06-23-2010, 11:29 PM | #351 |
Re: my 68 shortbed build
here are some pics from today, i got the diff pulled and took it to work to do axle bearings and seals and replace the pinion seals and crush sleve,
also got the c notch bolted in the rest of the way. im going to weld it in a few more spots also. i just have one question. how do mark the bottom of the frame to drill the 2 3/8 holes to bolt the bag to and the 1'' hole for the fitting??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
06-24-2010, 11:54 AM | #352 |
VA72C10
Looking good. I marked my holes by making a paper template with the holes matching up to the plate on the airbag for the fitting/bolt holes. Taped it to the bag with some painter's tape. Had tape under the template sticky side up as well. So when I raised up the trailing arms till the bags touch the frame, you loosen the tape holding the paper template to the bag and attach the tape that was sticky side up to the frame....drop the trailing arm/bags and the paper template is left behind. Mark, repeat, and drill
Looking for a 67-72 swb or blazer project in or around VA. |
06-24-2010, 09:23 PM | #353 | |
06-24-2010, 09:32 PM | #354 |
VA72C10
yep, just bolt them to the rear and then crank the rear up and you're good to go! Don't worry...the bags won't sit evenly under the frame..they stick out more on one side...just make sure to pre-line up the holes before using the actual template to make sure they will all be under the frame.
06-27-2010, 08:57 PM | #355 |
today i got the rear bags hung and set the frame down to see how low it will be.
now i just need to wire wheel the frame and brush on some black frame paint, then the bed goes back on and its time for plumbing!
06-28-2010, 03:32 AM | #356 |
man sweet build i cant wait to see those steelies on your truck
07-09-2010, 12:42 AM | #357 |
today i got the switch box wires and all the vlaves wired, just need to ground the valves
also got the bed on and picked up some trailer fenders for front inners they are 33X13
07-09-2010, 08:08 AM | #358 |
Looking good. You're getting close now! Where did you get 13" fenders that are only 33" long?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-09-2010, 09:59 AM | #359 |
WOW, You have really made some progress! Looks great!!!
1977 Camaro 468 BBC - SOLD - 1972 Chevy SWB....in the works!! 2006 Crew Cab Dmax/Allison Summit White-SOLD- 2009 Toyota Tacoma V6 Pre Runner - daily driver - my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595 |
07-09-2010, 11:41 AM | #360 |
truck looks great, glad to see it coming along this good!!!! keep it up or should I say lay it down low now.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
07-09-2010, 12:20 PM | #361 |
Insert Title Here
Coming along great.... awesome job
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
07-09-2010, 01:29 PM | #362 |
Looking good! I would like to see alot of pictures when you put the trailer fenders in.
07-09-2010, 02:39 PM | #363 |
Active Member
Good build! And great job!
07-09-2010, 02:43 PM | #364 |
67cheby
i like that shot down the side of the bed.... man i cant wait to get paint on mine!!
07-10-2010, 10:19 PM | #365 |
oops. typo. they are 33x11 sorry about that, but i got them from a local trailer supply store
07-11-2010, 08:51 PM | #366 |
one step forward and a big leap back...
soo i got all the valves and campressors wired and working great today. but now the truck wont turn over, everything eles works great radio, guages, lights, e-fan, dash lights etc. but when i go to start it... nothen
07-11-2010, 09:08 PM | #367 |
VA72C10
is it clicking at all? Maybe just not enough juice to turn it over since you were playing with the compressors? THey take a lot of juice....or did you mess with any ground wires and maybe leave one off? Also check the connection at the battery...mine would let the lights work but not turn over when it was loose at the terminal....tightened it down and it started right up...
07-12-2010, 01:14 AM | #368 |
no clicking, everything i working normal just nothing at the starter, the starter is new and so is the ignition switch
07-12-2010, 08:40 AM | #369 |
GEARHEAD
Check the neutral safety switch. If it's not adjusted right or unplugged, it won't turn over. I had this happen.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
07-13-2010, 09:07 PM | #370 |
ok i got it started... hgs_notes was right. i had my security switch wired into the neutral saftey switch and one of the wires had come disconected out of the back of that.
so today i got all the bags plumbed to the tank. heres some pics ill get a video up once i get shocks in
07-13-2010, 09:09 PM | #371 |
Very nice, truck looks great!
07-13-2010, 09:46 PM | #372 |
AMBITION
looks good man!! real good
07-13-2010, 10:03 PM | #373 |
Still Learning
Very nice work! Truck looks great!
07-13-2010, 10:16 PM | #374 |
GEARHEAD
Cool, my previous misfortune was used to help someone else out. Truck looks great.
07-13-2010, 10:44 PM | #375 |
Active Member
looks good got any pictures of your tank mounting, trying to find a good place to mount mine.
