Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 11-11-2013, 01:29 PM   #376
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: D52 Caliper Rear Disc Brake Brackets
Brackets arrived!
No I just need a couple of hours to get to them..
I will take pics as I go this week installing them and noting how things go. I'm looking forward to it.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 12-01-2013, 06:24 AM   #377
Baker819
Just read all of your threads on the brackets. That was a lot of good information that would have taken me way longer to find out if I had to research it all my self. To bad you repeat your self frequently because people don't take the time to read. I will be buying the 6 lug brackets from you soon, as long as I don't swap out my 12 bolt on my 69 C10. Thanks for all your hard work and great customer service Captainfab!!
Baker819 is offline   Reply With Quote
Old 12-02-2013, 01:58 AM   #378
Captainfab
60-66 Nut
Thanks for the compliments
Let me know when you're ready to order.
Old 01-04-2014, 07:33 PM   #379
Sixshooter44
Does someone have the part number for the correct wilwood d-52 calipers. Looking at getting them from Summit since I have some credit with them. Thanks
Sixshooter44 is offline   Reply With Quote
Old 01-05-2014, 12:21 AM   #380
Captainfab
60-66 Nut
Do you need them for the front or rear? In black or red? Do you have 1" rotors or 1.25" rotors?
http://www.summitracing.com/search?S...0D52%20caliper
Old 01-05-2014, 06:55 AM   #381
Sixshooter44
Red ones for the rear with an astro disc. Thanks
Old 01-06-2014, 01:22 AM   #382
Captainfab
60-66 Nut
Then these are the ones you need.......
http://www.summitracing.com/parts/wi...92-r/overview/
Old 02-26-2014, 04:05 AM   #383
54Caddy
GM Addicted
54Caddy's Avatar
have any black brackets ready to ship?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-27-2014, 02:57 AM   #384
Captainfab
60-66 Nut
Sorry but no I do not. I don't keep the powder coated ones in stock. In fact, right now I am out of one of the pieces for the D52's. I sold the last set yesterday. I do have more parts on order.
Old 02-27-2014, 03:48 AM   #385
54Caddy
GM Addicted
54Caddy's Avatar
do i need to prepay for a set of powder coated ones? whats the wait time on other pieces?
..Mac’s Garage..
IG:MacsGarage
Old 02-27-2014, 11:14 AM   #386
Captainfab
60-66 Nut
I should have my laser cutting by next Wednesday and hopefully have the powder coating by Friday. Whether you pay now or when the powder coating is done is up to you.
Old 03-12-2014, 04:50 PM   #387
ms2335
ms2335's Avatar
Would like to get a set of brackets for 12 bolt chevy
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 03-12-2014, 11:02 PM   #388
Captainfab
60-66 Nut
PM sent
Old 05-27-2014, 12:11 AM   #389
siggyfreud
siggyfreud's Avatar
Captain have you or anyone worked out the e-brake situation for these?
siggyfreud is offline   Reply With Quote
Old 05-27-2014, 12:18 AM   #390
siggyfreud
siggyfreud's Avatar
PS I'll take a regular set for my 12-bolt regardless, but was curious if an ebrake solution had been worked out. Will paypal you here in a min.
Old 05-27-2014, 01:07 AM   #391
Captainfab
60-66 Nut
Right now all I have in stock is a set of powder coated D52 brackets. I will need to order some more laser cutting in the AM. I might be able to get that by the end of the week.
I do have some e-brake levers and cable brackets done and zinc plated, I just need to get some springs ordered.
Old 05-27-2014, 09:58 AM   #392
siggyfreud
siggyfreud's Avatar
How much for those brackets, levers and springs? I'll send you the delta if that's stuff you can provide.
Old 05-27-2014, 11:38 PM   #393
Captainfab
60-66 Nut
I'll let you know once I find the correct springs.
Old 10-14-2014, 06:22 AM   #394
dkauffman05
dkauffman05's Avatar
would like ordering info fore rear brackets bare steel on a 72 12 bolt with the d52 calipers and astro rotors. email is dkauffman05@yahoo.com
dkauffman05 is offline   Reply With Quote
Old 10-14-2014, 06:25 AM   #395
dkauffman05
im assuming if I buy thw wildwood calipers pt# 120-10938 for the rear and 120-10936 for the front I can just buy d52 brake pads local instead of buying the calipers that come with pads for $300+ ?
Old 10-14-2014, 09:45 AM   #396
Dobok
Sorry Captainfab; I was just rereading this rear disc bracket info and I came across my 2 cents worth and I had said a 77 chevy truck diff. while I have a 64 chevy truck 12 bolt.It was rebuilt but I have to do a axle swap to a 5 lug so my tires will fit back on( it came with 6 lugs) so I have to order those first and by the postings I should be able to upgrade mt 12 bolt soon !!! What exactly do I need/LOL/I guess everything !!! Thanks
Dobok is offline   Reply With Quote
Old 10-14-2014, 11:44 PM   #397
Captainfab
60-66 Nut
Yes you can just buy standard D52 brake pads from your local auto parts supplier and use them with the Wilwood D52 dual piston calipers.
I sent you an email
Old 10-14-2014, 11:50 PM   #398
Captainfab
60-66 Nut
Since you have a '64 truck 12 bolt, you will also have to change the side spider gears along with the axles. Once you have the axles out, remove the backing plates. All of my rear disc conversion brackets except the Impala SS brackets, can be R&R'd without removing the axles.
Old 10-27-2014, 04:02 PM   #399
BigDaddyV
BigDaddyV's Avatar
Sub'd for future use.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 11-23-2014, 08:43 PM   #400
Beaumont@
Would like to get a set of brackets for a 12 bolt Chevy sent to Canada if possible
Beaumont@ is offline   Reply With Quote
