Old 04-25-2020, 12:42 PM   #326
Gregski
Post Whore
Gregski's Avatar
Re: A '54 named Busty
Originally Posted by 8man View Post
Let's see, heat in Sacramento vs heat in Bryan by GAWD TEXAS!
I do understand the need for anything that saves one from heat stroke!
I yield to the gentleman from the Lone Star State.
Gregski is offline   Reply With Quote
Old 04-25-2020, 03:49 PM   #327
Gregski
Post Whore
Gregski's Avatar
so it was out with the fake blue moon rocks and time to try a 3rd type of media, no idea what this is, it came with the FREE blasting cabinet I got
FYI: I vacuumed out all the dust because I couldn't take off the blue plastic container cause the stupid walnut shells got stuck in the plastic wingnut and jammed the threads, design failure!
Note: the blue rocks tumbled the loudest this black metal looking shavings stuff is much more quiet
... see you all in a couple of hours ;-)
Old 04-25-2020, 03:50 PM   #328
8man
Guy across the street just put one of those hotel type through the wall units in his garage so he can work on his 64 F#^!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-25-2020, 05:19 PM   #329
Gregski
Post Whore
Gregski's Avatar
... two hours later, more disappointing results
Old 04-25-2020, 06:19 PM   #330
8man
I've got a tumbler from HF that I've used with various media. Black Beauty from Tractor Supply seems to do a little better job, but the blast cabinet with glass beads does a great job of getting rid of the rust, paint and scale, but then as stated before they are "RAW" steel and you have to do something with them. I've painted them on the Cherokee, and will again on the trucks.
8man-aka Robert
Old 04-25-2020, 08:52 PM   #331
joedoh
joedoh's Avatar
I use evaporust from cardboard freight. I found an old 8M FARM TRUCK tag in the dirt at my honey hole, probbably been there 40-50 years, evaporust showed me there was still white paint on the tag with blue paint on the letters, I took before and after pictures, I will find them.
I used it on some gmc head bolts that sat in a truck with no hood and no valve cover and they look like brand new bolts from the foundry, no kidding!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 04-25-2020, 10:27 PM   #332
Gregski
Post Whore
Gregski's Avatar
yup, I tried it, and I swear they must have a different formula for California cause I did not have the same luck as you, it would not remove a bugger off a finger, what I've been using is that Phosphoric acid from Home Depot, I don't know why I haven't thunk to dunk the nuts and bolts in it till now, LOL
Old 04-25-2020, 10:33 PM   #333
Gregski
Post Whore
Gregski's Avatar
ok this is like 6 or 7 hours later, I honestly don't know what to think, as this is after three days of tumping close to 30 hours (sorry neighboors)
the reason I spread them out into two batches is because I only care about the grille metal screws on the left, I don't care about the nuts, bolts, and washers on the right, I plan on using nice brand new black 5/16th body bolts where they went
but the grille on the '54 is the purdiest thing since pig tailed Bonnie in 4th grade, so I am geeking out on it, hope you understand - I think I may be short a few screws, ha ha, so if you gots some rusty ones and those U clips I'll gladly buy them off you, please PM me (I don't like the new versions of 'em)
Old 04-25-2020, 10:40 PM   #334
Gregski
Post Whore
Gregski's Avatar
so while the tumbler was a tumblin' I was busy myself, though I was supposed to rest my arm
anywho first I wire wheeled them chop sticks that hold the truck to the fenders - please try to hold back your excitement
Old 04-25-2020, 10:45 PM   #335
Gregski
Post Whore
Gregski's Avatar
~ WARNING ~
If you are not passionate about headlights and headlight accessories, you may want to skip the next 73 pages! LOL
Old 04-25-2020, 10:52 PM   #336
Gregski
Post Whore
Gregski's Avatar
it appears they used much different zip ties back in '54
Old 04-25-2020, 10:55 PM   #337
Gregski
Post Whore
Gregski's Avatar
gently remove the conduit woven out of only the finest asbestos, don't forget to savor the aroma
Old 04-25-2020, 10:57 PM   #338
Gregski
Post Whore
Gregski's Avatar
this
Old 04-25-2020, 10:59 PM   #339
Gregski
Post Whore
Gregski's Avatar
on to the Wire Wheel Of Fortune
oh, almost forgot, original piece is on the left, the one already wire wheeled is on the right, (whaaa haa ha)
Old 04-25-2020, 11:01 PM   #340
Gregski
Post Whore
Gregski's Avatar
remember we are not going for perfection since we are going to hit it with some acid next
Old 04-25-2020, 11:03 PM   #341
Gregski
Post Whore
Gregski's Avatar
ah, a reminder of the good ol' days, when things was made in 'merica...
... by immigrants! hee hee
Old 04-25-2020, 11:24 PM   #342
joedoh
joedoh's Avatar
this is 3 days of soaking
Old 04-26-2020, 01:48 AM   #343
LT7A
Originally Posted by Father&son56project View Post
*Hillbilly Tumbler: Bolt an electric palm sander to the bottom of an old paint can. Toss in your cruddy parts and some sand. Hang the paint pan by its handle, turn on the sander, walk away for an hour, return to perfectly clean parts.
This is brilliant.
Old 04-26-2020, 01:52 AM   #344
LT7A
Dunno, bro. Those NBWs (nuts bolts washers) look ok for a fire-and-forget process. Clean enough to paint with Rustoleum after degreasing.
Also, you mentioned that the propane didn't get hot enough for you. You can try MAP gas for the same bernz-o-matic torch. I think it's in yellow bottles. I have both and will try the MAP if I remember and get the chance. I gotta find something I can try to turn red-hot. Maybe on the neighbor's car, but he's home alot now.
Old 04-26-2020, 08:55 AM   #345
8man
Love the work on the headlights. Those are looking good.
I tried Evaporust and it didn't work well for me.
Hope your arm gets better soon so you can use it and make some real progress! Really, you are moving along very quickly.
8man-aka Robert
Old 04-26-2020, 09:59 AM   #346
Gregski
Post Whore
Gregski's Avatar
that's Awesome!
Old 04-26-2020, 10:04 AM   #347
Gregski
Post Whore
Gregski's Avatar
Turns out the torch makes all the difference please watch this video:
MAPP Gas or Propane - Bernzomatic TS8000 Torch Kit
I just ordered mine on Amazon!
Old 04-26-2020, 03:46 PM   #348
Gregski
Post Whore
Gregski's Avatar
very pleased with the way the headlight bits are cleaning up, I hit these with a wire brush after I took this pic and got rid of all the remaining hard to reach rust
Fun Level: 0
Old 04-26-2020, 03:52 PM   #349
Gregski
Post Whore
Gregski's Avatar
today I forced myself to tie up all the loose ends and get every part of the front end primered that was going to get eventually painted satin black
as far as the different colors of primer, the gray stuff will be visible like the grille, the brown stuff will not
I went this route because I already primed and painted some grille pieces this way and I wanted to repeat the process the same way for the remaining external pieces increasing their chances to match
yeah now I realize no one will see those headlight buckets, LOL
Old 04-26-2020, 04:25 PM   #350
Gregski
Post Whore
Gregski's Avatar
yup, this process was un ending
