Old 02-14-2018, 12:08 PM   #351
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Out of the Ditch = The Rebuild Begins ('72 GMC)
I had recently installed CPP 4" HD rear drop springs to replace the standard CPP 4" drop springs. While I was in there I installed the CPP rear shock relocation brackets too. Now the truck can be used as a truck again, and still have a lowered stance. The HD drop springs make a HUGE difference over the standard drop springs as far as hauling and towing capability. The new shock brackets gave me over an inch more of shock travel as well. Complete difference!
It was a gorgeous day here in the PNW this past Monday. It was my day off and I was headed over to my stepson's place to assist him with his "1970 C20 conversion to C10 project". So I stopped out by our mailbox on the backroad we live on, and snapped a couple of pics. Still no hood on the heap yet... which makes it look kinda mean when ya see it.
Pics are of the new HD springs, Shock relocation brackets... and of course the heap...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-14-2018, 12:51 PM   #352
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looking good, it's nice to see it out and about
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 03-02-2018, 06:49 PM   #353
GASoline71
GASoline71's Avatar
I had mentioned that the rig has a bad vibration somewhere around 45-55 mph. I have yet to have the drive line balanced, but did some research on driveshaft "phasing". I had taken the 2 piece shaft apart when I put new U-joints in it. Just made it easier to handle while using a press by myself. Anyhoo... I marked the 2 halves before I separated them so I could slide them back together the same way it came apart.
I either screwed something up when putting them back together or the drivline was out of phase in the old frame and I just never noticed. The transmission yoke was off compared to the rear end yoke. So I unbolted the U-joint straps at the rear end and then separated the 2 halves again. Leaving the transmission side still bolted up by the carrier bearing. I was able to "clock" the rear half 2 splines over on the slip yoke and now all of the U-joints were in alignment with each other.
Took it for a quick test drive and the vibration is pretty much gone! I have some road feel through the steering wheel and front end. but I have to still get the rig to a professional alignment shop. I am still going to get the driveline balanced as well.
Stay tuned...
Gary
Old 03-02-2018, 08:01 PM   #354
Ol Blue K20
Sounds like good news to me.
Dale
Old 03-03-2018, 12:16 AM   #355
swamp rat
swamp rat's Avatar
Well isn't that the S*I*s!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-28-2018, 12:58 PM   #356
GASoline71
GASoline71's Avatar
Progress has been kinda slow as we've been busier than a one legged cat burying a turd around here...
But I finally got all the old seam sealer out of the drip rail "ditch", and then wire wheeled it, and gave it a good dousing of Rust Mort. After it sat for a week I masked it off yesterday and hit it all with some self etching primer. Will do one more coat of primer before I start on the self leveling seam sealer.
I bought self leveling sealer from 3M, and an applicator gun made by Cox Industries. Got it all off of Amazon. I'll report back when I have the area sealed up. I looks like I'm gonna have to raise the rear of the truck to make the front edge of the drip rail "ditch" fairly level. The pinch weld is towards the front, and I want the sealer to stay over the seam instead of pooling at the back along the roof line.
Gary
Old 03-28-2018, 06:34 PM   #357
swamp rat
swamp rat's Avatar
Nice, kinda wondered myself how runny that stuff is and what to do about the down side (back of windows) to make sure it stays thick enough.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-10-2019, 11:51 AM   #358
NewBayColony
NewBayColony's Avatar
subscribed
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 08-29-2019, 08:32 PM   #359
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Your signature made me think of this:
https://youtu.be/nvy_E9X1N2g
66 C20 Service Truck:
Old 09-04-2019, 01:54 PM   #360
67C10GS
67C10GS's Avatar
Subbed for the story, great inspiration
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10”
67C10GS is offline   Reply With Quote
Old 03-14-2022, 05:11 PM   #361
cericd
cericd's Avatar
How did those drip rail sealant products work out? Any issues applying it? I saw you mentioned possibly having to jack the back of the truck up. How's the truck looking now?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
