Old 03-01-2012, 02:13 AM   #351
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bolt in steering rack
Originally Posted by jnjchev77 View Post
i think you may have posted this in the wrong thread....??
By the way killertruck, your upper a-arms (porterbuilt) look like they're upside down...
x2
When you flip them over,... make sure they are on the correct side of the truck.
The upper ball joint should be installed thru the arm,... not bolted on the bottom side.
Keith
Convert to disc brakes.
Old 03-01-2012, 05:50 PM   #352
killerpickup
You know for a while I thought you had been in the sun to much, but I think your right!
killerpickup is offline   Reply With Quote
Old 03-02-2012, 10:31 PM   #353
gringoloco
A guy with a truck
gringoloco's Avatar
Would love some pics of the 73-87 arms modifications...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-15-2012, 01:48 AM   #354
Tmend
Tmend's Avatar
What's up rob. I really want this kit any word for thos of us running stock lower control arms?
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 03-15-2012, 03:58 PM   #355
robnolimit
robnolimit's Avatar
Well, 73-87's are seeming to be a bigger headache. we are working on it, but it may take a little bit.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 03-15-2012, 08:33 PM   #356
dnd1978
dnd1978's Avatar
Rob,
I was doing the final install on my rack kit today and I’m having problem with the fit of the aluminum clamp. With the aluminum clamp tourqed and the rubber in-between it and the rack is not tight. I can jiggle the rack with the clamp fully tourqed. I have one of the first kits. The aluminum is bore too big are the rubber is not thick enough?
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 03-21-2012, 09:41 AM   #357
Custom 68
Custom 68's Avatar
ttt
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-09-2012, 10:46 AM   #358
Custom 68
Custom 68's Avatar
still excited to see somebody install one of these and drive it on the street. Feedback will be appreciated.
Dave
Old 04-09-2012, 11:39 AM   #359
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
I have mine it will be going on my daily driven 68. But I am going to wait to install it until I put my LS motor and trans in.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 04-09-2012, 11:54 AM   #360
robnolimit
robnolimit's Avatar
I am trying to get more customer feedback, there are more than 20 up and driving that we know of, hard to get them to post up.
Old 04-09-2012, 02:05 PM   #361
Custom 68
Custom 68's Avatar
Thanks Rob, I knew you had sold several but nobody posted. I assumed most of them were from on here with your introductory pricing. I figure we will see more posts as spring gets here.
Dave
Old 04-10-2012, 10:57 AM   #362
Tmend
Tmend's Avatar
hey rob any fix for the guys still running factory 73-87 lower control arms
Old 04-17-2012, 12:32 AM   #363
Tmend
Tmend's Avatar
Any word rob.
Old 04-17-2012, 09:25 PM   #364
gringoloco
A guy with a truck
gringoloco's Avatar
Any word rob.
Me too!
-Chris
Old 04-18-2012, 11:27 AM   #365
robnolimit
robnolimit's Avatar
Not looking so good. Due to the size of the A-arm bushing, we would be forced to move the rack up or forward way to far out of the 'sweet spot'. This causes bumpsteer, and/or interferance with the oil pan/balancer. we looked at spacing the lower arm down, and while this helps in the IFS geometry, it costs ground clearance, so, not so good for lower trucks, which is almost everyone. So, it looks like A-arms are the solution
Old 04-18-2012, 09:29 PM   #366
Tmend
Tmend's Avatar
If anyone has installed the kit with a later front end 73-87 what lower control arms r u using.... Please post. It's gonna raise the price of the complete set up just want to know by how much. Thanks
Old 04-29-2012, 11:41 AM   #367
dnd1978
dnd1978's Avatar
Rob,
I have sent you a couple PMs about this problem but no reply. You can see my first post from 03-15-2012.
I was doing the final install on my rack kit today and I’m having problem with the fit of the aluminum clamp. With the aluminum clamp tourqed and the rubber in-between it and the rack is not tight. I can jiggle the rack with the clamp fully tourqed. I have one of the first kits. The aluminum is bore too big or the rubber is not thick enough?
Old 04-29-2012, 11:46 AM   #368
robnolimit
robnolimit's Avatar
there are thick and thin bands for the racks. You should have recieved both in the kit. If no, we will be glad to send you the thick band. Please call the shop monday and we'll get it right out to you.
Old 08-13-2012, 11:22 PM   #369
98crewcab
Originally Posted by robnolimit View Post
Here's the last steps. We finally recieved the adjuster sleeves today! The hex shock is threaded with 5/8" x 18 on one side, and 14mm x 1.5 on the other. We then had them heat treated. Tie rod ends are high-mis-alignment 5/8" chromoly.
I NEED THESE!!!! any chance you sell just the kit above, X2 (one for each side) and is the 93 mustang rack 14mm?
98crewcab is offline   Reply With Quote
Old 08-14-2012, 04:39 AM   #370
Leonkruger7
Smile Re: Bolt in steering rack
Hey Rob, you doing some fine work. I need a R&P for my 69 C10. Its a RIGHT HAND DRIVE and I am in South Africa
Leonkruger7 is offline   Reply With Quote
Old 08-16-2012, 03:51 PM   #371
robnolimit
robnolimit's Avatar
the mustang should be 9/16" NF. Sorry, but we don't sell the parts seporately.
Old 08-16-2012, 04:01 PM   #372
robnolimit
robnolimit's Avatar
Hmmm, I do some RHD stuff, but not the rack for this. At this point I don't know of any rack I could use for this at the moment.
Old 08-20-2012, 04:45 PM   #373
Custom 68
Custom 68's Avatar
oh man I saw some activity on this thread and hoped somebody had some feedback from their install and drive.
Humm right hand drive
Dave
Old 11-25-2012, 05:08 PM   #374
HzEmall
HzEmall's Avatar
Rob, how is this kit for trucks with air ride?
I have a 79 Chevy C-10 with Ridetech Airbags and upper and lower tube control arms and CPP dropped spindles
I currently have the Flaming River bolt in Rack and Pinion Kit and.......well it sucks........
Where the rack mounts to the frame it places the tie rods further forward then the tie rod mount on the spindle which puts them on a about a 25-30 degree angle backwards, not up and down but backwards. (see picture)
This screws with the toe huge. It is almost impossible to get the toe properly adjusted because every time the air ride is adjusted it throws the toe back out.
Does your kit have this same issue
It`s to the point where I can`t drive it and was ready to go back to a normal steering box just so I could enjoy my truck that I built.
Tim Baillie
Installer/Designer/Fabricator
Trick Factory Customs
Company - www.trickfactory.com
Personal - www.hzemall.com
Instagram - @hzemall
HzEmall is offline   Reply With Quote
Old 11-26-2012, 12:41 PM   #375
robnolimit
robnolimit's Avatar
Wow, interesting picture. Air ride is no problem for our kit, but I have some 'warnings' for you. We have test fit our P/S rack with RideTech arms - no problems. But, we have NOT tested with a RideTech sway bar. Our Tie rod end fits to the bottom of the steering arm (on the spindle) and there may be some interferance with the RideTech sway bar - maybe not. If so, this can be solved by making the 'link' longer (a piece of allthread will do this). Next, the top rail on a 73-87 is a bit on the narrow side. We have a different bearing mount plate for these trucks. It can be boltd in, but I suggest welding. Other than that, no problems.
