Old 05-20-2016, 06:08 AM   #3976
RodsGreen10
RodsGreen10's Avatar
Re: Restoring Rusty
Originally Posted by Wgesnerjr View Post
Gregski,
I am interested in cleaning my truck's bolts the same way you have discovered. Would you mind sharing your vendor? Ace hardware is getting expensive.
Thanks for all your documentation. Reading Your thread has become my morning ritual.
Carry on McDuff!
Naval Jelly works for dissolving rust from bolts. It is an alternative vs buying all new. Give it a try. Or just buy Phosphoric acid. The Jelly worked great on my door jam switches.
RodsGreen10 is offline   Reply With Quote
Old 05-20-2016, 07:39 AM   #3977
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Originally Posted by Gregski View Post
yeah it did, and I thought about doing that but it's too bulky and the last thing I need is that thing getting stuck under the throttle pedal or the brake pedal.
Just leave it on the floor. It's up in the corner under the E-Brake pedal. No law says you have to use it.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-22-2016, 04:26 PM   #3978
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Fast Idle Adjustment
decided to mess with the fast idle as it was reving as high as 2600 upon the cold start procedure
here its shown at 2200
Gregski is offline   Reply With Quote
Old 05-22-2016, 08:52 PM   #3979
Gregski
Post Whore
Gregski's Avatar
basically you are supposed to turn that screw counter clockwise to bring the RPMs down, well that's all well and good except the screw is in there all upside down and who knows what clockwise or anti clockwise be, so basically just loosening it or unscrewing it makes the RPMs go down and screwing it in makes them go up, (in theory)
you see I spent a few days trying to tame this little rascal, see the most you can turn that screw is half a turn at a time cause the carburetor and such is in the way, so what The Greg would do is use a 1/4" box wrench and give it a 1/2 turn (as much as possible) then start the car and see where she idles, then the next day, (after a proper cooldown of the enjin) I would turn her another 1/2 turn and see where she RPMs
and after playing that silly gave for a day or three, I said enuff is enuff and I unscrewed that darn screw flat all the way as far as it would go without falling out, I had to see where it would RPM with it all the way out, you know the extremes from one end to the other, and I gotta tell you that even all the way out she still RPMs at above 1200, see there the pic
well I wouldn't be writing about this if it don't surprise me none you see, cause now I need to turn the screw back in some to get that 1500 sweet spot, but it aint all as easy as them marketing guys make it out to be, especially for such a small tiny little screw
Old 05-23-2016, 06:32 AM   #3980
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
1200 is a little low. I usually set Fast Idle at 1500-1800 RPM and Curb Idle at 700-800.
You should be able to swing the fast idle cam over the adjustment screw and set it even after she warms up.
Old 05-24-2016, 04:55 PM   #3981
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so from all the way out to half a turn in I think I dialed in my Fast Idle to around 1500 RPM
Old 05-24-2016, 05:01 PM   #3982
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Gentlemen I only know two things for sure about these old trucks:
1. They a leak.
2. If they don't a leak, they is out of fluids!
Old 05-24-2016, 05:07 PM   #3983
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
time to get this situation rectofied real quick
now some of youz might ask now Greg why didn't you replace that output shaft seal when you had the transmission out and on the workbench, and to you I say... [who made you guys the efficiency police, lol, ha ha] it's so much more fun doing it on the truck, well under the truck well under the now lowered truck
first we go out and git the a proper single purpose seal puller "guaranteed not to mangle the old seal as you pull it" we'll see about that
Old 05-24-2016, 05:12 PM   #3984
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
after raising the rear end of the truck sky high to prevent any seapage, we snuck up on the seal and in no time she was out
Old 05-24-2016, 05:14 PM   #3985
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
not exactly mangle free but we don't care it's gettin replaced anyway, plus its been in there for over 30 years
Old 05-24-2016, 05:16 PM   #3986
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
four dollars and thirty one cents later we were the proud owners of a brand new replacement seal part number 15041 made in Mexico
Old 05-24-2016, 05:19 PM   #3987
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
hold still for a comparison shot, old part number 15404
Old 05-24-2016, 05:21 PM   #3988
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
of note is this keep things tighty thighty spring that hides inside the metal housing and clasps the rubber seal tight, present on both seals the old one and the new one, I yanked it off the old one to show you all
Old 05-24-2016, 05:24 PM   #3989
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
now to the untrained eye this may look like a used clutch fork and release bearing...
Old 05-24-2016, 05:27 PM   #3990
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
but a Certified SemiPro Shade Tree Technician CSPSTT knows exactly where we are going with this
yeah it's the perfect output shaft seal pressure inner thingie tool
Old 05-24-2016, 05:30 PM   #3991
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and in what seemed like no time at all, the much lesser known Seal Team 5 had the new output shaft seal pressed in and ready for action
test drive done, and Leakage Report at 11
Old 05-24-2016, 05:51 PM   #3992
flashed
Re: Restoring Rusty
Now we have been schooled by the Greg ,good deal .But Chevy's still seem to find a place to leak just to give us something to do.
flashed is offline   Reply With Quote
Old 05-24-2016, 11:39 PM   #3993
enaberif
Re: Restoring Rusty
Chevy's don't leak .. They just mark their territory.
enaberif is offline   Reply With Quote
Old 05-24-2016, 11:47 PM   #3994
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
Chevy's don't lose oil. You always know exactly where it is.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 05-25-2016, 07:46 AM   #3995
MikeB
MikeB's Avatar
Re: Restoring Rusty
One question I have is regarding the Holley 4160 carburetor throttle cable linkage, I have noticed that in its current position I am not opening up the throttle plates all the way seems like I can go about an inch more, so should I move the linkage to the round hole towards the front of the carb, see pic
I think Holley sales a special adapter/stud to go in that hole to move the cable there
I've always used the location in your picture halfway between the red circle and red arrow, where some type of connector is installed.
But if that's a no-go, then here's what you're looking for:
https://www.holley.com/products/fuel...age/parts/6026
You will also need a longer ball stud with 1/4" threads. One in this kit should work.
https://www.holley.com/products/fuel...ies/parts/20-2
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-25-2016, 08:14 AM   #3996
MikeB
MikeB's Avatar
Re: Restoring Rusty
Whoops, I was wrong about the hole I've used. My 6-cyl throttle cable wasn't long enough, so I used a Lokar cable and bracket that I had in the shop. Lucky I wasn't able to sell it at a swap meet!
Mike
Old 05-25-2016, 10:27 AM   #3997
Hewfil1
Hewfil1's Avatar
Re: Restoring Rusty
Every time I see the stance on this truck I break inside a little out of it's beauty. Then I remember you want to lower it because it's not a 4x4, and find myself cringing. But to each their own, and as always an amazing thread.
P.S. At least she's not slammed.
Hewfil1 is offline   Reply With Quote
Old 05-26-2016, 11:21 AM   #3998
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
fear not it's already been lowered, so you may be liking it after I already lowered it, LOL
Old 05-26-2016, 12:11 PM   #3999
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
hey bro how did that output shaft seal repair turn out? did it stop the leak man?
tough brake bro, tough brake!
Old 05-26-2016, 12:17 PM   #4000
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well the good news is the new output shaft seal area be dry as a bone
another job that needed not be doin' done right! know what I'm a sayin' folks? ha ha
