Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 07-23-2013, 01:49 AM   #351
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
Hello Jim
No I do not. Have you checked with Ruff Stuff Specialties, or DIY4x? You will want to be sure to get brackets specifically for a Dana 60 with the GM housing ends.
http://www.ruffstuffspecialties.com
http://www.diy4x.com
Originally Posted by eagleuh1 View Post
Do you offer a bracket for Dana 60's from 72 C20 using caddy Eldorado calipers? Thanks. Jim
Old 07-29-2013, 10:10 PM   #352
SYCOTIK
Just got my brackets. Some well made pieces. Can't wait to get them on the truck
SYCOTIK is offline   Reply With Quote
Old 09-30-2013, 02:26 AM   #353
KFreddy
Active Member
KFreddy's Avatar
I'm curious,
A '72 C10 with factory disk on the front, if I swap out to the Wildwood D52 calipers up front. Is it possible to reuse the factory front disk brakes with your brackets on the rear?
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 09-30-2013, 10:46 PM   #354
Captainfab
60-66 Nut
Since your '72 C10 has D52 calipers, yes they will bolt up to these brackets. You could likely use the hoses on the rear also.
Originally Posted by KFreddy View Post
I'm curious,
Old 10-10-2013, 11:23 PM   #355
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I know it's been several months, and my project slowed so I forgot about it for awhile, but I'm finally to the point of installing my Eldorado calipers, and was wondering if you ever got that run of levers completed? If so what would a set go for?
Thanks,
Drew
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-11-2013, 11:34 PM   #356
Captainfab
60-66 Nut
I have had the levers done for some time now. It is the cable brackets that I just have not found the time to complete. I guess I'll have to bump my work week up from 70hrs. Let me see if I can get something done on those in the next couple days
Thanks,
Drew
Old 10-14-2013, 01:44 PM   #357
Twisted78SS
Wide n'Low
That would be awesome!
Here are a few shots of the installation for others to see how things look. I am using the Eldorado brake pads and they fit just fine.
First bracket that fits flush to the inside of the 4 bolt mounting flange
Shot of the brackets installed, the large thick bracket has a recess on one side that should face the backside of the axle. This is to allow the caliper piston area clearance.
A couple of shots with the calipers on, and one from the top down to show where it sits in relation to the axle.
Side view
Front view
Top view
Also, the wheels are stock Rallye 15x8 and they have plenty of clearance all around..
Air Force Retired
Old 10-14-2013, 11:29 PM   #358
Captainfab
60-66 Nut
THanks for posting those pics Twisted, looks good
I did make a little progress this evening. I finished cleaning up the laser cut parts, deburred them and got them formed. Hopefully tomorrow evening, I can get a set finished up and test fit them.
Old 10-15-2013, 01:43 PM   #359
Twisted78SS
Wide n'Low
I'm ready for a set of levers and brackets as soon as you get time to put them together. Thanks for these,
not an easy find otherwise..
Air Force Retired
Old 10-17-2013, 12:42 AM   #360
Captainfab
60-66 Nut
Well, I've made some progress with the levers and cable brackets. However I discovered that the pair of calipers that I have are not quite the same. I did not realize that when I made the levers. So now the levers only work on one caliper and not the other.
Twisted78SS, it looks like the caliper in your pics above is like the one that I have that the levers won't work with. Can you post pics of both of your calipers, viewed from the shaft side?
Old 10-21-2013, 10:05 AM   #361
Twisted78SS
Wide n'Low
Will do, as soon as I get home this evening.
Air Force Retired
Old 10-22-2013, 01:31 AM   #362
Twisted78SS
Wide n'Low
Here we go,
Right hand
Left hand
Side by side
Air Force Retired
Old 10-22-2013, 01:36 AM   #363
Twisted78SS
Wide n'Low
Some more,
Back side of left hand
Back side of right hand
Air Force Retired
Old 10-22-2013, 09:49 AM   #364
Dobok
Hey Captainfab; I have a 94 Gmc ext.with the usual 10 bolt. We talked earlier(thro e-mails) and you told me that there is nothing yet fabbed for us (88-98) trucks. Well I am staring at my 1977 12 bolt rear diff. now and am guessing that this mod will now fit my new rear diff. setup once I install it !!! AmI correct now !!! I will be one happy guy if its true as I always wanted disca all way around on my truck !!! Thanks for responding and what are my choices if it does fit now !!! (Price too)
Dobok is offline   Reply With Quote
Old 10-22-2013, 11:00 PM   #365
Captainfab
60-66 Nut
Thanks for the pics Twisted78SS.
That shows what I was afraid of. The one caliper that I have and was using for mockup in designing the levers and cable brackets, does not have the extra nub cast into it as yours do. That drastically changes the position of the lever in relation to the cable brackets that I currently have made upSo it looks like it is on to plan B..
Old 10-22-2013, 11:03 PM   #366
Captainfab
60-66 Nut
Yes these rear disc brackets, as well as the other 2 for the 5x5 wheel stud pattern, will work with your '77 truck 12 bolt. The '64-'82 truck 12 bolts and the '80-'87 truck 10 bolts all have the same backing plate flange as well as the same brake offset.
Old 10-22-2013, 11:36 PM   #367
Twisted78SS
Wide n'Low
Bummer for sure, I know how much time it takes, and how precious time can be when also working full time plus. If there is anything I can do to help, don't hesitate to ask.
I have a few sets of the later eldorado calipers as well, might look to see if I could modify the brackets off one set. Who knows.. But I'm not hopeful as they are pretty different
Air Force Retired
Old 10-23-2013, 12:06 AM   #368
Dobok
Thanks Captainfab for the good news(for me) !!! I will have to put this mod on my to do list when I pick up my 12 bolt to work on sometime hopefully this winter. I will be looking for vendors to rebuild that 12 bolt too as I will need to replace all the seals and bearings and put in a posi unit with gears. Any info on that Please let me know !!! Captainfab---You have come thro again !! Thanks from me and I am sure there is alot more of that out there too !!!
Old 10-23-2013, 12:58 AM   #369
Captainfab
60-66 Nut
I appreciate the understanding. Right now I have a couple very important rush jobs that I need to get done. I should be done with those in a couple more days.
The cable brackets that I have made are basically the same as on those '79-'85 Eldorado calipers you have. The issue is that on the '76-'78 calipers, with that extra nub, that moves the levers so close to the cable bracket, there isn't much room for movement of the lever.
I'll try and get a couple pics tomorrow of what I'm talking about.
I think that the '76-'78 Eldorado's must have had the cable brackets on the axle tube?
I can most likely stretch the brackets that I have currently made, and have some more laser cut. I'll have to take a look at it
Old 10-27-2013, 12:09 AM   #370
83_shortwide
Would one of these calipers work with your kit? It says 3121 is from a '76-'78 El Dorado
http://tsmmfg.com/3120.html
or
http://tsmmfg.com/3121.html
Bo
'83 C10, LQ4, 4L80E
83_shortwide is offline   Reply With Quote
Old 10-27-2013, 01:03 AM   #371
Captainfab
60-66 Nut
Yes those will work, if they are in your budget.
or
Old 10-28-2013, 11:09 PM   #372
Captainfab
60-66 Nut
Here are a couple pics of what I have fabricated so far, and the small issue I discovered. Upon closer inspection it appears that at some point the caliper without the extra casting that lowers the lever, has had that extra nub cut off. That may be a quick solution to those of you that are waiting for these levers and cable brackets.
Old 11-04-2013, 04:03 PM   #373
Twisted78SS
Wide n'Low
I'd be willing to give it a try.
PM me info on a set of brackets and levers please.
Thanks,
Air Force Retired
Old 11-04-2013, 11:13 PM   #374
Captainfab
60-66 Nut
PM sent
Old 11-10-2013, 12:36 PM   #375
liftmeup
Good work
lifted, locked, rockin
liftmeup is offline   Reply With Quote
