03-05-2016, 12:06 PM | #351 |
Re: A 15 year old's project. Rusty 62 stepside
Thanks man, respect to you as well for all the rust repair you did on your 62
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
03-05-2016, 10:26 PM | #352 |
Made a run out to picknpull this morning and got a couple different things. One was these Cadillac seat belt buckles for the tailgate latches just like on the Persh trucks website
03-05-2016, 10:26 PM | #353 |
The ones I bought
03-05-2016, 10:30 PM | #354 |
I also Did some more work on the t5 install. I went to picknpull today because I previously bought the wrong slip yoke. Instead of searching online and paying big bucks I just pulled a camaro driveshaft from the yard that was the same 2.5'' diameter as mine and cut off the front end so that when I get it shortened I can get them to put on the front portion from the camaro. Also when I go to buy ujoints I just have to tell them it's an 86 Camaro. I also pulled the license plate bracket from the camaro as well. It's on a hindge and has a spring that locks in the open and closed position. That how I'm going to fill the gas tank.
03-05-2016, 10:32 PM | #355 |
Then when I got back I worked on the portion of the inner rocker that goes between the cab support and the door pillar
03-05-2016, 10:33 PM | #356 |
And here it is sitting in place. Holes still need to be drilled
03-06-2016, 12:08 AM | #357 |
Post Whore
Nice! Looks good.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-06-2016, 12:47 AM | #358 |
03-06-2016, 09:56 PM | #359 |
Another busy day with great results. I drilled the holes and welded in the panel that covers the cab support and goes under the pillar
03-06-2016, 09:58 PM | #360 |
Then I made a patch for the lower kick panel
03-06-2016, 09:59 PM | #361 |
Then welded it in and drilled the holes
03-06-2016, 10:00 PM | #362 |
02
03-06-2016, 10:02 PM | #363 |
And then I welded and bolted in the lower door pillar section that I made. All the welds still need to be ground down.
03-06-2016, 10:03 PM | #364 |
Looks good!
1964 Chevy Factory K10 Short Bed Mitchell Sampson |
03-06-2016, 10:04 PM | #365 |
Post Whore
X2! You got some skills bud. lol Build on.
03-06-2016, 10:05 PM | #366 |
And I was finally able to set the truck down on the new tires
03-06-2016, 10:07 PM | #367 |
Post Whore
Ah, that's what it is.....all that perrty weather. Ya'all done givin us yer rain! LOL
03-06-2016, 10:07 PM | #368 |
And if your driveway doesn't look like this at the end you aren't doing it right
03-06-2016, 10:17 PM | #369 |
Thanks guys
03-06-2016, 10:20 PM | #370 |
03-06-2016, 10:32 PM | #371 |
Ha Yeah I've been lucky with the weather lately, the past two weeks have been good weather almost every day.
03-06-2016, 11:17 PM | #372 |
Oh and I also hung the door and it looks like I did my measurements correctly as the door fits pretty nicely
03-06-2016, 11:21 PM | #373 |
Here's another pic of the repaired areas. Still need to finish the kick panel and the floors
03-06-2016, 11:28 PM | #374 |
Beauty! I'm right there with you. Just waiting on some front supports to finish up the passengers side. I think it fits better when you make it your self
03-06-2016, 11:44 PM | #375 |
Thanks man, I know what you mean about them fitting better if you build them Even though it takes more time.
