Old 07-18-2011, 12:27 PM   #326
68 TT
Still plays with trucks
68 TT's Avatar
Re: '72 Chevy SWB, Project Driver
Originally Posted by fishingjred73 View Post
That's what I'm making mine out of too. Pretty cool idea for the button.
When I was thinking about going that route for my gauges I was going to put a remote mount shift light in the glove box lock location.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-26-2011, 10:17 PM   #327
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Thanks guys! Looks like the button is may become the "tow/haul azz" button because the trip/reset is located in the speedo.
Cut some holes for the exhaust.
I'm going to be doing my own exhaust work now due to shops wanting $700+ for it when they saw the truck. Ordered Flowmaster 815936 2.5" mandrel bend Stainless U-fit kit.
Mufflers are going to be MagnaFlow 11266's 4x9 Oval 18" , not here yet.
Have the bed off now and just got done with the wire wheel......rust, dirt and dust everywhere Hopefully have the frame painted this weekend.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 07-26-2011, 10:47 PM   #328
VA72C10
VA72C10
VA72C10's Avatar
Nice progress! Exhaust cutouts look good and I like how you kept them in place with the wood. Frame is looking good too. That's a dirty job. Watch out for the wires that become inbedded as the tool wears down
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-27-2011, 12:05 AM   #329
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
x2 on imbeded wires lol
looks good
wow you cut the holes with cordless drill and hole saw!!! How long did that take?!! lookin' good
John
1999 Toyota Tacoma 4x4
Old 07-27-2011, 12:54 AM   #330
68 TT
68 TT's Avatar
Nice trick to keep the hole saw in place.
Old 07-27-2011, 01:11 AM   #331
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
looking good, u should try and run a pipe or brace after making the crossmember cut before you paint, I didn't on mine and a lot of people say it causes a weak point, I have seen many with and without though, hard to say. Great idea on the cutting though, I torched mine into ovals by hand, not near as clean as yours.
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 07-27-2011, 09:58 AM   #332
usmcchevy
usmcchevy's Avatar
VA and oldblue,
Oh the wires.....there was still one imbeded in my shin after I took a shower
I did use a corded drill, but cordless easily could have done it. Took less than 5 mins per side with a few cool down breaks.
Thanks, I think the idea came from someone on here. I sprayed the inside of the hole saw with chain wax to keep the heat down.
Right now I'm not planning on bracing it. I honestly don't think its necessary, but if I had a welder that could weld metal this thick I would be bracing it.
Build thread
LSx Swap FAQ index
Old 07-27-2011, 10:01 AM   #333
oldblue1968chevy
What size hole did you cut?
John
Old 07-27-2011, 10:19 AM   #334
usmcchevy
usmcchevy's Avatar
4" Hole saw was $16 from Lowes.
Edit: If you do it make sure you wear heavy leather gloves and have a very good hold on the drill....It hurts when the drill gets away from you
Build thread
LSx Swap FAQ index
Old 07-27-2011, 02:47 PM   #335
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work man! It's looking awesome. I also found out the hard way the other day how high exhaust shops are etting to be. They won't get my money if I can help it.
Great advise on the drill. Also try to keep the drill speed low if your drill is a high speed drill.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-27-2011, 04:22 PM   #336
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the crossmember mod. I like the backup board idea.....may have to steal that one in good time. Sorry if you said, where did you pick up your stainless exhaust kit? Are you going to tig it all up? Are you going to have to clamp it in a few places to get it welded up and mounted? and dang $700 is a little steep.
mcbassin is offline   Reply With Quote
Old 07-27-2011, 06:50 PM   #337
usmcchevy
usmcchevy's Avatar
Thanks guys. Just got the garage cleaned up and the frame primed. Oh and one muffler showed up.
The kit came from Street side auto:
http://www.streetsideauto.com/p/flow...t-dual-815936/
Looks like the price went up a little, it was $242 and then found a code for $15 off so $227 with free shipping.
A nice tig welded exhaust would be nice, but I'm just going to mig it.....The exhaust can't be the nicest part of the truck As for making it removable, I'm going to order 4 band clamps, just not quite sure where they are going to go yet. Maybe one set at the back of the mufflers and the other set under the cab behind the H pipe?
Build thread
LSx Swap FAQ index
Old 07-27-2011, 06:52 PM   #338
68 TT
68 TT's Avatar
Originally Posted by Dieselwrencher View Post
...I also found out the hard way the other day how high exhaust shops are etting to be. They won't get my money if I can help it.
No kidding. I about had a heart attack when they gave me the estimate to replace the muffler & tail pipe on my Blazer. I ended up doing it myself for less than 1/4 the price.
I will be building all my exhaust systems from now on. It's not that hard and I have the tools on hand to do it right.
Old 07-27-2011, 06:53 PM   #339
68 TT
68 TT's Avatar
I like to put them at the back of the muffler. It allows a little tweaking of the tail pipe location and the muffler can stay level.
Old 07-27-2011, 06:55 PM   #340
68 TT
68 TT's Avatar
I have had good luck with those guys and they ship quickly. No handling fees like some of the other guys with the free shipping too. Lots of online discount codes you can find & use too.
Old 07-27-2011, 07:44 PM   #341
Dieselwrencher
Thanks for the link on the exhaust. I need to put new exhaust on the 40 some time and that is affordable.
Ryan
Old 07-27-2011, 09:22 PM   #342
usmcchevy
usmcchevy's Avatar
The kit was here 2 days after I ordered it and I had no problems so I will definitely use them again.
No problem, might want to look at the 3" SS kit, its cheaper than the 2.5 SS kit now
Build thread
LSx Swap FAQ index
Old 07-27-2011, 11:48 PM   #343
mcbassin
Still Learning
mcbassin's Avatar
Hey thanks for the link to the kit. I may go that route myself. About the tig no big deal there. I was just curious since it's stainless. You know how tricky that can be no matter what welder you use.
I can't wait till I get to the point of laying out the exhaust on mine. I have been at a dead stop for the last few weeks. We have had 32 straight days of 100+ temps here. No a/c in my shop. Hope to change that by next summer season Let's see some more pics
Old 07-28-2011, 12:41 AM   #344
hbchevy
hbchevy's Avatar
Looking good man!
- Scott
My 70 lwb build http://67-72chevytrucks.com/vboard/s...d.php?t=472866
hbchevy is offline   Reply With Quote
Old 07-28-2011, 01:18 AM   #345
iehotrod
iehotrod's Avatar
subscribed
iehotrod is offline   Reply With Quote
Old 07-28-2011, 02:49 PM   #346
Dieselwrencher
I'm right there with you. I was so peeved when I was sanding the areas of my doors that weren't sand blasted and the sweat was rolling off of me and getting on my nice bare metal. What can you do though? I want to get my turd back together before it snows.
I can't believe the 3" kit is cheaper. They must sell more of those kits.
Ryan
Old 07-29-2011, 10:51 PM   #347
68 TT
68 TT's Avatar
Better buy one now before they figure that out and jack up the cost.
Old 07-30-2011, 07:18 PM   #348
usmcchevy
usmcchevy's Avatar
Thanks again guys.
Painted, trailing arms, shocks and dif cover were left unpainted because they all need to come off for one reason or another. They will be painted while off the truck.
Both mufflers made it here.
The kit.
Started fitting it up, nothing permanent yet.
Build thread
LSx Swap FAQ index
Old 07-30-2011, 07:34 PM   #349
68 TT
68 TT's Avatar
Good idea with the blocks of wood for where the bed rails are.
Don't forget to put about 400 pounds on the rear frame area to compress the suspension to where it will be with the bed, tailgate & rear bumper on. That little bit of movement can make a big difference in pipe placement around the trailing arms.
Old 07-30-2011, 09:12 PM   #350
mcbassin
Still Learning
mcbassin's Avatar
Hey nice work on the frame. Looks like you have a plan for making the exhaust too.
Couple of questions. Will you need to cut clearence in your bed for the Blazer tank? I just picked one up myself. I am gonna set my fuel system like yours too.
Did you use a Corvette regulator/filter? How do you know if you need one? I don't think my engine has a return at the fuel rail. Does that mean I need one of these style regulators? thanks
