Old 09-29-2023, 10:44 AM   #351
loudchevy
Active Member
loudchevy's Avatar
Re: 67 SWB First Build
Very nice job. The amount of effort you put in on the bodywork is amazing. Enjoy the pay off. I'm looking forward to seeing the rest of the build
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 09-29-2023, 11:04 AM   #352
Kronald_70GMC
Kronald_70GMC's Avatar
Agreed! Everything is looking flawless and amazing!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 10-02-2023, 09:12 AM   #353
68 C10 Driver
Originally Posted by a.c.ward View Post
when doing our builds, we prep as if for paint, Direct To Metal (DTM) primer, then color match exterior paint with Raptor Liner.
The picture shows the underside of the hood and the front fenders, but we do the bottom of the cab, underside of bed, underside front fenders, and wheel tubs in the back the same way.
A.C. Ward, how do you color match the Raptor Liner? Is it as simple as adding paint to it? I sprayed the bottom of my cab, but left the Raptor Liner black.
Thanks in advance!
68 C10 Driver is offline   Reply With Quote
Old 10-03-2023, 11:52 AM   #354
68 C10 Driver
Definitely an outstanding build! I am just now getting to my frame. I can certainly relate to balancing family and working on the truck. I cannot wait to see what the final product looks like with the lights, engine, and interior installed. Your work is very motivational for me to get my truck finished!
Old 10-07-2023, 04:21 PM   #355
Shifty One
Shifty One's Avatar
Looks great man!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 10-22-2023, 01:22 AM   #356
Scurry67
Thanks for the compliments everyone.
I’ve been getting up to the shop most nights recently, for at least an hour. I spent the week re-prepping the interior, the tubs, and a few other misc pieces for paint. Ended up painting Friday night. Ended up being a productive night
Grill inserts had a couple spots in the back that were a tad light on basecoat from a previous painting attempt. I taped them off and rehit them. Much better!
Back of hood in paint.
Dash/interior is looking much better.
Tubs turned out decent, too
Next objective is to repaint drivers fender and bedsides. I’ll also start cutting/buffing the interior.
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 11-06-2023, 01:56 AM   #357
Scurry67
Update: bedsides and driver’s fender are in paint. Onto the cut and buff. Hope to get after it this week.
67 SWB First Build
Old 11-08-2023, 11:20 PM   #358
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Real nice build. Sure takes a while don't it? I started mine in 2015. I'm in well over a year for a front bumper and seat, they're still pending. Since covid, things have proved very difficult to have done, and right.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 11-15-2023, 02:12 AM   #359
Scurry67
Appreciate the compliment. Definitely has taken some time. I’m definitely motivated to make some more progress after an 8 month hiatus.
I’m dreading the wait time on my seat upholstery. I’ll find that out this December I’m thinking. By the way, i really enjoy your build. I’ve stayed caught up on it for awhile now. It’s been very informational!
67 SWB First Build
Old 11-15-2023, 02:26 AM   #360
Scurry67
Taking a little break from the buffing. I felt like switching it up a little bit. I hung the inner fenders a couple nights ago. Very minor scratches I’ll have to clean up at some point.
I also decided to break out the new wiring harness. Every time i looked at it, i’d get intimidated and find something else to do. I finally decided to jump into it though. I’ve been taking small bites out of it every night i get up to the shop. It seems to be progressing and is less intimidating now.
67 SWB First Build
Old 12-01-2023, 03:17 AM   #361
Scurry67
I’ve been making some progress on the wiring as time permits. I made a good start on the interior but ran into an issue with mounting the vintage air evaporator. I smoothed my firewall early on without considering how to secure the evaporator to the firewall. I think i have a solution but put it on hold. I jumped into the rear harness and was able to get it routed along the frame rail to the rear of the truck. I used the ebrake firewall hole to exit the cab since i don’t plan on installing an ebrake.
Another issue i had was i didn’t consider the taillight housing when moving my filler hose up the rear stake pocket. In order to get it to sit flush, i had to modify the terminal location. It came out pretty decent.
Lastly, i installed my taillights. It appears when i ordered them last two years ago, they shipped me two driver’s side parking lights. The new one is on order.
67 SWB First Build
Old 12-01-2023, 11:02 AM   #362
Kronald_70GMC
Nice progress! I have been thinking about mounting my evaporator to the firewall too once I can afford to get it. Since I'm hoping to keep my firewall clean and not have bolts coming through it, I was doing research for options a while back. I believe that full custom fab has a bracket that mounts to the floor below the pinch weld and thus there is no need for drilling through the firewall. I found this info somewhere on this forum but I can't remember where specifically.
Kyle
IG: kyle_ronald
Old 12-01-2023, 11:17 AM   #363
loudchevy
Active Member
loudchevy's Avatar
Thanks for the company name for the kit. A quick Lougle search came up with this link
https://fullcustomfab.com/shop/ols/p...ket/v/GEN%20IV
I'm in the same boat with a shaved firewall and a future VA install. This bracket looks promising when you don't have the VA unit for stud layout before painting everything.
Scott
2003 Tahoe Stock
Old 12-01-2023, 11:24 AM   #364
Kronald_70GMC
My thoughts exactly. I don't really want to buy my VA kit just to figure out mounting then have it sit on the shelf for potentially years until I'm ready for it.
Kyle
IG: kyle_ronald
Old 12-09-2023, 03:49 PM   #365
Scurry67
Oh nice, i wish i would have known about that earlier. That’ll be my plan B. For the time being, i ended up fabricating my own little bracket based on what i saw someone else do here on the forum. If it ends up being a flop, i just may have to try that bracket.
67 SWB First Build
Old 12-09-2023, 04:05 PM   #366
Scurry67
I built the evaporator bracket out of some scrap sheet metal and some flat bar i had laying around. It’ll mount above the evaporator, on the cowl. I think it’ll work okay.
I also mounted the condenser on the core support. What a PIA it was to install with the grill already installed. It took some time, but i was able to drill the core support and route the lines. It’s slowly coming together.
67 SWB First Build
Old 12-18-2023, 06:03 PM   #367
loudchevy
Active Member
loudchevy's Avatar
That home brew bracket looks like it did the trick, nice job! How did the ping pong paddles come into play
Scott
2003 Tahoe Stock
Old 12-19-2023, 02:17 AM   #368
Scurry67
Ha! I didn’t realize those were in the shot. Those just happened to be the closest “shim” in the shop while I was leveling my evaporator it’s typically a one-man-band in the shop.
67 SWB First Build
Old 12-19-2023, 02:50 AM   #369
Scurry67
Built a Dakota Digital control box bracket that’ll mount to my brake bracket behind the dash bezel. The kit came with the BIM module so i mounted it although i won’t be using it. Maybe down the road…Name:  IMG_0119.jpg
I’ve been working on getting the interior all wired up and it’s starting to come together. I still have to figure out where I’ll route the control box sensor wires through the cab.
A couple shots of the engine bay. I have the headlight harness and the AC harness roughed in. Each harness is tucked behind the inner tub and I’m trying to mount under the core support top lip. Not shown in the picture is the new battery tray in the original location.
Lastly, I installed the new LED headlights. They have the LED bar in the middle that I plan on wiring up for turn signals.
I’ll continue to slowly chip away at the wiring and maybe get some other pieces in paint over the holidays.
67 SWB First Build
Old 12-19-2023, 11:52 AM   #370
loudchevy
Active Member
loudchevy's Avatar
gotta be resourceful. Wiring it looking good.
Scott
2003 Tahoe Stock
Old 12-23-2023, 02:56 AM   #371
Scurry67
Knocked a few more things off the to do list.
I ordered a replacement AC control panel about two years ago. After wiping off the dust, i got the harness and new faceplate installed. Fit was great. I installed my cup holder as well. I’m sure I’ll have to take it out when i install the carpet and seat, but i couldn’t resist.
Gauges are about ready to go in, just have to wait for new j-nuts now
Started buffing the cab. Looking good, although there is a little bit of orange peel still. I decided to keep moving forward and if the little bit of orange peel bothers me, I’ll fix it. Just too anxious to get this thing done.
Happy holidays!
67 SWB First Build
Old 01-14-2024, 02:27 AM   #372
Scurry67
I set out on a goal this past week to get a handful of parts painted and installed. High build, sand and seal coated the parts by Wednesday.
Shot paint on Thursday. The color is a Toyota color called cement gray. It has a slight pearl to it. Very happy with the contrast in colors
Grill trim, headlight buckets, emblem and front bumper installed. Reinstalling the trim was a total PIA with keeping the fasteners seated. That was definitely a frustrating couple of hours, but it came out nice. I’m really liking the look
Next goal is to get the doors put together.
67 SWB First Build
Old 01-14-2024, 09:56 AM   #373
kev2809
low n' slo
kev2809's Avatar
i like it! progress is looking good
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-14-2024, 10:21 AM   #374
cj847
cj847's Avatar
Did I miss the post where you talk about closing up bolt holes and mounting the bumper? It looks fantastic!
cj847 is offline   Reply With Quote
Old 01-14-2024, 01:18 PM   #375
kev2809
low n' slo
kev2809's Avatar
good catch..i didnt notice that. looks a lot cleaner than the bolts showing. do they take a separate bracket to mount?
-_--_--_ _________
