Old 05-12-2013, 11:02 PM   #326
oilyrag80
oilyrag80's Avatar
Re: Brave or crazy? crewcab build
Originally Posted by jbclassix View Post
Hey man. You mind posting a picture of the header area above your 3rd (right rear) door where the cabs are welded together? On mine I ended up cutting all the way to the B-pillar and adding that section from another pick-up. I checked on my suburban compared to my brothers cab and they both are different than above the front doors.
This is proving to be a pain to get lined up just right, by the way.
is this what your looking for I havent worked on this side much still need to work on the drip rail
oilyrag80 is offline   Reply With Quote
Old 05-12-2013, 11:15 PM   #327
jbclassix
Junk Yartist
jbclassix's Avatar
That is it! Thank you! So mine looks about the same
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 05-12-2013, 11:16 PM   #328
oilyrag80
oilyrag80's Avatar
Got some more work done on the b pillar. I think this is the most time consuming
part so far,glad im not keeping track of my hours! I really just tied up some small details.
Old 05-12-2013, 11:22 PM   #329
oilyrag80
oilyrag80's Avatar
Here's some more, the little notch cut out of the lower part is to clear the part of the hinge that keeps the door open. I will fix that after I get the outer skin done.
Old 05-12-2013, 11:38 PM   #330
oilyrag80
oilyrag80's Avatar
This is the layer I'm welding on the outer part of the b pillar to add strength
and copy the other side like the factory did. Now all 4 sides will be doubled 16gauge which is more than the factory did on the other side.
Old 05-12-2013, 11:52 PM   #331
oilyrag80
oilyrag80's Avatar
Yea everthing lines up exepct for the drip rail the are just a little different
Old 05-13-2013, 07:45 AM   #332
zellway
zellway's Avatar
This is about the point that I would run out of steam. Looking good!
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 05-13-2013, 10:14 AM   #333
bodydropped68
bodydropped68's Avatar
Looking good keep it up the end is in site.
bodydropped68 is offline   Reply With Quote
Old 05-13-2013, 01:31 PM   #334
67c10rustbuket
67c10rustbuket's Avatar
Awesome, love the new door mod!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-13-2013, 03:03 PM   #335
Rusbuilt
Rusbuilt's Avatar
You are getting there sir! Nice work!
Rusbuilt is offline   Reply With Quote
Old 05-13-2013, 06:41 PM   #336
jbclassix
Junk Yartist
jbclassix's Avatar
Alright, now I have another question for you. Are your B-pillars different widths? My right is 1/4" wider than what is there from the factory on the left? It freaked me out when I measured my door openings and they were 1/4" different. Luckily I set the rear of the cab from the leading edge of the B-pillars.
-Jeremy
Rebuilding an NP205
Old 05-13-2013, 08:12 PM   #337
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work and good job on the 4th door! You're flying right through it!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-13-2013, 10:24 PM   #338
oilyrag80
oilyrag80's Avatar
is this what your looking for mine is the same as the passenger side 3in
I havent ground it down so it shows a little more
Old 05-13-2013, 10:55 PM   #339
jbclassix
Junk Yartist
jbclassix's Avatar
No, I was talking about the inside... I think mine is 5 1/2" on the right, and 5 1/4 on the left. That will be fixed when I put the lip in that the weatherstrip attaches to.
-Jeremy
Rebuilding an NP205
Old 05-13-2013, 11:15 PM   #340
oilyrag80
oilyrag80's Avatar
i just measured, mine is the same as yours just under a 1/4 inch difference
Old 05-13-2013, 11:57 PM   #341
jbclassix
Junk Yartist
jbclassix's Avatar
Right now I am so glad that I squared everything up from the front of the B-pillar! I would have been SCREWED because I didn't notice the difference until this point!
-Jeremy
Rebuilding an NP205
Old 05-19-2013, 09:12 PM   #342
oilyrag80
oilyrag80's Avatar
I think I finally got the b-pillar wrapped up. now I can move on to the rocker that should go pretty quick its already half done. Next weekend is a long weekend so I hope to take the truck over to fellow board member boddydropped68's shop and extend the frame. I'm very exicted about doing the frame so I can finally see how this thing is going to look!
Old 05-19-2013, 09:16 PM   #343
oilyrag80
oilyrag80's Avatar
I also got the front driver door latch all finisded up. This pic is comparing it to the passenger side front door. It took 3 latches to make this one.
Old 05-19-2013, 09:35 PM   #344
Rusbuilt
Rusbuilt's Avatar
Very nice sir! Cant wait to see the frame stretching!
Old 05-19-2013, 11:53 PM   #345
jbclassix
Junk Yartist
jbclassix's Avatar
Awesome Awesome work man!!! Thanks for the kick to get going!
-Jeremy
Rebuilding an NP205
Old 05-20-2013, 12:13 AM   #346
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-20-2013, 11:58 AM   #347
vegadesign
vegadesign's Avatar
Top notch bro
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 05-20-2013, 04:11 PM   #348
bodydropped68
something tells me that is in the very near future
Old 05-21-2013, 08:29 PM   #349
oilyrag80
oilyrag80's Avatar
[QUOTE=bodydropped68;6081302]something tells me that is in the very near future [/QUO
That's right only 3 days to go!
Old 05-24-2013, 06:45 PM   #350
oilyrag80
oilyrag80's Avatar
Truck is all loaded up ready to go to bodydropped68's shop for its frame stretch
Looks like ill have to make 2 trips because the bed and frame doner section would not fit on my trailer with the truck. But it will all fit on the way back!
