Old 05-08-2011, 09:28 PM   #326
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Pic 1 In epoxy primer, now you can see the body line better.
Pic 2 In high build primer, don't have one in the final gray primer.
oldman3 is offline   Reply With Quote
Old 05-08-2011, 09:30 PM   #327
oldman3
oldman3's Avatar
Pic 1 Making some more repairs to lower cowl area.
Pic 2 A little filler on drivers side.
Pic 3 In high build primer.
Old 05-08-2011, 09:32 PM   #328
oldman3
oldman3's Avatar
Here is the bottom of cab, original rusty section in back and new floor up front.
Old 05-08-2011, 09:35 PM   #329
oldman3
oldman3's Avatar
After blasting I painted the bottom with POR, immediately after painting I sprayed a thin layer of primer on this. That way you can sand and paint without coming off.
Old 05-08-2011, 09:36 PM   #330
oldman3
oldman3's Avatar
Here it is painted the teal color.
Old 05-08-2011, 09:38 PM   #331
oldman3
oldman3's Avatar
Pic 1 Stripped firewall for primer.
Pic 2 In epoxy primer.
Old 05-08-2011, 09:40 PM   #332
oldman3
oldman3's Avatar
Pic 1 In high build primer and the black section is POR and primer. You can also see my drain tube for the AC.
Pic 2 In final primer.
Old 05-08-2011, 09:42 PM   #333
oldman3
oldman3's Avatar
Here is the dash in final primer.
Old 05-08-2011, 09:44 PM   #334
oldman3
oldman3's Avatar
Pic 1 Got the dash area all masked off and here is the cab in teal paint.
Pic 2 Another view.
Pic 3 Also painted the doors.
Old 05-08-2011, 09:51 PM   #335
oldman3
oldman3's Avatar
That's it for today. OK guy that's about 300 pics I've posted and not to many replies, come on give and old dog a bone now and then.
Old 05-08-2011, 10:09 PM   #336
BlueJeep
BlueJeep's Avatar
I was wondering if you'd do anything with the rear cab seam, guess I just needed to wait and see....
How much work did it take to clean up the seam after being welded? I did something similar, welded it and ground it somewhat. I'm thinking of making a profile template off the doors and trying to get a similar profile on the back wall (since the doors never had a seam to begin with). I tried to make sure my welds were hot and quick so as not to build up too much material in there, and I think it worked pretty good but I'm trying to get some insight into what it'll take to make it look good....and yours looks good. Thanks!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-08-2011, 10:22 PM   #337
chev3600
chev3600's Avatar
I'm still amazed. I always wanted to do the removable top mod to mine, but didn't have the guts! Or skills but you've got em. Looks great......more pics!!
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 05-08-2011, 11:23 PM   #338
oldman3
oldman3's Avatar
What I did was weld a section about 5" long. Then I would grind a line to line up with the original line. Skip a 5" section, weld another 5" section and so on till I got to the other side. Then I came back and filled in the open sections. That made it easy to keep the line correct. Hope that helped. Jim
Old 05-08-2011, 11:31 PM   #339
oldman3
oldman3's Avatar
Thanks, I appreciate the kind words. I had never done anything like this before, just said give it a try and it came out OK. Now I'm not saying I would try brain surgery, but don't cut yourself short, we all have talents. More pics to come. Jim
Old 05-09-2011, 02:30 AM   #340
flatbed51
flatbed51's Avatar
Jim your posts are like a good book, I find myself wanting to look at the end and see how it all turns out, but I don't want to miss all the good stuff that leads up to the end. Don
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 05-09-2011, 08:35 AM   #341
oldman3
oldman3's Avatar
Thanks Don, I appreciate it. Jim
Old 05-09-2011, 01:59 PM   #342
oldman3
oldman3's Avatar
Posting early today, got plans for later tonight.
Pic 1 Misc parts ready for blasting
Pic 2 more parts
pic 3 frame ready for blasting
Old 05-09-2011, 02:01 PM   #343
oldman3
oldman3's Avatar
Pic 1 Engine in primer.
Pic 2 Misc parts in primer
Pic 3 more parts
Old 05-09-2011, 02:03 PM   #344
oldman3
oldman3's Avatar
Pic 1 Engine in teal paint
Pic 2 & 3 misc parts painted.
Old 05-09-2011, 02:10 PM   #345
oldman3
oldman3's Avatar
At this point you are thinking is this guy crazy or what, paint the axle flanges. Well my thinking is if I take everything apart and put back together, it has given me the chance to check everything, retorque all bolts, etc. I feel a lot safer the first time out and it's just time and a little paint. If something does go wrong, it's easier to work with clean parts. This is NOT a show truck, eventhough I go to many local shows, I drive this thing everwhere it goes, it's NOT trailered, and it's been put away wet many times. This is just how I build my stuff. Enough BS
Pic 1. axles
Pic 2 rear axle housing
pic 3 backing plates & drums
pic 4 Misc. parts
Old 05-09-2011, 02:13 PM   #346
oldman3
oldman3's Avatar
Pic 1 Here the frame is blasted and ready for primer and paint.
Pic 2 frame all painted.
Old 05-09-2011, 02:14 PM   #347
oldman3
oldman3's Avatar
A little detail paint on valve covers and air cleaner (not shown).
Old 05-09-2011, 02:18 PM   #348
oldman3
oldman3's Avatar
Pic 1 Engine and trans in place on frame.
Pic 2 Brake setup installed and running brake lines. Yes I also paint my brake lines. I use silicone brake fluid, so I don't worry about eating paint.
Old 05-09-2011, 02:24 PM   #349
oldman3
oldman3's Avatar
Pic 1 All the goodies installed
Pic 2 View from back side.
Old 05-09-2011, 02:25 PM   #350
oldman3
oldman3's Avatar
That's is for today, enjoy. Jim
