09-01-2011, 09:12 PM | #3801 | |
Re: What did you do to your truck today?
How much were those shocks, and are they single or mono tube? |
09-02-2011, 12:08 AM | #3802 |
Put my 12bolt back in, finally got it finished
09-02-2011, 12:45 AM | #3803 |
But Found Her 25yrs Later!
Bought a replacement cab.
Picking it up tomorrow. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-02-2011, 10:17 AM | #3804 |
Drove the gmc everywhere, worked on the tailgate........
09-02-2011, 06:39 PM | #3805 |
Did a bit more work on developing the technique for the fauxtina on my stepside bed. The bed had shiney spots from the areas that were low and didn't get sanded. I used my hand finishing sander with a green Scotchbrite attached. This helped, and was quick and easy, but there was still some gloss. I then used some full strength degreaser (Purple Power) and simply wiped it on with a shop rage, then removed it with a dry shop rag. That did the trick and was also pretty easy.
So the technique is now defined, now I just gotta find the time to do the rest of the truck I am sure most of ya would agree that working for a livin' is way over-rated. (if your curious about primer and how it was applied check out my build thread. The primer application is the key to the look)... This last photo shows the lack of gloss of the "finished" product. The faux-tina process isn't for the faint of heart, once the gloss coat is sprayed over the rolled on primer the paint looks hideous. The sanding, scotchbrite and chemical de-glossing brings it back to some level of decency... well arguably so. I know a lot of people hate it. That's ok, variety is the spice of life and I gotta tell ya'll I am having a grand ole time working on this. Last edited by lakeroadster; 09-02-2011 at 07:03 PM. |
09-02-2011, 07:51 PM | #3806 |
Hell yeah!!!
Got her washed up and ready to take an early morning drive to the ventura nationals.
Stock is good but custom is the sh*t! |
09-02-2011, 10:23 PM | #3807 |
Not a heck of a lot. My supervisor took half the day off so I brought in my passenger side inner fender in to work so I could pressure wash, media blast and weld up all the factory and PO's holes. Unfortunately after pressure washing I discovered that the inner fenders were undercoated in places so I couldn't media blast it. I have to go after it with the heat gun and a putty knife first. I plan on getting one of those $170.00 - 22 circut wiring harnesses off eRape and running my wiring down the inside of the frame rails. That way I can run an internally regulated alternator, get rid ot the voltage regulator, move the horn between the grille and the radiator support and mount a NOS radiator over flow bottle that I have for a 71 Cadillac. It should fit perfect. I'm actually looking forward to going to the graveyard shift for the next 3 months. I plan on getting a LOT done on my truck durning that time as long we have no major break downs at my work while I'm on graves.
I'm pretty lucky. At my work they have a 100 TON press, 1 Bridgeport mill, 1 steam cleaner, 2 pressure washers, 2 TIG welders, 2 arc welders, 3 MIG welders, 2 lathes but one is down right now, 1 band saw, 1 chop saw, etc, etc. they should know better than leave me unsupervised during a shift. |
09-02-2011, 11:08 PM | #3808 |
lets see...a few nights ago...i painted the engine bay and the motor. today i put the 22's on it. i think im going to have to change the rear wheel studs...they are not long enough....
09-02-2011, 11:13 PM | #3809 |
I replaced the 5 1/2 year old dry rotted tires so I can now roll it in and out of the hobby shop. Let the games begin tomorrow with the tear down process.
09-03-2011, 01:35 PM | #3810 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Well not sure this really counts but.....I opened up the new boxes for the prostreet build.....and well it's a great day.
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
09-03-2011, 02:00 PM | #3811 |
Been wanting to get into airbrush for a long time. This is my first attempt. It's easier than people think, just get some stencils and you can play to your hearts content. I think i'll try some flames next.
09-03-2011, 04:14 PM | #3812 |
IT"S ALIVE!!!!!The engine i pulled out of the wrecked 65 fired up in the 66 ,i ran it for about ten minutes ,still have to tune carb and set timining but it ran!!!!need to find some tires that hold air so i can see if the used tranny works or not....and i had a extra gas tank for my 54 ford sedan,that i did ruff measurements on and should fit right inbetween frame rails no problem its a 17 gallon ,still need to find out the ohms for sender.
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
09-03-2011, 05:59 PM | #3813 |
Well , I got the engine in the 63 today .. It would like to have killed me .. Every thing had to be reworked nothing went together like I had hoped it would ,missed the fact there was a broken bolt in the rear of the head so the last header bolt will have to wait .. I found one like it on the left side before dropping it in and it was an easy one to remove .... the P/S works , I ran it for a minute , no leaks , it is charging ,so all I have to do is finish weld the steering shaft and install the new radiator...
09-03-2011, 06:11 PM | #3814 | |
Sounds like a very busy day dude
09-03-2011, 06:57 PM | #3815 |
Rolled outside this morning, first time on all for tires since last November
09-03-2011, 09:06 PM | #3816 |
Well, it's a start but here is what my father in law and I accomplished today.
09-03-2011, 09:24 PM | #3817 |
"Where were you in '62?"
Little bit more progress today.
Not bad from a couple of country boyz huh......... Dang I am tired.......... I'm going grab a glass of sweet tea, watch some TV, and go to bed. Can't wait to get this dang truck done!
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
09-03-2011, 09:46 PM | #3818 |
Wow! I thought I had a good day working on my truck...looks like you just killed me in the progress category.
09-03-2011, 10:04 PM | #3819 | |
I started around 8am -- 8pm... off and on. It was hotter than an electric prod on a hog's behind outside. Took many breaks!
09-03-2011, 10:09 PM | #3820 |
Well that would explain it. I only worked about 3-4 hours on mine today.
Real nice truck! |
09-03-2011, 10:51 PM | #3821 |
Hey Bud finally got the box on now that's progress, that is one cool truck and that's the color yellow I like the most. What's the plan for the bed floor?...Vernski
09-03-2011, 11:08 PM | #3822 | |
The Shiney Stuff....... http://67-72chevytrucks.com/vboard/s...d.php?t=321173
09-03-2011, 11:35 PM | #3823 |
The 60-66 GMC/Pontiac guy....
[QUOTE=1Bad62Pro/Street;4880215][B]Little bit more progress today.
Not bad from a couple of country boyz huh......... Please don't take my question wrong but I am curious as to why you are fabing up such big wheel tubs when the top and sides of the tire don't come anywhere near the top of the tubs? Do you have an Air Ride setup or something that will take the tires up further in the wheel tubs. Again, just curious.
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
09-04-2011, 12:06 AM | #3824 | |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
09-04-2011, 12:10 AM | #3825 | |
[quote=66-PMD-GMC;4880462]
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
