went thru mine, only in `93, when I had a lot more energy, 6 weeks from start time to driving, that was stripping, painting, new door parts, engine, trans and alum bed...been driving the begeezes out of it sense then, just a little over a 120,000 miles on it, its time to do it all over again, this time big block, muncie, and air...maybe
No kidding about the diminished energy level. Twenty years ago I would have pulled the front clip, engine and suspension, stripped everything bare and started from there. Being old with back and knee problems, if I pulled it all apart there’s a good chance I’d never put it back together. Thankfully I’ll be happy if it just looks decent to the casual observer and in photographs.
I drove mine for about 15 years with a TH350 before I swapped in a Richmond 4 speed. There’s just nothing more fun than a manual 4 speed. My only regret is that I didn’t go with an M22 rock crusher. I just love the howling of those gears!
markeb01 is offline
Old 06-20-2011, 10:16 PM   #3252
markeb01
Senior Enthusiast
markeb01's Avatar
That looks really interesting. Looking forward to seeing the finished assembly.
Originally Posted by jimmydean View Post
I got bored, so I built a center console out of scrap wood and used the vinyl from my kick panels and doors to cover it. Still need to make the top, but I dig it.
markeb01 is offline
Old 06-20-2011, 11:39 PM   #3253
jimmydean
jimmydean's Avatar
There's a test fit shot in my build thread. I hope to get the top built this week, still deciding on cup holders.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline
Old 06-21-2011, 12:36 AM   #3254
alwaysbroken
got all my breaks finished and bled.
chevys the way to go.
alwaysbroken is offline
Old 06-21-2011, 03:16 PM   #3255
kieth
kieth's Avatar
got the hood on her......
http://kieth.smugmug.com/Trucks/66-G...9_XBJQKNf-A-LB
kieth is offline
Old 06-21-2011, 04:21 PM   #3256
markeb01
Senior Enthusiast
markeb01's Avatar
That turned out beautiful!
markeb01 is offline
Old 06-21-2011, 05:07 PM   #3257
markeb01
Senior Enthusiast
markeb01's Avatar
Pulled the wipers, cowl vent, fender extensions, heater plates, radiator baffles, washer hoses, and accomplished some minor cleaning. Also formed a new hard line for the clutch to replace the ugly and hurriedly formed piece added during the 4 speed swap.
markeb01 is offline
Old 06-21-2011, 05:21 PM   #3258
kieth
kieth's Avatar
You know how picures are they look better than the real thing. But Thanks. Kieth
kieth is offline
Old 06-21-2011, 05:25 PM   #3259
steverino66
x2 - love the color
steverino66 is offline
Old 06-21-2011, 05:29 PM   #3260
steverino66
Looked in your build thread, I was hoping to see it being built - what size/type padding did you use under the vinyl? Looks nice.
Old 06-21-2011, 06:46 PM   #3261
PORKY
PORKY's Avatar
We got the cab stripped and pleasantly found it to be very rust free and in need of little bodywork.
PORKY is offline
Old 06-21-2011, 06:56 PM   #3262
jimmydean
jimmydean's Avatar
I built it in about an hour, would have taken longer to take pictures than to actually build it.
The pad is some industrial pad stuff I got for free from a carpet store. It's a closed cell foam that is not quite a half inch thick. You could use regular home carpet pad, or any pad for that matter.
The sides are just 3/8" ply wood and the bottom is 1/2 MDF that I use for damn near everything. The face will be made out of wood and fiberglass to get the shape, then use wood veneer for pimp factor.
I ran out of fiberglass resin, so the top is on hold until the next Home Depot run.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-21-2011, 07:04 PM   #3263
steverino66
thanks for the info - I'll be attempting partial door panels at some point.
I'll watch for your finished console - very cool.
Old 06-21-2011, 10:30 PM   #3264
dean jendro
Old and crusty
dean jendro's Avatar
Installed new alternator and idler. (Then wife reminded me to, mow the lawn).
dean jendro is offline
Old 06-21-2011, 11:53 PM   #3265
jimmydean
jimmydean's Avatar
Did you see my doors? I hope to get them painted this weekend, but I keep getting pulled off onto something else. I made a tweeter pod out of fiberglass and wrapped the whole thing in vinyl.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-22-2011, 12:35 AM   #3266
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Slammed down the pro street truck down.....just a bit more work then it's off for powder coating.....
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 06-22-2011, 12:35 AM   #3267
neto
neto's Avatar
Finally took it out for a drive after a month and a half. Waited for real axle, drum. Put it all together in 107 degree temp but worth the drive around the block!!! 63 GMC suburban.
neto is offline
Old 06-22-2011, 01:43 AM   #3268
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Added some Redline Water Wetter to the coolant, trying to help keep her on the cooler side as we approach our 100 to 110 degree summer time temps. Did another round of redneck polishing on the old chrome wheels, and they are starting to look pretty good for however old and neglected they are. Not much else going on besides that, she is still being driven every day, and the focus is now on the wife's 63 Cadillac getting it ready for the show this weekend.
fryer1979 is offline
Old 06-22-2011, 08:13 AM   #3269
Hipper
Hipper's Avatar
last two nights got new t/s switch put in and all new wiring ran to front and rear and all the lights working.
71 GMC Long Bed, 454,factory everything, lowered, and shaved.
64 GMC Short Bed (great grandfathers truck)
65 Chevy 1 ton Dually a/c p/s p/b v8 auto
89 Jeep Cherokee 3" lift
79 MG Midget (My 7 year old vehicle)
29 Ford Model A Rat Rod (in the works)
86 pontiac fiero 2.5 manual18 year olds)
87 pontiac fiero SE 2.8 auto (18 year olds)
90 Mitsubishi eclipes turbo AWD (18 year olds)
69 BMW 1600 (wifes toy)
Hipper is offline
Old 06-22-2011, 08:57 AM   #3270
kieth
kieth's Avatar
x2 - love the color
I went to PPG and we pulled up the stock light green, I told them I wanted something that would look kind of stock but better. The paint guy said he could replace the white with silver metalic and the solid yellow with a transparent yellow. In my opinion the color looks very 60 ish but has a little more umphhhh..........Thanks for the compliments........I just want it finished so I can start driving it every day.
kieth is offline
Old 06-22-2011, 08:59 AM   #3271
weaintscared
weaintscared's Avatar
Went and picked up some sand paper doing a lillte at a time,,,,Man it Hot outside
http://67-72chevytrucks.com/vboard/s...d.php?t=468622
weaintscared is offline
Old 06-22-2011, 05:53 PM   #3272
markeb01
Senior Enthusiast
markeb01's Avatar
Got the new hard line installed for the clutch, and even managed to bleed it by myself. I just stepped on the clutch pedal and then used a bar clamp/spreader against the front seat to hold it on the floor while I opened the bleed valve. It’s a pretty small circuit so it didn’t take all that many cycles to complete. Also noticed the brake booster/master cylinder was clocked about 5 degrees to the right, so I loosened the mounting bolts and rotated it to dead level. Now it’s on to paint prep.
markeb01 is offline
Old 06-22-2011, 06:01 PM   #3273
lakeroadster
Got the new hard line installed for the clutch...
Looking good Mark. All that attention to detail is destined to result in an engine bay that is as cool as the rest of your truck!
My engine bay definately matches my truck.... kind of a mess with possible potential
Rolled on the second coat of primer yesterday (in-process Faux-tina). The extra thickness and texture is needed so that, after application of color, the primer will show through the paint after wet sanding. At least that's what I am told .
You know guys, by posting this as I do each step, if this turns out bad, I got no place to hide .
I am also posting these steps on my build thread if anybody wants to see a more contiguous listing of the steps.
lakeroadster is offline
Old 06-23-2011, 01:45 AM   #3274
fryer1979
Redneck Hillbilly
fryer1979's Avatar
That's usually how I end up doing them, hard to find help for things like that sometimes. Now if only the brakes worked the same way....
Picked up a new antenna to replace the busted out original one, just a cheap aftermarket antenna but it should work just fine. I also got a new saddle cloth style seat cover, the old one is just crumbling underneath me.
Old 06-23-2011, 01:47 AM   #3275
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Those bed rail corners really look good man, very nice work. That little bit makes a huge difference in how the bed looks as a whole.
Closed Thread
