Old 03-29-2016, 02:57 PM   #326
oem4me
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Originally Posted by yelmer View Post
here is my repop on right nos on left
I had no idea. Sooo much better than the ones now available! I imagine the tooling still exists somewhere, no?
The guy at Truck Shop is flat wrong. Lots of people notice the details.
Old 03-29-2016, 03:07 PM   #327
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Great hubcap breakdown.
Old 03-29-2016, 03:44 PM   #328
60-66
60-66's Avatar
Okay, going to edit the reproduction thing in the hubcap post. Not only are the ones I compared smaller top to bottom on the wings of the bowtie, I measured them with a dial caliper and the poor repop is much taller in the center. Heres all three. Original on left, the "Good" reproductions in the center and the currently available far right.
For the bowtie wings I will call them
Original measures .593
GOOD reproduction .500
Poor reproduction .463
Center of bowtie or center square
Original measures .890 tall
GOOD reproduction .820 tall
Poor reproduction .992 tall
You can see now why the poor reproductions look so disproportioned. Also notice the ridge around the center is more rounded compared to the poor reproduction thats more pointed. Fine for many street trucks but this is a restoration thread. Hate to sound so over critical but that bowtie sucks !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-29-2016, 10:06 PM   #329
likaroc13
Rollin' Old Skool
Great pics & references for this thread! I honestly have no clue if my chrome '66 hubcaps are original or repros, so I'll have to check them out more closely.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 03-29-2016, 10:07 PM   #330
LT1 Burb
LT1 Burb's Avatar
Originally Posted by 60-66 View Post
It was really hard to tell on that second one because of poor pictures, but the master cylinder looked totally wrong and Im thinking the booster was something else other than truck and in the wrong box. Normally these kits did not have a master cylinder with them. The biggest part of that last sale going so cheap was, it was missing most the hardware , like the aluminum shim and pedal pad etc.
I didn't see that but I guess if the hardware wasnt there, that's the most important part.
LT1 Burb is offline   Reply With Quote
Old 03-29-2016, 10:38 PM   #331
sodly
sodly's Avatar
Wow! Incredibly thorough breakdown, 60-66. Thanks for taking the time and effort to do these comparisons.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 03-30-2016, 09:06 AM   #332
jbgroby
jbgroby's Avatar
I can add a bit of information for this thread in regards to the Hubcaps. In 1960, the correct hubcap for the GMC trucks was the 1957-1959 GMC caps.This was because when the 1960 model year was rolled out, GMC either forgot to design a new cap or it was not ready for production. The caps changed in 1961. I put the 1959 caps on my '60 as the early sales ads show them this way.
jbgroby is offline   Reply With Quote
Old 03-30-2016, 09:37 AM   #333
60-66
60-66's Avatar
Thank you Jake . That's partially correct. The hubcap you posted is the same in design , yes. For 1960 AND 1961 GMCs , GMC grouped both years together as the "N" series . Both 1960 and 1961 received the same version hubcap with a paint change of a blue a center and blue outer ring accent. This is spelled out in the GMC parts books , dealer literature and data books. GMC did many things different than Chevrolet even though they are subtle differences , they make it a little tough sometimes.
Old 03-30-2016, 01:06 PM   #334
jbgroby
jbgroby's Avatar
You can see both Painted and Chromed in this picture. I though about changing the color to blue, but the red matches the emblem as well, so it was a coin toss.
Old 03-30-2016, 01:18 PM   #335
60-66
60-66's Avatar
Yeah I here ya there. Painting these GMC caps would be a chore. Oem4me is quite talented in that field. He should do a hubcap "restoration" thread !!
Old 04-07-2016, 10:09 PM   #336
jlbruce
i have a 1966 chevy c10 inline 6 and have a big issue. this truck was barned for 15 years and I just got it running, well kind of. I put a new carb on(1bbl rodchester) and new fuel line along with a new sending unit. I also put in new plugs and points, cap, rotor, timed it to 4 degrees advanced and it now will start takes some turning over but will start and idle but when I try driving it it wont come up to speed it just boggs down cant pull its own weight. what could be causing this? please help done all i can think of. thanks
jlbruce is offline   Reply With Quote
Old 04-07-2016, 10:15 PM   #337
60-66
60-66's Avatar
Try a new vacuum advance on the distributor .
Old 04-07-2016, 10:20 PM   #338
jlbruce
i'll try that in the morning thanks didnt think of that will keep you posted
Old 04-07-2016, 10:27 PM   #339
White knuckle Garage
White knuckle Garage's Avatar
I've seen that before and it was the points not set right but mine was also running a little warm along with that reset the points and work fine
White knuckle Garage is offline   Reply With Quote
Old 04-08-2016, 11:17 AM   #340
oem4me
Wrong thread for this subject. You'll probably get more views in the general 60-66 section or Engines and Drivetrain section.
Old 04-08-2016, 10:45 PM   #341
jlbruce
tried new vacuum advance and set dwell to 30 and timing to 4btdc but still no power when i drive. the vacuum advance still does not move even when revved way up. took line off carb and with finger over hole and revving still feel no vac out of new carb should i feel the suction?
Old 04-08-2016, 11:02 PM   #342
likaroc13
Rollin' Old Skool
Phillip
My Build threads:
Pics:
Previous Rides:
Old 04-13-2016, 02:11 PM   #343
aotte1
Hood Hinge and Spring Finish
Hood Hinge
From research here looks like some hood hinges were silver cad, which mine looked like, weathered silver with some light rust/dirt. Also, some of the photos posted for Lambert, looked like they may have been blackish ones too??.
Hood Hinge Springs
Again research looks like they were kind of flat blackish, phosphate?? mine looked like this.
Couple of photos of mine cleaned.
Les
aotte1 is offline   Reply With Quote
Old 04-14-2016, 08:16 AM   #344
60-66
60-66's Avatar
Les , From my own group of trucks and personally , every truck Ive seen, 1960-1963 is Silver Cad with silver cad bolts and 1964-1966 is gray/Black phosphate with silver cad bolts .
1963 Silver Cad hinge gray phosphate spring
1964 Lambrecht truck . You can see the contrast in this picture of the 1964 between the cad plated bolts and gray phosphate hinge.
Old 04-18-2016, 02:44 PM   #345
Brad54
Brad54's Avatar
We've covered the paint/build order for the cab and the bed. How about the front sheet metal?
How was it all painted? Separately, then bolted together?
I've never seen a good, unmolested truck: are the inner fender and core support bolts all painted, as though they were bolted together prior to painting?
Grill surround? I've never paid attention to see if the flanges of the grill surround and the outer fenders are painted body color, or primer and bolted together before exterior paint.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 04-18-2016, 06:48 PM   #346
yelmer
on the hood and hinge bolt using star washers did that change in 66 to flat washers does somebody have a original 66 to see
yelmer is offline   Reply With Quote
Old 04-20-2016, 02:00 AM   #347
oem4me
Yup. April 66 Fremont truck has flat washers.
Old 05-05-2016, 04:45 PM   #348
pedrosc10
pedrosc10's Avatar
Great thread. It has become my go to before the shop manual. Looking for pics of weather strip. I have not seen any. Just wondering may be the whole door. glass run channels etc... Thank you in advance!
pedrosc10 is offline   Reply With Quote
Old 05-13-2016, 01:51 PM   #349
ironman3452
ironman3452's Avatar
this is great lots of possibilities
ironman3452 is offline   Reply With Quote
Old 05-14-2016, 10:29 AM   #350
jbgroby
jbgroby's Avatar
Learned something out the Hydra-matic today. My dipstickcap has always been loose so I decided to solder it and make it right. I glass bead blasted it and found this under the paint - cool. One more factory correct item.
