Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-26-2012, 05:57 AM   #326
68 TT
Still plays with trucks
68 TT's Avatar
Re: 1972 Blazer - 'Bullet' Project
From what I understand the best source is a complete setup off a diesel truck or SUV. Not sure what years are the best. 88-93 NBS uses one design and 83-87(91) square bodies use another. I would go with the one that has the same accessory drive system you want to run, V-belt or serpentine and grab that whole setup to match.
An Astro van with the optional hydraboost is a second choice but may need a different master cylinder to work on a truck The one I was looking at a couple days ago was angled downward pretty heavily. It would cause fluid level issues in the brakes if mounted level. The hoses are bound to be all different too so that is more added cost.
I believe a keyed firewall plate will be needed to keep things from rotating. You can make your own, cut the piece from the donor or buy a prefabricated part from one of the vendors out there.
You need the power steering pump from the donor as well since it is an integral part of the hydraboost system. I would assume the power steering brackets are unique to the hydraboost power steering pump so make sure you get those as well.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-26-2012, 07:03 AM   #327
mcmlxix
Collector of Projects
mcmlxix's Avatar
CaptainFab (board vendor) make a great bracket but you cant use the auto column shift.... the linkage has an interference issue...
I used his bracket with a 2005 GMC hydroboost and MC... It's not installed yet, just bolted together.
*** Edit - I think the linkage hit the brake booster, SOOOO it may be ok for hydroboost... CaptainFab's bracket is also set up to use later model (80s/90s) vacuum booster...+
CLICK HERE for Captain Fab brackets w/ pics and info
Rich
1972 K5 Blazer CST Click HERE
Old 07-26-2012, 12:38 PM   #328
fxdxharley
Just a nother gear head
fxdxharley's Avatar
http://www.truckandcarshop.com
page 113 of the 60-72 catalog. kinda pricey at $500 for the complete kit but its got everything you need and hey brakes are worth the money!
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 07-27-2012, 12:05 AM   #329
68 TT
68 TT's Avatar
Good to know. I thought John made some but couldn't remember and he doesn't have them in his sig so I thought it might have been somebody else.
Old 07-27-2012, 02:22 AM   #330
mcmlxix
mcmlxix's Avatar
HERE is a link to a cost breakdown. He estimated $350 when done...
Rich
Old 08-11-2012, 12:09 PM   #331
lks dcvn
lks dcvn's Avatar
Got it - thanks everybody.
I went another direction and got an electronic vacuum pump instead - works like a champ and gives me a solid brake pedal all the time.
I turn the key and it fires up for about 5 seconds when I start the truck and then only kicks in during driving when it notices that the vacuum is low.
Pretty slick.
Pump rests on the core support so it is out of the way in the engine bay.
I need to get you guys some updated pix since I got the different rims/exhaust on this thing.
lks dcvn is offline   Reply With Quote
Old 08-19-2012, 01:34 AM   #332
68 TT
68 TT's Avatar
Pretty slick.
Any info on the electric pump you used would be appreciated.
Old 08-19-2012, 05:07 PM   #333
lks dcvn
lks dcvn's Avatar
Sure - here is the pump that I got:
SSBS Electric Vacuum Pump
A few new pix as well...new exhaust installed, new brakes all around, vacuum pump installed.
I have a few sets of bucket seats that I am hoping to trade/sell to get a set of blue buckets down the road, but no rush on that yet - want to be sure I have a solid driver w/o issues before I attack cosmetic items.
I am having a hard time lining up the doors on this thing.
I checked the passenger side door and the hinge area is cracked. I do have a few doors to pick from. I hope that they are all not cracked in the same spot.
I pulled the hatch and the rusty tailgate today to make some room to fix the floor back there.
Old 08-28-2012, 10:27 PM   #334
lks dcvn
lks dcvn's Avatar
Ok - some updates.
Finally took the top off this thing since I have owned it. All the rust is gone in the lower A an B pillars of the truck - only the windshield frame and a few spots in the rear bed is left to fix.
I could not get the doors dialed in so I took another set and bolted them on. They were much closer to the other set that I had from the start...
I also cleaned up the bedsides now that the top is off and coated them in rust preventative paint.
Old 09-05-2012, 01:29 AM   #335
OldCreek
OldCreek's Avatar
Here I am with the same wheels... just thought I'd share.
Keep up with the good work! You're getting there!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 09-10-2012, 07:28 PM   #336
1956cameo
1956cameo's Avatar
It's good to see more progress being made.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 09-10-2012, 08:50 PM   #337
lks dcvn
lks dcvn's Avatar
Tell me about it.
Over the weekend I ran the 220 line in my garage and hooked up my 60 gallon compressor so I can hopefully get more done now.
Old 09-10-2012, 09:52 PM   #338
BLUE THUNDER
BLUE THUNDER's Avatar
Lookin' good bro. I like the electric vaccuum. Do you have a part# and $? I want one.
BLUE THUNDER is offline   Reply With Quote
Old 09-13-2012, 01:48 PM   #339
lks dcvn
lks dcvn's Avatar
Here you go Mario-
$280 from Jegs - cheapest place I found it.
Pedal is great every time I use it. You can't really hear the pump running over the exhaust (which is aggressive, but not overwhelming).
Old 09-22-2012, 03:42 PM   #340
lks dcvn
lks dcvn's Avatar
My search for some front inner fenders brought me to another stash of parts in the area.
I picked up the following:
2 New Inner Fenders
1 set of Black Blazer Bucket seats with tracks and new covers/backs - 1 seat was recovered already the other needs to be redone - anybody want to trade for a set of blue ones?
2 Black Cup Holder Consoles (1 GM one 1 aftermarket) - both in great shape
1 set of new CST Door Panels (NIB)
Dash Clusters (1 w/ Camaro Tach installed in it, 1 standard, 1 new surround)
1 set of new lenses (Deluxe, CST Trim (NOS and aftermarket), blue dot (NIB))
I bought all the good stuff and will likely have it up on the for sale forum this week.
So - I now have new inner fenders to work with - so I can dump the rusty ones.
Old 04-04-2013, 08:06 PM   #341
lks dcvn
lks dcvn's Avatar
I have started my list of action items I need to finish to wrap up this project:
  • Fix rust in rear bed floor where it meets the tailgate
  • Fix inner driver side inner bedside
  • Replace Windshield Frame
  • Complete Body Work
  • Align Panels for fitment
  • Acquire Interior items - Blue Carpet and Blue Seat Covers
  • Replace Dash Harness with new replacement (already purchased)
  • Acquire/Trade for nice Black Steering Wheel
I have a lot of parts that I have stockpiled and I plan to trade my way to getting the last few items I need (if possible).
I need to put up a post in the for sale section to start the process - just haven't got to it yet.
I put all the sheet metal back on the truck and it drives very well now.
Brakes work great and I swapped out the carb for an Edelbrock 1406 with an electric choke.
I am waiting until it warms up a bit to start the body work again as I know how much fun that can be...
Old 06-25-2013, 06:18 PM   #342
lks dcvn
lks dcvn's Avatar
and I sold it today...somebody made me an offer I could not say 'no' to.
I will be selling quite a few extra parts in the coming days/weeks.
Thanks everybody for the support along the way.
Old 06-25-2013, 08:14 PM   #343
jaros44sr
jaros44sr's Avatar
Good luck to you, stop back and say hello from time time
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-01-2013, 12:13 PM   #344
docstheman
docstheman's Avatar
Thanks for the thread. This is really helpful to me seeing what all you had to do in rust repair since I am just starting my project. Great work!
~ It's a Learning Process ~
Click Here for my Blazer Build: 1971 Blazer 4x4
Click Here for my Work Truck Build: 1970 C10 LWB
Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F
docstheman is offline   Reply With Quote
Old 07-08-2013, 06:52 AM   #345
vtblazer
vtblazer's Avatar
Looked like you made it a long way, nice job!
vtblazer is offline   Reply With Quote
Old 07-14-2013, 07:05 PM   #346
lks dcvn
lks dcvn's Avatar
Thanks everybody - I am not averse to buying any more trucks from this era - just want to buy something done and just enjoy it instead of spending all my time tracking down parts and working on the darn thing.
Old 07-14-2013, 10:39 PM   #347
jaros44sr
jaros44sr's Avatar
Good luck to you, which ever path you take
Still alot of good info. on your build thread, would you mind if it was moved over to the builds and project section. Could be very useful to someone down the road
SAFETY FIRST
AS usual, off topic
Jim
Old 07-16-2013, 06:46 PM   #348
lks dcvn
lks dcvn's Avatar
to move it - not at all - happy to be of help to others.
Many guys helped me along the way so might as well pay it forward.
Thanks.
Old 07-17-2013, 09:41 AM   #349
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I totally feel you pain!
Tom Vogel is offline   Reply With Quote
Old 07-17-2013, 11:21 AM   #350
jaros44sr
jaros44sr's Avatar
Thanks.
Thanks for your permission, asked a mod. to move it....
I guess restoration looks deceivin, just a great deal of time involved, and that is one thing we all dont have alot of. Hope you find a truck you can drive.
I feel your pain, and dont know how you endured
SAFETY FIRST
AS usual, off topic
Jim
