Old 10-19-2016, 03:37 AM   #351
Marshy
Re: How about some pics of '73-'87 Long Beds Part II
Wow, Im at a loss for words. That truck is immaculate.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 10-22-2016, 08:33 PM   #352
hardcore4life
hardcore4life's Avatar
Originally Posted by jh413 View Post
Hopefully this works and it's the right size.... it's been a long time since i posted on a forum
1976, K20, 454, SM465, NP205, 14BFF, Dana 44, 285/75r16 BFG KO2, 16x8 Ultra 164-6882 +12mm offset. Truck has come a ways from the time I brought it home. About a UPS truck full of new parts, countless hours, and several busted knuckles later. I'm happy to call it mine. Waiting on new front end pieces, autometers are still sitting on my tool box, just scored some original fender tags. So maybe one day it'll be "done."
^ if someone like me is searching google like a mad man, hopefully they find that information useful. I looked, read, and googled imaged wheels on these trucks forEVER trying to find a backspace that would work. I wanted tires flush with fender openings, and that's exactly what I got. I saw another member on this site, or another. He had this setup, but only 2 pictures. I rolled the dice and came out a winner I think. I will say the inside of the wheel lip is CLOSE to the tierod end, but not touching. Zero rubbing so far. I had the tire place use stick on wheel weights when they balanced them. I had stickies on my other truck and never had a problem with them.
What size lift are you running on your truck? And do you have any pictures from the side angle?
68 C10 lwb, 406 sbc, 700R4
86 K30 srw, 454 bbc, TH400
11 Camaro RS, 217 V6, 6M
hardcore4life is offline   Reply With Quote
Old 10-29-2016, 11:56 PM   #353
Jigme
Jigme is offline   Reply With Quote
Old 11-07-2016, 12:29 PM   #354
jh413
Funny you ask that because I looked thru google images and here for hours looking at trucks running that tire size. Almost all of them had a lift of some sort. The other truck I saw with this setup, at stock height, the tire looked more stuffed. My truck does have a 1" BL, was there when I got it, so I left it. I tried getting some fender height measurements from guys, but had no luck on that.
However; I think they're factory springs front & rear. They look factory, but don't have any negative arch, even with the 454, they're just flat. So maybe somewhere in it's life, someone may have added the 1900lb type spring? Because IIRC they're still a 3 pack spring, but don't quote me on that. I'll try and take some pictures from the side on flat ground for you. I have some, but yard is sloped and it plays tricks on how the truck looks.
jh413 is offline   Reply With Quote
Old 11-10-2016, 01:39 PM   #355
Gasasaur
Here's my '87 V20 Camper Special. One pic is the day the original owner (that's him in the pic, not me) handed me the keys of this 51k mile original. The other pic is after I did a few mods to make it more to my taste. I put dual exhaust on it, removed camper shell, added tool box, more aggressive treads, powder coated wheels, and tinted the windshield.
The interior is dark charcoal, dual tanks, 350/TH400, and tons of original documentation. He was a farmer, so he stayed away from what he considered an unreliable over drive transmission. Also opted for roll up windows and manual locks. And I love the fact that he special ordered this Silverado with a vinyl seat instead of the velour. He said, "Why the hell do I want velour seats in my truck?"
I've been driving it every day since I brought it home.
Gasasaur is offline   Reply With Quote
Old 11-10-2016, 11:11 PM   #356
JT_Trucks87
Active Member
JT_Trucks87's Avatar
1987 V30 Silverado SRW 454/400 4x4 104k original paint
1979 GMC C3500 Sierra Classic 3+3 454/4l80e
1971 K20 Cheyenne:
http://67-72chevytrucks.com/vboard/s...d.php?t=804580
https://67-72chevytrucks.com/vboard/...d.php?t=837441
Instagram: jt_trucks3500
JT_Trucks87 is offline   Reply With Quote
Old 11-13-2016, 12:46 PM   #357
Booneybarz
Hey everyone.... Just joined and sharing pic of my '86 k20, loaded Silverado original thruout. 350/400 4.10 front quad shocks PW PDL AC Tilt Cruise am/fm cass no rust !
Booneybarz is offline   Reply With Quote
Old 11-24-2016, 07:55 PM   #358
jh413
Hoping these pics work and are what you were lookin for. I haven't been anywhere in the truck, so I just took some at the house. Truck looks raked in pics far worse than it is in real life.
Old 11-25-2016, 08:18 AM   #359
tlman
repaired my lok rite diff with new carrier and put left front wheel bearing back together ,pulled out warn axle locks and installed drive plates now wait 5 months til spring and I can drive it again
tlman is offline   Reply With Quote
Old 11-26-2016, 10:29 PM   #360
mud.man.rj
mud.man.rj's Avatar
tlman, you do know your truck is a 4x4 right, why wait till spring to drive it, think your weather is the same as ours, winter..
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 11-26-2016, 11:31 PM   #361
tlman
I have spent too much on this truck to have the salt eat it up again our township has a salt quota I think , our roads are white with salt .you check on Kijiji all the good trucks are west nothing here anymore , I used this for plowing snow for two years , it now has a big block and 373 gears 800 eldebrock and performer air gap manifold , we usually have little snow here in southwestern Ontario so I save this truck for my daily driver in spring to fall and park my 2011 Sierra then , I built it now for local tractor pulls and it works awesome , also found out you DONOT use a g80 Eaton locker for that , big bang theory ! But any how that's my story ,everyone has there's
Old 11-27-2016, 08:55 PM   #362
mud.man.rj
mud.man.rj's Avatar
Forgot about your over salted roads in Ontario, also same experience with that style locker, learn the hard way.
5.0 4spd std.
7" lift w 35's.
Old 11-27-2016, 09:21 PM   #363
tlman
454 gets about 28 l/100 ,would cost a fortune in gas for plowing anyhow it had a tired 350 when plowing
Old 11-28-2016, 12:29 AM   #364
mud.man.rj
mud.man.rj's Avatar
Once I get a few more builds done for others will build a 70 454 I have for my truck, every truck I build is always a big block, same as any muscle cars that I have built, just love the torque but mpg is never great but most aren't a daily so may as well be a big block right.
5.0 4spd std.
7" lift w 35's.
Old 11-28-2016, 08:40 AM   #365
tlman
this one in paint booth waiting for paint to be done 1971 c10 complete frame off
Old 11-28-2016, 09:47 AM   #366
Skeetman
Skeetman's Avatar
I found a picture of my '78 which I bought new and put a fiberglass cap on then had it painted with a air brush mural. I had the truck for 10 years, living in the rustbelt you know the rest of the story. That was a good truck.
Skeetman is offline   Reply With Quote
Old 11-28-2016, 09:56 AM   #367
tlman
yes the good old days ,history is repeating itself for me ,I drove a 73 c10 first truck for me ,beat it to death while I built a 67 gmc short box step side in 1979 tilt hood as well
now I drive a 78 k1500 and building a 71 c10
Old 12-04-2016, 08:34 PM   #368
Red Beard
Red Beard's Avatar
A couple of recent pictures.
1987 R10 Silverado "Farm Fresh" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=703698
Red Beard is offline   Reply With Quote
Old 12-07-2016, 05:33 PM   #369
Bolig
My Camel '79
Bolig is offline   Reply With Quote
Old 12-14-2016, 06:42 PM   #370
RoadDevil13
RoadDevil13's Avatar
I just picked this one up.... '84 C20 LWB , 292ci, 4speed with Clifford 6=8 powered setup.
RoadDevil13 is offline   Reply With Quote
Old 12-14-2016, 09:48 PM   #371
jricharc
I just picked this '86 up after selling my '70 C10. It's got 77K original miles and a super clean body with just surface rust. The power plant is a 350 from a late 70's Z28 with a 3 speed on the floor so it has plenty of power for my needs. I have some good plans to make her a sweet truck for doing chores around the house. I am going to get all of the undercarriage cleaned up and undercoated over the winter and then when the weather warms up I plan on painting her up with a nice two-tone look and spray in Raptor bed liner.
1986 C10 LWB 350
1970 C10 LWB 350 - Sold
jricharc is offline   Reply With Quote
Old 12-15-2016, 11:05 AM   #372
truckfan
truckfan's Avatar
Originally Posted by jimbonice View Post
The handset is quite small, and light. It just has a velcro backing.
beautiful truck. good friend had this same truck in white with the green interior
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 12-17-2016, 07:56 PM   #373
SquareChevy
SquareChevy's Avatar
86 chevy k10
SquareChevy is offline   Reply With Quote
Old 01-02-2017, 10:28 AM   #374
darcia87
Originally Posted by Just call me Sean View Post
My '87 Chevy I've been working on and my wifes '83 GMC.
Nice trucks, I have a 87 Chevy and am needing to replace the heater blowing motor, would you happen to know where it's located and the best way to change it with out taking the whole dash off? Thanks
darcia87 is offline   Reply With Quote
Old 01-02-2017, 12:01 PM   #375
tlman
Under the hood by right hinge 4 screws and it's out
