07-26-2016, 03:31 PM | #326 | |
Re: Project Cannonball C10
Funny about your comparison vehicle..... My X had a 08 E92 M3 & they are quite the car. I would love to have one as a DD but the cost of the LS3/T56 swap (in addition to the car ) takes them out of my financial comfort zone. Their small alum V8 just didn't do it for me. The 06 335i she had before it actually pulled harder (compound turbo strait six) but the M3 'drove' better (much better IMHO).
07-26-2016, 04:20 PM | #327 | |
I also had an E90 M3 (4 door model) which I sold off and moved back to the older E46 chassis. The V8 sounded amazing but was nothing like an LS motor. The E46 is, to me, the absolute best M car and i will never sell this one. |
07-26-2016, 06:38 PM | #328 |
. You planning to run this through an Auto Cross course? Would love to see a video of it doing so. . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
07-26-2016, 09:44 PM | #329 |
09-17-2016, 10:10 PM | #330 |
. Saw this awesome pic. Hopefully someone can post it click-free: https://www.instagram.com/p/BKUlzkcA5ac/ . . . . ...also saw this auto cross video: https://www.instagram.com/p/BKdyPGPBm2C/ Sounded like a slight throttle blip near the apex of the turn spun her around. Still fine tuning the suspension? Looks and sounded great! . .
09-19-2016, 02:29 AM | #331 |
09-19-2016, 02:50 AM | #332 |
Also got a great in-car video of that first run with the spinout.
Truck performed great for our first time out. Managed a best run of 53.2 which put us into 3rd fastest truck of the day, behind the C10R and a pro El Camino. Last edited by mikentosh; 09-19-2016 at 02:58 AM. |
09-19-2016, 03:09 AM | #333 |
Love that you rip on this truck and drive it like it's made to be driven.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
09-19-2016, 09:50 PM | #334 |
Found some more photos from the weekend over on lateral-g: http://lateral-g.net/hot-in-fontana-...kis-autocross/
09-20-2016, 06:02 AM | #335 |
. That in-cab video is Truck looks amazing and as others have said, job well done driving it like it should be! Here are some of the click-free pics:
09-20-2016, 06:27 PM | #336 |
The truck looks awesome. Dig the interior.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
09-23-2016, 11:25 PM | #337 |
09-23-2016, 11:35 PM | #338 |
Another thing we found during the runs last weekend was the power steering system isn't keeping up during heavy use. Not really a surprise with 13" front tires and a quick ratio fox body steering rack. First thing to do is put in a steering cooler. I happen to have a nice Setrab unit that matches the oil and trans ones, but we skipped putting it in when we did the initial build last November.
The other issue I have discovered, which doesn't seem to be talked about much, is cast iron GM type 2 power steering pumps max out at 5000rpm. Above that and they really cavitate the fluid and mess things up. I've got a 5.5" pulley on the pump, and a 7.48" crank pulley which works out to > 5000rpm at the pump when engine rpm is at 4000. One option is to put a bigger pulley on there, but not a lot of space between that and the oil thermostat. Other option is to move to an aluminum pump like the KRC ones, which maxes out at 9000rpm instead. The nice thing about those pumps is their reservoirs have AN fittings so no worry about crappy power steering leaks. Unfortunately they are really, really expensive pumps We might get it out to Crows Landing next month for another round of autocross and will see if the steering holds up again...then maybe an upgrade over the winter. |
09-24-2016, 12:12 AM | #339 |
I had a car whose power steering couldn't keep up as well. Running synthetic helped a little bit, but a larger reservoir worked too - it seemed the fluid didn't get back to the pump fast enough. No idea if this is the issue with yours or not. Just more data.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
09-25-2016, 08:21 AM | #340 |
09-25-2016, 10:24 PM | #341 |
Not only does she look great but she performs great as well!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
09-25-2016, 10:48 PM | #342 |
Finally got around to troubleshooting the major front end squeaking we've had for a few months. Became convinced it was the Delrin bushings in the lower control arms causing the troubles. Had to pull apart most of the suspension to get at the bushings and did find that the bushings were wider than the steel sleeve by three hundreds of an inch on both the front and back. There was also wear marks on the edges. So I took the dremel to a spare set I had and shaved off a generous amount, then liberally lubricated and reassembled. Took it out in the heat today and it's silent up front now.
Unfortunately the 90F heat now uncovered a potential cooling system issue. First time I've driven it in stop and go with the A/C on and saw temps creep up over 220, when it never tops 210 normally. I checked the fluid level and it's all topped up so perhaps I need to rethink the fan strategy, or even move to a larger rad. Always the moment you solve one thing, another pops up. Posted via Mobile Device |
09-26-2016, 08:58 AM | #343 |
Sometimes the LS platform can give you fits with cooling side, is the system properly "burped".
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
09-26-2016, 09:11 AM | #344 | |
09-27-2016, 09:06 PM | #345 |
. Saw this awesome interior shot: https://www.instagram.com/p/BK3STqohko3/ Any plans to get a professional photographer to take some pics of this one? This truck delivers in every way - job well done w/ it for sure! . .
09-28-2016, 12:05 AM | #346 | |
09-28-2016, 05:31 PM | #347 | |
. Thanks - hadn't seen those great pics yet! . .
10-02-2016, 01:02 AM | #348 |
Got some time to try burping the system. Followed instructions I saw on ls1tech, which is basically leaving the rad cap off and bring it up to temp until thermostat opens, wait for it to suck more fluid in and top off the rad. I did this but didn't find it dropped, though I think it might have pulled additional fluid in from overflow tank. The lower rad hose never got hot...not sure if that's good or bad. But after doing this it wouldn't move above 190F, and even taking it for a few miles around in the afternoon I didn't see more than 193F. I think that might have fixed it, but won't call it success until I try it in some stop and go traffic.
10-02-2016, 04:17 PM | #349 |
It seems like it doesn't take much to create issues! Hopefully it solves your problem.
10-15-2016, 11:18 AM | #350 |
Finally got around to filling the radio hole in the dash. In the blue truck we put a RetroSound unit which does look nice, but 99% of the time I'm listening to satellite radio or something from my phone so a full head unit isn't required. Since I'm running an amplifier for the speakers anyway I decided to set everything up hidden away. That left the dash hole, so I searched eBay to find an original radio delete plate. Since there were a bunch of dash styles and finishes over the years, there is a corresponding number of different delete plates made for these trucks, so make sure you get one that matches your dash grain. This one was labelled 73-77 and matches quite nicely.
Now I just need something to fill the tank switch hole...kill switch, taillight cutout... |
