Old 05-27-2012, 07:13 AM   #376
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Post Your Straight Six Pics!
50-Bomb: That looks like a double tap for the Oil Pressure gauge. One side goes to the O.P. gauge itself, the other goes to some other device that also needs to read oil pressure. Idiot light and gauge? Oil Pressure safety switch for an electric fuel pump [kills the fuel pump voltage when OP goes below a specific pressure], maybe?
Old 05-27-2012, 09:21 AM   #377
50bomb
50bomb's Avatar
Weird. I have an oil line running to the Original pressure gauge in dash already. So could I just plug that up and it be alright?
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 05-27-2012, 01:03 PM   #378
pritch
pritch's Avatar
The PO rigged this up on my green '68:
Aftermarket gauge and idiot light both work.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 05-27-2012, 08:23 PM   #379
'68OrangeSunshine
So when the Idiot light goes on, you know your aftermarket gauge is fried and it's most likely time to rebuild.
50-Bomb: Yeah, just plug it up.
Old 05-27-2012, 09:25 PM   #380
50bomb
50bomb's Avatar
Cool thanks 68orange. It has been confusing me forever now and this truck is about to get a to see its first engine fire up since I owned it for almost 2 years. Just got the inline a month ago. Truck probably hasnt ran in more than 8 years. haha EXCITED
Old 05-28-2012, 10:24 AM   #381
VWNate1
VWNate1's Avatar
Post Re : Initial Fire Up & Fan Shrouds
Rightly so you're excited ! good job , keep working diligently and you'll soon be rewarded with the best trucks ever made , as it was supposed to be .
me , i'd just unscrew that thing and see what comes out of the hole ~ if oil , install a pipe plug , turn it in by finger then snug it up , pipe threads never bottom out like regular nuts & bolts so not too tight ! .
For the other Gentleman , what you're looking for is called a Fan Shroud , unless you're overheating at traffic lights , they're unecessary ~ when i was recently in Death Valley in my L6 C/10 , I had to stop to help an overheated Motocyclist , after maybe 45 minutes idling the gauge reached the 1/2 way point so I took ff driving again , this is how it should be .
Fan Shrouds only help @ idle ~ you're far better off removing the stock fan and installing an electric fan with relay , it makes no difference pusher or puller , the relay and wiring it up live , is very important .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 05-28-2012, 10:52 AM   #382
ole dollor
ole dollor's Avatar
vwnate1: they also help keep your fingers from getting cut off....
ole dollor is offline   Reply With Quote
Old 05-28-2012, 10:58 AM   #383
VWNate1
VWNate1's Avatar
Talking Re : ' Stubby '
Obviously you don't know many mechanics......
-Nate
Geezer
Old 05-28-2012, 01:36 PM   #384
Str8-6-68
Str8-6-68's Avatar
Does this count? It's a 24valve 5.9 cummins in the build for my '68 gmc.
And this is the ppump its getting its in-line 6 also
And this is my daily driver, it also has an inline 6
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 05-28-2012, 02:38 PM   #385
50bomb
50bomb's Avatar
cummins COOOOL! If I ever get my dream truck 60-61 chevy apache k10-k20 I would love to put a detroit diesel in it I know nothing about anything hahaa but this truck inspires me to want have one.
Old 05-28-2012, 04:07 PM   #386
ole dollor
ole dollor's Avatar
that is kool...should have plenty of power...
Old 05-28-2012, 10:57 PM   #387
Jimbabwe
Jimbabwe's Avatar
@VWNate1;
Hey thanks, but I don't mean an actual fan shroud, I mean that little mini bit of a thing that attaches to the top of the rad support and just kind of hangs out a bit over the top. I would call that a fan guard. Looks about a foot wide and like it's sole purpose is to keep your fingers attached!
No overheating problems, just looking to keep things super clean and stock looking under the hood, while she's laid out on the ground.
Jimbabwe is offline   Reply With Quote
Old 05-29-2012, 09:08 AM   #388
VWNate1
VWNate1's Avatar
Post Re: Post Your Straight Six Pics!
Oops ~
You're correct , that's the Fan Guard......
My bad .
-Nate
Geezer
Old 05-29-2012, 12:49 PM   #389
50bomb
50bomb's Avatar
So I have had no luck finding any brackets for my kicdown cable on the th350. Like I mentioned before I have a inline 250 with the rochester b single barrel carb. I guess they didint make a bracket like most the automatics have on here for this type of setup. Someone told me my year engine had the powerglide and that in 69 the th350 came out for the mono type carbs. So how can I make my own so the transmission works properly when hitting the freeways? I heard from people if you do not have the kicdowon/tv cable/ passing gear cable whatever you call it hooked up to trans to carb that you could mess up your trans and others say that is a lie. I just want to avoid messing my trans up. Workin my butt off with no job or money comin in and really need my own vehicle to drive. Not gonna lie this truck is starting to stress me out haha
Old 05-29-2012, 02:10 PM   #390
RichardJ
Did you check GM cars of that era? Olds Omega, Buick Apollo and Pontiac Ventura were the same as Chevy Nova and many had the 250. Camaro and Firebird did as well, but you obviously won't find them in wrecking yards. Many full size Chevy Impala's had a six.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 05-29-2012, 03:12 PM   #391
50bomb
50bomb's Avatar
Not to many good Salvage yards in Orange county. I sometimes to to ecology in sant fe springs. But everything else is just to far of a drive.Mostly just callin places up but nothing they have for mine.
Old 05-29-2012, 09:28 PM   #392
ole dollor
ole dollor's Avatar
i have seen the th350 work just fine with the tv cable un hooked and setting in its hole properly , but if you wanted passing gear just drop it to second gear, but use common sense, dont do it at 100 mph...
Old 05-29-2012, 09:56 PM   #393
50bomb
50bomb's Avatar
I am only plannin on driving freeways around 60mph-65 maybe 70mph but thats it. I drive my dad's 1989 toyota 4runner 4cyl around those speeds and nothing faster.
Old 05-30-2012, 01:12 AM   #394
WIDESIDE72
WIDESIDE72's Avatar
Th350's do not use a "tv cable". It is a kick down cable only and not hooking it up has no detrimental effect on the trans. Only the 700r4 and 200 4r. I have one of each in a 79 Malibu and 72 Swb step.
WIDESIDE72 is offline   Reply With Quote
Old 05-30-2012, 09:00 AM   #395
VWNate1
VWNate1's Avatar
I keep trying to tell him that...... .
-Nate
Geezer
Old 05-30-2012, 09:34 AM   #396
50bomb
50bomb's Avatar
ok ok no more askin. Just wanted to make sure. Thank you everyone and NATE for helpin me.
Old 05-30-2012, 09:36 AM   #397
VWNate1
VWNate1's Avatar
Thumbs up Re : TH350 Slushbox
Good .
Now , button it up and lube / tune / adjust EVERYTHING then go DRIVE the flusherginner Truck ! .
-Nate
Geezer
Old 05-30-2012, 10:10 AM   #398
50bomb
50bomb's Avatar
Well everything seems to be all done with the electrical just gotta see if it all works. If it runs good thaenn I have to do all the brakes next and then I can take this truck out for a test drive for the first time I have owned it for 2 years about. I don't think this truck has been on the road for atleast 8 years. haaa. Oh i am so broke I have to save money for the transmission oil hahaa. GEEZ
Old 05-30-2012, 03:44 PM   #399
VWNate1
VWNate1's Avatar
Post Re: ATF
It's a used tranny correct ? .
Did you take the pan off and replace the filter , clean out all that nasty crud ? .
Either way , you should fill the tranny up to just over the " full " mark on the dipstick then once it's running and you're checking the timing , properly adjusting the valves (engine running , dig) and then adjusting the carby to the highest steady vacuum signal @ idle , then check the ATF , only add a little bit at a time until it's touching the dipstick but NO MORE as ATF expands as it gets hot by 10 % minimum so it's really easy to overfill it and cause leaks .
Keep at it , we're all on the sidelines watching & cheering you on ! .
-Nate
Geezer
Old 05-30-2012, 06:41 PM   #400
50bomb
50bomb's Avatar
Thanks Nate! Yea I bought some motor oil 10-40 I think i probably should go thicker? Also the transmission was rebuilt a couple years ago and has not seen any miles since rebuilt.
