#351 |
67cheby
![]() Join Date: Sep 2008
Re: 68 C 10 stepside "My American Bulldog"
NICE work
#352 |
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
#353 |
looking great as always.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
#354 |
Grandpa in the rustmobile...
nice bare metal..mmmm
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#355 |
Master Procrastinator
looking good, can't wait to see it in primer
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#356 |
VA72C10
![]() Join Date: Mar 2008
Looking really good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#357 |
never seen so many body panels so clean at once!!!!! nice work spike!
#358 |
wow spike got off work at 2am its now 3:20am over here in the sand and i read your whole thread very nice work and attention to detail finally a stepside build to watch the rootbeer color looks real good can not wait till i can start on mine got to get home and build a shop though before that happens until then i will be watching your project.
#359 |
Thanks for all the support guys!
![]() I can't wait until I get it all primered. But first a little sand blasting ![]() Just hope it cools down a little by Tuesday It's been over 100F, With heat index of 110-120 100% humidity, Without hardy any rain ![]() But on a brighter note, Next weekend, Planning a trip to Summit racing with crob35 ![]() Spike ![]()
#360 |
Great work Spike!! the build up from the frame with lots of pictures is inspiring, get me really wanting to get started on my 68 c10. Love the color you are going for too, the metallic sparkle with the rootbeer looks amazing and makes me thirsty for some reason. Keep up the great work!!
Papa-J Last edited by Papa-J; 06-05-2011 at 04:32 AM. |
#361 | |
![]() Here is a small update. Had to do some repairs to the sand blaster, Before finishing up cleaning my panels and such. ![]() But got all of my bed metal ready now. All those nasty little nooks and cranny's. ![]() Here are the bed sides with there first coat of epoxy primer ![]() Spike ![]()
#362 |
And on a side note, I've been using my friend Tom's little angle grinder.
And burnt that thing up completely. So it was off to Sears. Picked up 2 angle grinders, And a butterfly impact. " I swear it was calling my name" Spike ![]()
#363 |
looking good, can't wait to see them in that fancy paint
#364 | |
![]() Spike ![]()
#365 |
hey spike you seem pretty close to shooting some color on those panels can't wait to see them in that color it should be a nice effect with all the lines of the truck
#366 | |
![]() Next is 2 coats of b/u primer. Block sanding. Thin coat of filler to true up the body, Block sand again, Final primer, Black base coat, Gold pearl highlights, Then 4 or 5 coats of Kandy rootbeer, Then 4 or 5 coats of clear. After all that, It should look like this. Spike ![]()
#367 | |
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar Dropped and LS Swapped SWB 87 Build Thread |
#368 | |
I replaced the 12 hulk rivets, With 16 grade 8 bolts. But for maximum bolt diameter, I used metric bolts. So the rating is a 10.9. This is the best I could clear it up for you. Spike ![]()
#369 | |
#370 |
Been playing with the bed today.
Got all the bed parts treated, Sealed, And epoxy primed. Made a new frame, To set the bed on. And welded the stake pocket shut. ![]() My friends Chris, And Phil wanted to play also. Started closing in the side marker today as well. It's nice to see progress! Spike I ran across this sweet deal on a 69 stepside. What do you think, Was 75 cents too much ![]()
#371 |
beauty!!! looking good, 69's are nice and all but not a 67-68, love the front ends, can't complain for the price though, so cool, I want a die cast like that, maybe you should slide it into the paint booth and match it up
#372 |
forgot to ask for some pics of the stakes being filled, a little inspiration
#373 | |
![]() Spike ![]()
#374 |
Ok, It took 2 days.
-I overslept, -The A/C went out, -I needed to do laundry -I wanted to stay home, And drink cold beer instead Pick one or two ![]() But here we go! Welded up the stake pockets, And all gaps. Etched the patches. Applied several skim coats. Block sanded 95% back off. Then etched over the entire rail again. After I finish all the body work on the bed. I will glaze any pinholes. Block sand Then 2 coats of buildup primer. Block sand again Then final primer. Spike ![]()
#375 |
dammit the bar has been raised again
