#401 |
CopyWritten
Re: Project Lemon Drop: anything but stock!
Thats what I am talkin about. I am all about comfy! I was getting ready to order a new tilt column, but now I am gonna wait till I get those seats in to see if I need a shorter one.
#402 |
Life, Be In It.....
![]() Join Date: Oct 2003
I'm taking a break from the wiring, since Kevin finished welding up my coverted blazer gas filler tube and adding a bit to my blazer tank. I painted, installed and connected all the fuel and vent tubes. It turned out really nice. I got the idea for the filler tube from Livrat another member and modified it a little.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 06-05-2008 at 05:15 PM. |
#403 |
Life, Be In It.....
There are some more pics with the tubes attached
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
#404 |
Dat looks puurdy
![]() Kevin LFD Inc. |
#405 |
Jugernot, truck is looking great, i was just playing with my truck this weekend trying to plan out the wiring and thought about puting the fuse block in the kick panel vent, then saw you did it, how funny. but i have a few questions for you, how are you planning on routing the wires from the fuse panel to the engine, headlight section? in plain getting all wires to outside the cab? did you still use the painless wire disconnect the normally goes thru the firewall?
Do you happen to have a picture of the the fuse panel installed? if your willing to share if not i understand, i have a couple of secerts that i want to keep on my truck as well until its done. Thanks, Phil |
#406 | |
Life, Be In It.....
If you are going to put your harness into the vent, make sure that you have the turn signal flasher fuses install to check fitment ans accessiblity. As for the wires the go into the engine compartment, Kevin put a hole through the kick panel. I do not have a picture of it but it is oposite the kick panel vent opening some where around the area shown by yellow in the picture below. I have no problems sharing, in fact a couple of memebers have used our idea for the gas filler door. I hope this helps you out.
#407 |
Life, Be In It.....
pcorriveau951,
Just another thought, you could probable also put the harness through this area, but of course on the drivers side.
#408 |
thank you for sharing, im trying to decide which way i want to go, i hate the look of wires im trying to figure a way to get it all done with very minimal amounts of wires being seen anywhere in the truck, going to be alot of work but i think it will be worth it.
#409 |
Any updates on this build guys?
#410 |
Life, Be In It.....
Sorry the only update I have is that I had a vistor today, who said my paint was to loud and gave me a ticket.....................
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 12-04-2008 at 12:47 AM. |
#411 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#412 |
Dude I think that dam Cop parked on your Smart car
#413 |
Life, Be In It.....
I wish, just show and tell as the little one's school
#414 |
I didn't see that paint option when I got my Magnum lol
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
#415 |
Ready to go fast!!
jesse james the bike builder once said : "international color for scared is yellow" lol just a thought but nice truck man lol
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
#416 |
Life, Be In It.....
Okay, Well I'm trying to light the inspiration fire and motivated myself to get to work on Lemon Drop. So I finished installing by March Performance Serpentine Belt system. After three trips to Napa I found the proper belt size, which was a couple of inches less that what the instruction stated.
I also used a piece of 3/8 inch brake line to fad up a fuel line from the carb to the pump. I will be using a piece of stainless steel tube to replace it (more bling). I may have an issued with the routing of the lower radiator hose, but since I plan on using electric fans it may not be a problem. I think I will work on the AC/Heater hoses next.. I can’t decide if I want to use steel braided to black. I know the steel braided would look great, but $$$ has been a little hard to find. I have not inspired myself enough to finish the wiring thought.
#417 |
Under Construction
looking good. keep chugging along.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#418 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I say use black hoses and paint the clamps a satin black..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#419 |
Life, Be In It.....
I was thinking black hoses and polished clamps
#420 |
VA72C10
![]() Join Date: Mar 2008
It's come a long way.....can't wait to see it finished up and on the road...do you have a target date?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#421 | |
Life, Be In It.....
I would like to get the engine running by summer, this summer.
#422 |
Life, Be In It.....
Okay, I spent about 2 hours trying to figure out what fittings I needed for the AC Heater lines. Then compared the priced with a braided hose and rubber hose. The braided kit would total $600. The rubber hose kit would total $350. This is using stainless fittings from www.gottoshow.com. So because of the cost I will probably go with the rubber hose.
Anyone know of a place to get a show stuff cheaper?
#423 | |
![]() Join Date: Apr 2004
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#424 |
Life, Be In It.....
I did a quick search, but could not find anything about that business. Anyone got any info on this company?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 01-28-2009 at 10:07 PM. |
#425 |
It'd be alot cooler if you did
Very slick build.
Mine isn't nearly as far along as yours, but I never thought of how much hoses were going to cost for the vintage air system on my truck.... add it to the list $$$ ![]() Last edited by smashingchuck; 01-31-2009 at 08:04 PM. |
