03-06-2019, 01:23 PM | #326 |
Re: What did you do to your truck today.The 3rd chapter
Confucius say " Paint job is only as good as the prep job."
Do it, Do it right, Do it right the first time |
03-06-2019, 05:19 PM | #327 | |
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
03-06-2019, 06:11 PM | #328 |
No more hand cranks P/W and P/L done
03-06-2019, 09:28 PM | #329 | |
thank you
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-07-2019, 10:28 AM | #330 |
Nice and clean....were are the window & lock switchs mounted?
1970 C10 Short Stepper with 71/72 front clip. |
03-07-2019, 11:27 AM | #331 |
Micro switches that control relays
03-07-2019, 02:18 PM | #332 |
Not so much to the truck....For the truck
20' wide x 30' long and 12'6" high under rafters. Enough room for a 4 post hoist and the Chev Roof and wall sheets go on this weekend if its not raining. |
03-07-2019, 09:52 PM | #333 |
Cap, rotor and plug wires...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 03-07-2019 at 09:59 PM. |
03-08-2019, 09:29 PM | #334 |
Junior Member
Shortened her up a little and changed over to 73-87 style engine mounts. Still need to finish welding the inner sleeve and smoothing the cuts for the motor stands but it’s all in.
03-08-2019, 10:48 PM | #335 |
I took my "new" truck to the mechanic to check all the fluids, and look over everything. When the differential oil came out, I heard "oh $#it". So I took pictures today.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
03-08-2019, 11:21 PM | #336 | |
Nevermind, I found the answer on your personal thread... Thats a bummer.
03-08-2019, 11:29 PM | #337 |
Nice job!
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
03-08-2019, 11:29 PM | #338 | |
Sorry, couldn't resist. It was all taken apart, cleaned, new bearings, seals, and new brakes shoes because what was on was cracked, and all new spacers. I posted a series of photos on my thread.
03-09-2019, 10:35 AM | #339 |
Bummer...could you hear the rear end singing when you drove it?
03-09-2019, 11:17 AM | #340 |
Not really, the transmission makes noise, there was water in the oil but no metal. Yes, when I was going downhill and turning right around curves, it howled. As you can see, the pinion gear was hitting the carrier (correct the terms if I got it wrong).
Here is a short video (on Facebook, sorry), showing how loose it was. https://www.facebook.com/10000846199...4929899799056/
03-09-2019, 07:51 PM | #341 |
Yanked the engine out of Old Red today to hopefully solve a vibration problem I've had since I put the crate GM engine in 10000 miles ago. I'm going to have it bored 30 over and put new pistons, rods and have everything balanced.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
03-09-2019, 09:16 PM | #342 |
Official Site Guitar Shredder
Got my Final Mock up done...hope to get her back in an plumbed mid week...
03-10-2019, 03:33 PM | #343 |
Got her a blankie....
03-10-2019, 03:54 PM | #344 |
What products did you use for the windows and doors? I see someone on this forum used to make a 67-72 specific power door lock kit, but they don't appear to be around anymore.
03-10-2019, 06:35 PM | #345 |
The windows were 91 chev truck motors and the lock are swap meet. All the switches and relays are hobby store. My own design beyond that.
03-10-2019, 06:45 PM | #346 |
Painting the inside of the hood to finish the engine bay
03-10-2019, 10:12 PM | #347 |
Dumped my sniper EFI back to carb, so glad to be done with that POS. Starts and runs every time now.
03-10-2019, 11:18 PM | #348 |
Well, the new project spent a full week in my shop, new wheels cylinders, hoses and shoes, new heater core, new thermostat and water neck, new pressure and temp gauges, new choke cable, new exhaust hanger, carb cleaning...I was really hoping to drive it to work tomorrow, but couldn’t get the brakes to gravity bleed...so, it’ll have to wait until I can get my 14 year old son to come down for a leg work out while I bleed the wheel cylinders.
03-11-2019, 12:30 AM | #349 |
Polished this up with Pro Honda. Comes in a spray. Beyond my expectations, it took out some tuff areas with ease. I could brighten it up some more, but why bother. May have painted it, they look amazing painted, but seems they "breathe" easier without it.
$1550 to have this rebuilt. It's shifted smooth since the day I got it, but 140K miles, and an occasion of abuse, it was due.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-11-2019, 01:06 AM | #350 |
I finished welding up the unnecessary holes in the firewall and started the body work. Now I get to learn firsthand why everyone gets sick of sanding.
