Old 06-10-2021, 06:40 PM   #376
jimbosprint
jimbosprint's Avatar
Re: '72 Cheyenne K10
I finally finished wiring the KC flood light and rear cargo light switches. I made the bracket from an old bent grill support (and smashed two fingers in the process).
jimbosprint is offline   Reply With Quote
Old 06-11-2021, 07:34 AM   #377
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks pretty good, I hope your fingers are ok
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 06-29-2021, 03:13 PM   #378
landarts
landarts
Originally Posted by jimbosprint View Post
Third time's the charm. The modified handles work great. Now I have RWD, FWD, and 4WD in high or low range. Pretty darn cool.
Attachment 2101664
Attachment 2101665
Attachment 2101666
Love everything about your truck and the path you have taken to get it where it is now. What all did you have to order to do the twin stick install? Was it just one kit or multiple items needed? I think I want to do the same on the Idaho Edition build. Again great work here!
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 06-30-2021, 10:59 AM   #379
jimbosprint
I bought all the twin stick parts from JBs Custom Fabrication (https://jb-custom-fabrication.myshopify.com/). I think the ones he sells on the website are for 1973 up, so I would maybe email him and ask before ordering. I had to send them back twice to be customized (see previous posts). The shift rails in the transfer case also need to be replaced or modified, so it's gotta come out of the truck to do it.
Old 06-30-2021, 11:03 AM   #380
landarts
landarts
Jim - thanks for the information I will give them a lookup and ask those questions. The shift rails were the big one for me, was not sure if that was part of kit or needed to add that on. I will be pulling the NP205 anyways to have it gone through so will do the upgrade then. Again thanks for your wealth of knowledge and the willingness to share.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 07-25-2021, 11:31 PM   #381
jimbosprint
My truck living the easy life hauling my kayak to the river.
Old 07-26-2021, 08:46 AM   #382
Ol Blue K20
That sounds like fun. Especially with the heat we've been having. How's the smoke in your neck of the woods?
Dale
Old 07-26-2021, 10:32 PM   #383
jimbosprint
Smoke is not bad in the valley, noticeable up in the foothills. I hope they can stop the fire soon.
Old 07-27-2021, 06:08 AM   #384
Ol Blue K20
I hope they get them stopped soon too!
Dale
Old 08-01-2021, 02:01 PM   #385
jimbosprint
After my kayak trip last weekend I noticed a pretty big puddle of transmission fluid under my radiator, but I couldn't find the leak until today. Every time I looked it was clean and dry around the fittings. Today I ran the engine and shifted between all the gears in the driveway and it was clearly leaking from the upper transmission line.
I tightened it as much as I could, cleaned it up, and topped off the transmission fluid. I'll check again next time I go for a highway drive to see if the leak is fixed. Fingers crossed!
Old 08-01-2021, 06:49 PM   #386
cj847
cj847's Avatar
I had a similar leak but on the transmission end. FYI, it only leaks while driving. So, it will leave a very small puddle when you park it, but will be a continuous drip while driving.
Hopefully it was just loose. In my case it had been previously overtightened and the line was ruined. I bought a new line and replaced it and all is good now.
cj847 is offline   Reply With Quote
Old 08-02-2021, 07:39 AM   #387
Ol Blue K20
I hope you solved it...
Dale
Old 11-19-2021, 03:31 AM   #388
jimbosprint
I took my truck on its first real four-wheelin adventure to the High Lakes today. It died on me a few times on steep technical section, but it did fine with the transfer case in low. A boulder in the middle of the trail customized my passenger side rocker a little bit. Fun day. I'll be going back for more.
Old 11-19-2021, 08:35 AM   #389
Ol Blue K20
Where's the High Lakes? I can see a burn scar in the pic's. Dang boulders, they like sneaking up and biting...
Dale
Old 11-19-2021, 10:56 AM   #390
geunther
geunther's Avatar
Hence the name "rocker" I suppose. Bummer, but cool that you are using it.
geunther is offline   Reply With Quote
Old 11-19-2021, 01:50 PM   #391
jimbosprint
High Lakes is way up above Paradise. A lot of the trails are better suited for a rock crawler than a full size pickup. The burn scar is from the enormous Dixie Fire this summer. A real shame too because I didn't get to see it before.
Name:  High Lakes Map.jpg
Old 11-20-2021, 07:39 AM   #392
Ol Blue K20
Attachment 2146858
Thanks for the info. I've heard of some of the individual lakes but I didn't know it was a OHV area. I may have to check it out sometime.
Dale
Old 12-01-2021, 03:17 PM   #393
jimbosprint
Sometimes it's fun to be a graphic designer / printer
Old 12-02-2021, 06:25 AM   #394
Ol Blue K20
Attachment 2149237
nice!
Dale
Old 12-06-2021, 12:09 AM   #395
jimbosprint
Helped out a friend today picking up a slant six for his 65 Dart.
Old 12-06-2021, 09:57 AM   #396
Ol Blue K20
It looks like you had nice weather. We were in the fog most of the day. Your truck doing what it was built for.
Dale
Old 12-12-2021, 02:03 PM   #397
jimbosprint
I just picked up this AstroVan Hydroboost for $50. Just have to figure out how to get it installed into my truck. Looks like Captainfab from this site makes an adapter bracket.
Old 12-13-2021, 05:33 AM   #398
72 tigger
72 tigger's Avatar
Attachment 2151486
That’s a nice improvement
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 12-13-2021, 10:21 AM   #399
Ol Blue K20
That will be nice. I hear good things about hydro boost.. Keep us updated on the progress, I'm curious how it comes together.
Dale
Old 12-26-2021, 08:49 PM   #400
jimbosprint
Took my truck on a ~450 mile round trip to San Jose this weekend. No problems, but 63mph in the slow lane the whole trip was a first for me. Santa got me a used canoe and patio set.
ochre
